tình trạng máy mở nguồn chỉ sáng đèn 2 hông , em đo áp vẫn đủ em thử check nhưng máy ko đồng bộ được đây la log của em nó nhờ mọi người giúp dùm em tk nhìu
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C0820380
Using device: HTI, FW ver: 00.50, SN: 000157C5
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14214(25-10-2012)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAP3G ver: PA 1.x]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 2350010336378C565927EA7EDE6460E503CDC9D6
ASIC MODE ID: 00
ROM ID: 191EC665DFAAF68F
eBB5ProtocolType: OLD
Storage0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: FLASH,NOR, asic:CMT
TransmissionMode: 16Bit
TransmissionMode: DDR&TX2
Original Imei: 35694703989018
Original Product code: 0563812
Bluetooth ID: 9C1874B317EB
SIMLOCK PA identifier:
[0] PA_SL
Đây là log chạy
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Processing MCU file: rm217__07.30.mcusw
[BB5,BB5 ALGORITHM] size: 14.50 MB
Supported Ids: 0103192101001101, 010C192101001101
Storing certificate [NPC, VARIANT, R&D] ...OK
Erase size: 16.37 MB
CMT FLASH,NOR area [00000000-000006BF]
CMT FLASH,NOR area [000006C0-0001FFFF]
CMT FLASH,NOR area [00020000-0007FFFF]
CMT FLASH,NOR area [00080000-000DFFFF]
CMT FLASH,NOR area [00100000-001FFFFF]
CMT FLASH,NOR area [00200000-0031FFFF]
CMT FLASH,NOR area [00320000-0105FFFF]
CMT FLASH,NOR area [01060000-01067FFF]
CMT FLASH,NOR area [01068000-0107FFFF]
erased in 40.688 s
Prog.status for Asic CMT ...
NOR: OK
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
Selecting first CMT PAPUB block with matching RootKey.
CMT PAPUBKEYS: 7F7E6491 [RAP Certificate 52 v1] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
CMT PMM_CONF block sent
CMT SBIF_CONF block sent
NOR: OK
Programming completed in 1 min 13.140 s
Processing PPM file: rm217__07.30.ppm_r
[BB5,BB5 ALGORITHM] size: 5.14 MB
Erase size: 5.50 MB
CMT FLASH,NOR area [01080000-015FFFFF]
erased in 14.343 s
NOR: OK
NOR: OK
Programming completed in 26.766 s
Processing CNT file: rm217__07.30.image_ctv_cn
[BB5,BB5 ALGORITHM] page size: 64 K size: 4.57 MB
Erase size: 9.87 MB
CMT FLASH,NOR area [01600000-01FDFFFF]
erased in 13.625 s
NOR: OK
NOR: OK
Programming completed in 22.078 s
file rm217__07.30_sd_ctv_prc_512_v2.fpsimage is empty, skipped.
Total time for flashing process(boot+erase+write) was 3 min 18.438 s
			 6300 nhờ mọi người giúp dùm em ...
