Kết quả 1 tới 10 của 12
    Thành viên mới DICHTHU_92's Avatar
    Nov 2011
    Mặc định C2-03 imel 12345610654321?
    Nhờ ace xem hộ
    Basic Phone Information
    MCU Version: V 03.82 17-10-11 RM-704 (c) Nokia
    IMEI Plain : 12345610654321?
    IMEI Spare : A123456106543210
    IMEI SV : 31234561065432109F
    IMEI (2nd) : 12345610654321?
    Phone Model: K C2-00
    Category : Entry Phone
    Phone Type : RM-704
    Extended Phone Information
    Product Serial Number: 4130196AH
    Product Code : 059D470
    Module Code : 0204579
    Basic Production Code: 059D007
    Long Production SN : 0
    PPM SW Version : V 03.82 17-10-11 RM-704 (c) Nokia V
    BT MCM Version : 19b5-22012
    MCU SW Version : V 03.82 17-10-11 RM-704 (c) Nokia
    HW Version : 1000
    RFIC Version : Dummy RFIC version
    LCD Version : TPO
    FWID Version : iV 03.82 17-10-11 RM-704 (c) Nokia V 03.82 17-10-11 RM-704 (c) Nokia V 059D470 001
    Content Pack Version : Content: v_dgray_059C1T1 V 03.82 17-10-11 RM-704 (c) Nokia
    Bluetooth ID : 00:02:5B:00:A5:A5
    CS Type : GSM900, GSM1800
    ********** SIMLOCK INFO **********
    CONFIG_DATA : 0000000000000000
    PROFILE_BITS : 0000000000030000
    ASIC : 11
    PROVIDER : Unknown Provider
    LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10
    Unable to read SP Data..
    SIMLOCK_TYPE : PA_SL3 (15-digit NCK)
    SIMLOCK_TEST : PASSED
    SECURITY_TEST : FAILED
    > Try SX4 "PM AUTH"
    > Then Write PM 1 and 309
    SECURITY_CODE : 12345
    PHONE_MODE : TEST
    Dynamic Camera Configuration
    DCC ID : NI00CS00000406150123
    DCC Ver: XXXXXX
    ERROR: DCC File Mismatched!
    Required DCC File: NI00CS00000406150123
    Write the correct DCC to Fix the Problem
    Selected VPL File:
    RM704_059C1T1_03.82_032.vpl
    Variant Details : RM-704 SEAP V DGRAY STROKE VN
    Software Version : 03.82
    Product Type : RM-704
    Product Code : 059C1T1
    Variant Version : 032
    em đã hết cách mong ace chi cách!
    Thành viên tích cực hoangdaika's Avatar
    THAY CẶP KC ĐI ANH IMEI Plain : 12345610654321? CHẠY GÌ NỮA
  3. ( hoangdaika ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    DICHTHU_92 (22-12-2012)
    Thành viên tích cực BMmobile's Avatar
    Dec 2012
    thay cặp cho nhanh bạn nếu ko có backup nhé
    Nov 2011
    Backup sao huynh?
    Dec 2012
    trước lúc flash bạn có backup rpl cho em nó ko vậy? nếu có thì wr lại file RPL là ok ..ko có backup thì thay cặp là ok
  7. ( BMmobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  8. #6
    Thành viên chính thức quocthanhmobile1982's Avatar
    Nov 2012
    Trích Được post bởi BMmobile Xem bài viết
    chuẩn ko cần chỉnh....
    TÂYNINH tell:0937575256_0909570881
  9. #7
    Nov 2011
    Nếu thay cặp thì đời này nó có trùng với thằng nào không?
  10. #8
    Nov 2011
    em co cái boar nhưng chỉ còn con flash được ko
  11. #9
    không được bác ơi phải là nguyen cặp nha
  12. ( mobingoc ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  13. #10
    Moderator VanTuan-ST's Avatar
    Sóc Trăng
    Có backup thì restore , ko backup thì thay cặp thôi!
  1. 6233 imei 12345610654321?
    By chienmobile2010 in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 24-11-2012, 14:37
  2. 6500s báo số sêri - 12345610654321?
    By nguyennghi in forum BB5
    Bài viết cuối: 15-09-2010, 11:23
  3. 6680 imie 12345610654321 ???
    By hogus405 in forum BB5
    Bài viết cuối: 07-01-2009, 12:43
  4. Sửa lại IMEI 12345610654321
    By ddhuynhtho in forum Box for Unlock BB5
    Bài viết cuối: 29-02-2008, 22:58
  5. 6270 số sêri 12345610654321?
    By dtddphuoclong in forum BB5
    Trả lời: 15
    Bài viết cuối: 26-01-2008, 13:44
