    Thành viên tích cực 99999's Avatar
    Dec 2011
    Mặc định 1650 contact
    máy đang xài bình thường rồi khơi động tắt ngưồn, chạy mxbox báo lỗi thế này, chạy bằng jaf cũng vậy , xóa full chạy not ok , ko đồng bộ được nhờ ae giúp
    đây là log flash
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C0855D93
    Using device: HTI, FW ver: 00.50, SN: 0000B3E9
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14214(25-10-2012)
    ASIC ID: 0x2292 [UPPCosto ver: 1.3]
    SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
    FlashID0: 0089 8874 [Intel 28F640W18,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF
    ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
    Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0
    UEM ID: 00C71EB0A3BDA66
    ASIC type: 11
    UEM Imei: 35680002250141
    Flash Imei: 35680002250141
    RPL saved to "C:\mobileEx\3.5\data\backup\RPL\35680002250141_BA CK.rpl"
    Processing MCU file: rm305_06.000
    [DCT4,DCT4 ALGORITHM] size: 2.33 MB
    Supported Ids: 2292
    UEM ID: 00C71EB0:2984DA60
    Area [01000000-0100FFFF] erased in 0.563 s
    Area [01010000-0179FFFF] erased in 1 min 9.063 s
    Area [017A0000-017EFFFF] erased in 3.218 s
    Area [01F00000-01FDFFFF] erased in 0.094 s
    Flash programming ...
    Programming completed in 21.312 s
    File processed in 1 min 47.906 s
    Processing CNT file: rm3050_nai6.00mq
    [DCT4,DCT4 ALGORITHM] size: 194.27 KB
    Supported Ids: 2292
    Area [01760000-0179FFFF] erased in 2.187 s
    Programming completed in 1.734 s
    Content extract fail, continue anyway ...
    File processed in 1 min 16.594 s
    Processing PPM file: rm305_06.00mq
    [DCT4,DCT4 ALGORITHM] size: 2.91 MB
    Supported Ids: 2292
    Area [01240000-0125FFFF] erased in 1.203 s
    Area [01260000-0175FFFF] erased in 45.875 s
    Programming completed in 26.563 s
    File processed in 1 min 21.078 s
    Total time for flashing process(boot+erase+write) was 4 min 25.578 s
    Dec 2011
    còn đây là log check
    ASIC type: 11
    MasterCode: 2627004520
    RPL saved to "C:\mobileEx\3.5\data\backup\35680002250141_BACK.r pl
    Chưa đồng bộ máy được mà anh => chuyển qua HWK hay MT xem sao => chứ máy Flash xong => chưa đồng bộ được thì máy củng sẻ bị hiện trạng như củ thôi ^^ !
    Jan 2009
    Hải Phòng
    che chân vpp lại rồi flash tiếp phát nữa chắc ok thôi
    nhờ bõot khác múc đi bác
    Thành viên tích cực hoangdaika's Avatar
    làm theo tuân gsm đi bạn kg được thì thay upp kc nhé
  1. 1650 contact service
    By huu_vinh in forum DCT4 - WD2
    Bài viết cuối: 08-09-2011, 22:49
  2. 1650 contact service
    By nguyengiap_84 in forum DCT4 - WD2
    Bài viết cuối: 27-10-2010, 17:20
  3. cần giúp gấp 1650 hiển thị contact sỉvice
    By tuyen_mobile1709 in forum DCT4 - WD2
    Bài viết cuối: 15-07-2010, 07:11
  4. 1650 contact service xin mọi người giúp!
    By ohayo in forum DCT4 - WD2
    Bài viết cuối: 16-03-2010, 12:18
  5. 1650 contact servic
    By anhdaomobile in forum DCT4 - WD2
    Bài viết cuối: 10-07-2008, 14:22
