tình hình là nhận em này bị dead phone.đem mxbox buscheck thì banh imei.em flash lại thì có nguồn rồi.nhưng lên chử nokia rồi trắng màn hình.đã tét MH khác và kiểm tra socket kỹ rồi.mình buscheck lại em nó cho ae xem ne.mong ae cho ý kiến.
MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C087C5B9
Using device: HTI, FW ver: 00.50, SN: 0100E833
Connection status: EHCI:HUB:HUB:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7600.16385
Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006
030C192101033000 [RAP3G ver: PA 3.0]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 0E000103074A8E569851F976C0C0A653797266C4
ASIC MODE ID: 00
ROOT KEY HASH:
9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
eBB5ProtocolType: OLD
Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT
TransmissionMode: 16Bit
TransmissionMode: DDR&TX2
Selected firmware certificate matched.
Original Imei: 35199404183328
Original Product code: 0579808
Bluetooth ID: 5C57C8974899
SIMLOCK PA identifier:
[0] PA_SL3
Phone type: RM-561 (Nokia 2700 classic)
SW version: V 09.98 06-09-10 RM-561 (c) Nokia
Imei plain: 35199404183328-5
Battery voltage: 4531 mV, current: 43 mA
Language Pack:
- not available.
warning: avoid SW Downgrade
& manual erase to this phone !
Camera config: NIMMIIIIRRFF00000000, ver: XXX.XXX
warning: DCC corrupted !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 351994041833285
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
Chú ý: màu chữ bài viết nha bạn, đã edit dùm
			 AE xem giùm log con 2700c với
