    Thành viên tích cực tientrung199x's Avatar
    Mặc định xem hộ em 3110c lỗi
    em flash bằng Mxbox trong quá trình chạy hiện lỗi
    MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C087B2FE
    Using device: HTI, FW ver: 00.50, SN: 0100980D
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14214(25-10-2012)
    Processing MCU file: 3110c_TV_OK.mcusw
    [BB5,BB5 ALGORITHM] size: 14.49 MB
    Supported Ids: 0103192101001101, 010C192101001101
    CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAP3G ver: PA 1.x]
    EM0 ID: 00000232
    EM1 ID: 00000353
    PUBLIC ID: 18E00019214B7D564F2C66E13C77912FB609A469
    ASIC MODE ID: 00
    ROM ID: 191EC665DFAAF68F
    eBB5ProtocolType: OLD
    Storage0: 0089 8981 - 0000 6A21 [Intel NU48F256,256 Mbits] type: FLASH,NOR, asic:CMT
    Storage content: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
    TransmissionMode: 16Bit
    TransmissionMode: DDR&TX2
    Storing certificate [NPC, VARIANT, R&D] ...OK
    Erase size: 16.37 MB
    CMT FLASH,NOR area [00000000-000006BF]
    CMT FLASH,NOR area [000006C0-0001FFFF]
    CMT FLASH,NOR area [00020000-0007FFFF]
    CMT FLASH,NOR area [00080000-000DFFFF]
    CMT FLASH,NOR area [00100000-001FFFFF]
    CMT FLASH,NOR area [00200000-0031FFFF]
    CMT FLASH,NOR area [00320000-0105FFFF]
    CMT FLASH,NOR area [01060000-01067FFF]
    CMT FLASH,NOR area [01068000-0107FFFF]
    erased in 0.156 s
    Prog.status for Asic CMT ...
    NOR: OK
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    Selecting first CMT PAPUB block with matching RootKey.
    CMT PAPUBKEYS: C0E691EA [RAP Certificate 66 v2] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    CMT PMM_CONF block sent
    CMT SBIF_CONF block sent
    NOR: OK
    Programming completed in 1 min 14.719 s
    Processing PPM file: 3110c_TV_OK.ppm_v
    [BB5,BB5 ALGORITHM] size: 4.35 MB
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
    Erase size: 4.62 MB
    CMT FLASH,NOR area [01080000-0151FFFF]
    Error while erasing, Result: 00000000000000 , 0
    anh em xem hộ em với
    Thành viên tích cực BMmobile's Avatar
    Dec 2012
    chuyển sang box khác flash xem sao nhé
    Thành viên tích cực quang_hhbg's Avatar
    Mar 2011
    bắc giang
    cho sang box khác thử đi anh?
    quang_hhbg
    01686381111
    Nov 2012
    ĐỒNG THÁP
    vệ sinh sợi cáp đem qua box khác luôn bạn
    thanks anh em .... đen thế ....HWK lại không update được mới đau... bị bao lần rồi
    Mar 2011
    bắc giang
    dùng best tool hay phoneix đi anh.
    quang_hhbg
    01686381111
    thanks mọi người .... chạy lại được rồi ... hay cáp đa năng của em có vấn đề ...
