Kết quả 1 tới 10 của 13
    Thành viên chính thức hovietluy's Avatar
    Mar 2011
    Mặc định sem giúp em cái log 2700c
    ae sem hộ em cái log 2700c tới phút cuối đứng im luôn .MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C08728AA
    Using device: USB ROM and HTI, FW ver: 00.50, SN: 00016122
    Connection status: EHCI:HUB:HUB::USB 2.00 (Full-speed)
    Driver: NMWCD, ver: 7.1.32.75
    Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14214(25-10-2012)
    Processing MCU file: rm561__09.98.mcusw
    [BB5,BB5 ALGORITHM] size: 19.41 MB
    Waiting for USB ROM device ...
    CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0]
    CMT EM0 ID: 00000296
    CMT EM1 ID: 00000B22
    CMT PUBLIC ID: 1670020983D7035495DFCD8D3ADFE2674BEC5FBA
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
    CMT ROM ID: 273F6D55DFAAF68F
    Flashing CMT Update Server Data, ULO: 0x3900 bytes
    Update Server code succesfully sent to phone.
    Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes
    Flashing CMT Update Server Data, PASUBTOC: 0x59980 bytes
    Waiting for USB device removal ...
    Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 1A59C501
    Verifying communication to device OK.
    Erase size: 21 MB
    CMT FLASH,NOR area [00000000-000006BF] erased in 0.578 s
    CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.578 s
    CMT FLASH,NOR area [00040000-000BFFFF] erased in 2.172 s
    CMT FLASH,NOR area [000C0000-0013FFFF] erased in 2.390 s
    CMT FLASH,NOR area [00140000-0137FFFF] erased in 1 min 18.531 s
    CMT FLASH,NOR area [01380000-0151FFFF] erased in 7.344 s
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    Selecting first CMT PAPUB block with matching RootKey.
    CMT PAPUBKEYS: 3EA22A1D [RAP Certificate 202 v.1] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    Programming completed in 1 min 37.594 s
    Processing PPM file: rm561__09.98.ppm_v
    [BB5,BB5 ALGORITHM] size: 6.90 MB
    Erase size: 8.62 MB
    CMT FLASH,NOR area [01520000-01DBFFFF] erased in 38.453 s
    Programming completed in 34.984 s
    Processing CNT file: rm561__09.98.image_v_blac
    [BB5,BB5 ALGORITHM] page size: 128 K size: 13.64 MB
    Erase size: 34 MB
    CMT FLASH,NOR area [01DC0000-0215FFFF] erased in 17.312 s
    CMT FLASH,NOR area [02160000-03FBFFFF] erased in 2 min 20.969 s
    Programming completed in 1 min 7.203 s
    Total time for flashing process(boot+erase+write) was 8 min 36.781 s
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...
    Phone not found, retrying ...
    Warning: Phone did not reboot to normal mode.
    ae sem ho em vợi ạ.
    May 2012
    boot băng cáp óp lưng đi anh
  3. ( LÊ_TRUNG ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    hovietluy (22-12-2012)
    Jan 2009
    Hải Phòng
    flash bằng fbus xem thế nào,cái này là nó ko tesmode dc lên ko đồng bộ , mà máy tình trặng sao vậy? nói rõ ra ace sẽ giúp bạn nhiệt tình.
  5. ( tuân gsm ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Mar 2011
    máy khách bảo ngủ đêm tới sáng thì mất nguồn.luôn bạn plash usb tới đoạn cuối đứng im luôn ko đồng bộ được.
    múc ver 9.98 đi bác chuyển qua ốp lưng hoặc cáp đa năng xem sao
  8. ( mobingoc ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  9. #6
    Mar 2011
    để mình plash thử bằng cáp đa năng sem sao.có j báo mấy pác sau.thanhk mấy pác
  10. #7
    Jan 2009
    Hải Phòng
    fbus cũng ko dc thì test đường bsi trước khi dùng đến đao to búa lớn nha
  11. ( tuân gsm ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  12. #8
    Mar 2011
    Trích Được post bởi tuân gsm Xem bài viết
    vâng có j em báo mấy pác sau ạ.
  13. #9
    Thành viên tích cực khangdl84's Avatar
    Nov 2011
    dùng phonix thử em nó đi. nếu có bõ khác thì chơi thử. mx hay bị như vậy. có khi ban gở mx ra để 2 -3 tiếng sau là chạy phapha. cái này mình bị hoài
    ĐỨC LINH, BÌNH THUẬN.
    yahoo: khangdl8401. ĐT: 0979430937
  14. #10
    Mar 2011
    Trích Được post bởi khangdl84 Xem bài viết
    dùng phoenix not ok bạn ah.báo lỗi
  1. xin giúp 2700c
    By manhdung81mobile in forum BB5
    Bài viết cuối: 24-06-2012, 10:56
  2. 2700c cần anh em giúp
    By thanhphuek in forum BB5
    Bài viết cuối: 04-09-2011, 00:25
  3. 2700c xin giúp
    By hanayuky18 in forum BB5
    Bài viết cuối: 03-09-2011, 15:40
  4. Trả lời: 15
    Bài viết cuối: 01-06-2011, 12:30
  5. 2700c cần giúp
    By anhquoc in forum BB5
    Bài viết cuối: 24-08-2010, 08:34
