    Thành viên chính thức nguyenlaluong's Avatar
    Mặc định C2-03 bật nguồn lên trắng màn Hình treo luôn xin giúp.
    em mới nhận con c2-03 bật nguồn lên trắng màn hình treo máy luôn , em chạy phần mềm , làm cpu+flash , thay cáp , thay màn hình , nhưng not ok , flash no báo lỗi như này các bác ạ MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C08598C8
    Using device: USB ROM and HTI, FW ver: 00.50, SN: 000118A7
    Connection status: UHCI:HUB::USB 1.10 (Full-speed)
    Driver: NMWCD, ver: 7.1.32.75
    Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
    Waiting for USB ROM device ...
    Device synchronized.
    CPU: XGOLD 213
    Sending EBL Loader...OK
    Sending EBL ...OK
    Getting EBL Version ...
    Boot mode: 0xCC
    EBL version major/minor: 10.37
    EBL version: Quantum_Bootloader_10.37_M1S1
    Protocol version suggested by phone: 3
    Set baud rate to: 6.50 Mbit/s
    Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits]
    CFI information:
    Flash settings: 0/1024, size: 0x04000000
    1 Block regions:
    512 x 0x00020000 = 0x04000000
    EBL ready !
    Processing file: rm702__07.63.mcusw
    Downloading item CODE:rm702__07.63.mcusw_ebl_psi.fls, num block: 4, size: 28 MB
    Erasing area 0x40000000-0x4001FFFE ...OK
    Programming completed in 0.343 s
    Erasing area 0x40040000-0x4005FFFE ...OK
    Programming completed in 0.360 s
    Erasing area 0x40060000-0x4015FFFE ...OK
    Programming completed in 1.657 s
    Erasing area 0x40280000-0x41D3FFFE ...OK
    Programming completed in 37.781 s
    Checksum verified (0x787E)
    Processing file: rm702__07.63.ppm_v
    Downloading item CUSTackage_v.ppm_ebl_psi.fls, num block: 1, size: 5.72 MB
    Erasing area 0x41DC0000-0x4237843A ...OK
    Programming completed in 8.547 s
    Checksum verified (0xD1B9)
    Processing file: rm702__07.63.image_v_059L5R6
    Downloading item CUSTackage_v_059L5R6.image.fls, num block: 1, size: 12.50 MB
    Erasing area 0x424C0000-0x43E1FFFE ...OK
    Programming completed in 18.594 s
    Checksum mismatch: Phone calculated 0xDBB2, software calculated 0xCD25
    Task failed at (08000012)!!!
    Last RX buffer: 01 00 DB B2 43 00 00 00 82 89 00 00 01 00 28 23 00 00 00 00 00 04 00 00 01 00 00 00 00 00 00 04 00 02 00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    May 2012
    chạy em nó bằng cáp ốp lưng đi bạn
    Thành viên mới HOANGLINH_2009's Avatar
    Cool
    Trích Được post bởi satthu_mobile Xem bài viết
    cáp ốp lưng con này sư huynh có không bán cho đệ một sợi
    Thành viên chính thức Tuấn Tân Trụ's Avatar
    huyện tân trụ
    thay cặp đi bạn ok liền
    Nhẫn một chút sóng yên gió lặng.0973.
    Lùi một bước biển rộng trời cao. 286.172
    Thành viên tích cực PHÁT TÀI's Avatar
    kiểm tra lại cáp , đổi sang box khác xem sao
    ccydia / manage / sources / edit / add / iphone.gsm.vn
    Raw file system -> var -> root -> media -> cydia -> AutoInstall
    May 2012
    Trích Được post bởi HOANGLINH_2009 Xem bài viết
    nào giờ chưa thấy cáp ốp lưng em nó àh
    thường những dóng mới giò chỉ có cáp ốp lưng usb nhưng chạy cũng ok lắm
    yh chanyenmobile_led1202
    ctk hà Văn Yên face hachanyen
    sdt zalo..0972444489
    BỘ ngoại giao trùm các 4r
    c2-03 cơ mà . su huynh dưa cáp con gì đấy ........?
  1. 6303c lên nguồn trắng treo.
    By DH-Mobile in forum BB5
    Bài viết cuối: 06-10-2013, 11:38
  2. Trả lời: 7
    Bài viết cuối: 29-01-2011, 12:47
  3. Trả lời: 3
    Bài viết cuối: 01-11-2010, 10:10
  4. Trả lời: 12
    Bài viết cuối: 07-02-2010, 10:14
  5. Trả lời: 11
    Bài viết cuối: 17-05-2007, 13:33
