Trang 1 của 4 1 2 3 4 CuốiCuối
Kết quả 1 tới 10 của 34
    Thành viên tích cực mrtranquang1993's Avatar
    Mar 2012
    Mặc định Xin giup log 1208
    máy boschek bình thường, scan phone không được, không factory reset được
    ImageFile:\file flash\1208_RH-105_v5.91\RH-105\rh105_05.910
    PhoneType : DCT4
    Algorithm : DCT4 ALGORITHM
    Supported Hardwares :
    > 2292
    Secondary Sending Speed : 100000Hz
    Algorithm Sending Speed : 6500000Hz
    Program Sending Speed : 6500000Hz
    Message Reading Speed : 51000Hz
    Number of Blocks : 147
    Entry Point: 0x00E7
    Is128k: True
    Boot Check, Please wait...
    MCUID Response
    MessageID : 92
    msbUPP_ID : 22
    lsbUPP_ID : 92
    Boot OK
    Boot File: C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u3_2nd.fia
    DataLen : 000009D8
    Secondary Loader Sent...
    Boot OK!
    MCU_CONFIGURATION_RESPONSE_DCT4_MUL3
    DCT4 Mess 9F MUL3 Mess 9F
    TransMode : 03
    NumFlash : 02
    DevAddr0 : 01
    ManuId0 : 0089 - INTEL
    DevId0 : 8872 - Type not in database
    ExtId0 : 0000
    RevId0 : 0121
    SectorSize0: 10
    Reserved0 : 00
    DevAddr1 : 02
    ManuId1 : 0000 - Flash
    DevId1 : 0001 - not used
    ExtId1 : 0000
    RevId1 : 0000
    SectorSize1: 00
    Reserved1 : 00
    ExtBUSC : AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
    CheckSum : 1A
    ReceiveConfigurationResponse_DCT4 - FLS1_NO_ERROR
    SearchForBootstrap_DCT4 : No Error
    Algo Match File : C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u3_intel.fia
    ALGO SENT..
    Perform AUTHENTICATION..
    MSID: 84F2ADABDD0B23800147918756
    DecodedMSID: 843E4EBAE9000F3AC8A8000000
    EncodedFAID: F121419D3085BCF7C0D121A5
    Authentication : SUCCESSFULL
    Erasing address:
    >> 01000000 : 0100FFFF
    BB_PROGRAMMING_STATUS_REQUEST : 04 FF
    ProgrammingStatus_DCT4 : No Error - 0 (0x00)
    >> 01010000 : 013AFFFF
    >> 013B0000 : 013EFFFF
    >> 017C0000 : 017EFFFF
    >> 01FC0000 : 01FEFFFF
    Erasing Done
    Flashing ImageFile
    ContinueFlash_DCT4 Complete
    Write Time Elapse : 00:00:22
    FLASH Mode Set to : PHONEMODE_FLASHBUS
    BB_PROGRAMMING_STATUS_REQUEST : 04 FF -- Progamming status
    First Byte OK
    Second Byte OK
    BB_PERM_DATA_RESTORE_REQ : 18 FF
    BB_RESTART : 07 FF
    MCURestart : SUCCESS
    Making delay between files for 6000ms
    ImageFile:\file flash\1208_RH-105_v5.91\RH-105\rh105_05.91mr
    PhoneType : DCT4
    > 2292
    Number of Blocks : 77
    Entry Point: 0x00D2
    Is128k: True
    MCUID Response
    MessageID : 92
    msbUPP_ID : 22
    lsbUPP_ID : 92
    Boot OK
    DataLen : 000009D8
    Boot OK!
    TransMode : 03
    NumFlash : 02
    DevAddr0 : 01
    ExtId0 : 0000
    RevId0 : 0121
    SectorSize0: 10
    Reserved0 : 00
    DevAddr1 : 02
    ExtId1 : 0000
    RevId1 : 0000
    SectorSize1: 00
    Reserved1 : 00
    CheckSum : 1A
    ALGO SENT..
    Erasing address:
    >> 01240000 : 0124FFFF
    >> 01250000 : 0137FFFF
    Erasing Done
    Flashing ImageFile
    Write Time Elapse : 00:00:13
    First Byte OK
    Second Byte OK
    BB_RESTART : 07 FF
    ImageFile:\file flash\1208_RH-105_v5.91\RH-105\rh1050_nai5.91mr
    PhoneType : DCT4
    > 2292
    Number of Blocks : 9
    Entry Point: 0x00CA
    Is128k: True
    MCUID Response
    MessageID : 92
    msbUPP_ID : 22
    lsbUPP_ID : 92
    Boot OK
    DataLen : 000009D8
    Boot OK!
    TransMode : 03
    NumFlash : 02
    DevAddr0 : 01
    ExtId0 : 0000
    RevId0 : 0121
    SectorSize0: 10
    Reserved0 : 00
    DevAddr1 : 02
    ExtId1 : 0000
    RevId1 : 0000
    SectorSize1: 00
    Reserved1 : 00
    CheckSum : 1A
    ALGO SENT..
    MSID: 841144B01D884868B29D3BD2A2
    DecodedMSID: 843E4EBAE9000F3AC8AA000000
    EncodedFAID: D239BC620FC81F56AD88A5F9
    Erasing address:
    >> 01380000 : 013AFFFF
    Erasing Done
    Flashing ImageFile
    Write Time Elapse : 00:00:01
    First Byte OK
    Second Byte OK
    BB_RESTART : 07 FF
    Time Elapse : 00:02:02
    Waiting For Phone to go Online...
    5, 4, 3, 2, 1...
    ERROR : PHONE READ INFO FAILED
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    flash lại cái lun coi sao
    Mar 2012
    cúng vậy bác ak. nhưng máy vấn dùng bt
    Thành viên tích cực khanhmobile87's Avatar
    thạch hà-hà tĩnh
    bạn che một chân cuối cùng phía chân phone của cáp ốp lưng là ok ngay
  5. ( khanhmobile87 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    mrtranquang1993 (29-12-2012)
    che chân vpp lại xem thế nào
  7. ( Trường_Mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  8. #6
    Mar 2012
    vâng để em thử coi sao.
  9. #7
    May 2012
    máy không viết file được thôi chứ đâu báo lỗi nạp file nên sài bình thường phải rồi.thử làm như máy anh trên xem có ok không
  10. #8
    atf đôi khi bị như thế là bình thường bác à mang qua box khác là ok thôi
  11. #9
    Jun 2012
    dòng này che chân vpp lai rồi flash lai xem sau ban
  12. #10
    Thành viên tích cực chanhtl's Avatar
    Jun 2011
    ĐỨC HÒA LONG AN
    máy dòng đời cũ này chiến tốt nhất vẫn là nbox các bác ạ !
    thử nhiều con rùi chạy mx và mt jaf... báo lỗi từa lưa và ko factory đc nửa bỏ qua nbox chắc như bắp
    SẴN SÀNG HỌC HỎI-SẴN SÀNG CHIA SẼ
  1. 1208 can giup
    By manhhong89 in forum DCT4 - WD2
    Bài viết cuối: 01-03-2012, 11:54
  2. 1208 xin giup
    By danonglathe229 in forum DCT4 - WD2
    Bài viết cuối: 19-12-2010, 20:24
  3. 1208 can giup gap
    By tronghuu_97 in forum DCT4 - WD2
    Bài viết cuối: 07-12-2009, 18:35
