Log của em nó. Tình trạng máy giờ mở lên hỏi mở máy không cần mở sim nhấn ok là tắt máy. Nếu bỏ sim thì lên nokia rồi trắng tắt máy
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 2], SN: C0855BC7
Using device: USB Phonet and HTI, FW ver: 00.50, SN: 000162C3
Connection status: OHCI:HUB::USB 1.10 (Full-speed)
Driver: nmwcdnsuc, ver: 7.1.32.75
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14214(25-10-2012)
Waiting for USB ROM device ...
Device synchronized.
CPU: XGOLD 213
Sending EBL Loader...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.37
EBL version: Quantum_Bootloader_10.37_M1S1
Protocol version suggested by phone: 3
Set baud rate to: 6.50 Mbit/s
Flash ID: 00EC 3012 - 23280002 [Samsung ]
CFI information:
Flash settings: 0/1024, size: 0x04000000
1 Block regions:
512 x 0x00020000 = 0x04000000
EBL ready !
Original IMEI:
RPL backup already exist (C:\mobileEx\3.5\data\backup\XGOLD__back.RPL)
Processing file: rm694__10.91.mcusw
Downloading item CODE:rm694__10.91.mcusw_ebl_psi.fls, num block: 4, size: 26.25 MB
Erasing area 0x40000000-0x4001FFFE ...OK
Programming completed in 0.484 s
Erasing area 0x40040000-0x4005FFFE ...OK
Programming completed in 0.828 s
Erasing area 0x40060000-0x4015FFFE ...OK
Programming completed in 2.062 s
Erasing area 0x40280000-0x41B7FFFE ...OK
Programming completed in 45.953 s
Checksum verified (0x27E3)
Processing file: rm694__10.91.ppm_v
Downloading item CUSTackage_v.ppm_ebl_psi.fls, num block: 1, size: 5.51 MB
Erasing area 0x41C00000-0x42181C72 ...OK
Programming completed in 9.141 s
Checksum verified (0x76E8)
Processing file: rm694__10.91.image_v_059D1W0
Downloading item CUSTackage_v_059D1W0.image.fls, num block: 1, size: 14.25 MB
Erasing area 0x42300000-0x43E1FFFE ...OK
Programming completed in 26.000 s
Checksum verified (0x2887)
Total time for flashing process(boot+erase+write) was 4 min 36.140 s
Waiting for USB device removal ...
Phone not found, retrying ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1885C092
Market items is empty, please select the correct products path !
			 Xin ae giúp dùm con X2-02 flash không đồng bộ được
 Được post bởi duykhanh_gsm
