em nhận cây1280, rơi đất bị contacservice; chạy lại pm thì không lên nữa và đây là log em vùa chạy xong cao thủ nào vào xem cho em cái
Backup saved to "C:\mobileEx\3.5\data\backup\XGOLD_RM-647_9813DCABA21DE404_IMEI.back"
MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C087B39E
Using device: HTI, FW ver: 00.50, SN: 01008AE7
Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14214(25-10-2012)
Device synchronized.
CPU: XGOLD 110
Using embedded SBL from MCU.
Sending EBL Loader ...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.19
EBL version: Default_RAM_Bootloader
Set baud rate to: 921.60 Kbit/s
Flash ID: 0020 88C0 - 23280003 [ST M58MWR064FU,64 Mbits]
CFI information:
Flash settings: 0/1, size: 0x00800000
2 Block regions:
127 x 0x00010000 = 0x007F0000
8 x 0x00002000 = 0x00010000
EBL ready !
Processing file: rm647_006.510
Downloading item CODE:hw_b2_rm647_r06.510.fls, num block: 3, size: 4.04 MB
Erasing area 0x00800000-0x00A0FFFE ...OK
Programming completed in 40.933 s
Erasing area 0x00C60000-0x00E5933E ...OK
Programming completed in 38.528 s
Erasing area 0x00FFC000-0x00FFC03E ...OK
Programming completed in 0.161 s
Error reading checksum!
Processing file: rm647_006.51mr
Downloading item CUST:hw_b2_rm647_006.51mr.fls, num block: 1, size: 1.10 MB
Erasing area 0x00210000-0x003288BE ...OK
Programming completed in 19.569 s
Checksum mismatch: Phone calculated 0x0033, software calculated 0x1507
Processing file: rm6470_nai06.51mr
Downloading item CUST:hw_b2_rm6470_nai06.51mr.fls, num block: 1, size: 305.83 KB
Erasing area 0x00EB0000-0x00EFBA3E ...OK
Programming completed in 5.246 s
Checksum mismatch: Phone calculated 0x00F0, software calculated 0xA1D0
Total time for flashing process(boot+erase+write) was 3 min 3.317 s
Phone type: RM-647
SW version: V 06.51 13-05-11 RM-647 (c) Nokia
Imei plain: 35432604108267-9
Product code: 0592248
Cellular system: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: MR
Language Pack:
English,Hindi,Bengali
Imei net: 35432604108267
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000030002
bác nào đã gặp qua xin chỉ giáo; thank
