    Thành viên tích cực tony.haokiet's Avatar
    Jan 2010
    Mặc định x6 trang treo nokia
    xin chào anh em . mình có 1 cây x6 như tiêu đề trên , mình đã đưa vào mxbox thì báo như thê này
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C08747B1
    Using device: USB ROM and HTI, FW ver: 00.24, SN: 00015137
    Connection status: EHCI:HUB::USB 2.00 (High-speed)
    Driver: nmwcdnsuc, ver: 7.1.32.75
    Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14214(25-10-2012)
    Processing MCU file: RM-559_40.0.002_prd.core.C00
    [BB5,XSR 1.6] size: 112.91 MB
    Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103
    Waiting for USB ROM device ...
    CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15]
    CMT EM0 ID: 00000296
    CMT EM1 ID: 00000B22
    CMT PUBLIC ID: 17600108398E00526B3FFF40ECCF6FF309656610
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371
    CMT ROM ID: 4B9B75103E691FF8
    Loading CMT secondary boot code
    SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80
    Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
    eBB5ProtocolType: NEW
    Secondary boot loaded.
    Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 00EC 0058 - 0000 0121 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.5
    Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F
    Update server code loaded.
    FUR: Adding Asic CMT as client OK.
    CERT backup skipped.
    Storing certificate [NPC, CCC, HWC, R&D] ...OK
    Partitioning....
    Partitioning complete
    Erase size: 182.94 MB
    CMT FLASH,MuxOneNAND area [00040000-00082FFF]
    CMT FLASH,MuxOneNAND area [00083400-003FFFFF]
    CMT FLASH,MuxOneNAND area [00400000-007FFFFF]
    CMT FLASH,MuxOneNAND area [00800000-00D5FFFF]
    CMT FLASH,MuxOneNAND area [00D60000-0B71FFFF]
    Formating partition ...
    Flash programming ...
    CMT ADA block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT RAP3NAND block sent
    CMT PASUBTOC block sent
    Selecting first CMT PAPUB block with matching RootKey.
    CMT PAPUBKEYS: E00DA77B [RAP Certificate 191 v.1] sent
    CMT SOS*UPDAPP block sent
    CMT SOS*ENO block sent
    CMT SOS*DSP0 block sent
    CMT SOS*ISASW block sent
    CMT SOS+CORE block sent
    CMT SOS+ROFS1 block sent
    Programming completed in 1 min 44.796 s
    Processing PPM file: RM-559_40.0.002_prd.rofs2.V20
    [BB5,XSR 1.6] size: 18.01 MB
    Erase size: 41.87 MB
    CMT FLASH,MuxOneNAND area [07920000-0A2FFFFF]
    CMT SOS+ROFS2 block sent
    Programming completed in 17.078 s
    Processing PPM file: RM-559_40.0.002_C03_prd.rofs3.fpsx
    [BB5,XSR 1.6] size: 5.31 MB
    Erase size: 20.12 MB
    CMT FLASH,MuxOneNAND area [0A300000-0B71FFFF]
    CMT SOS+ROFS3 block sent
    Programming completed in 5.078 s
    Processing CNT file: RM-559_32.0.002_001_000_U001.uda.fpsx
    [BB5,XSR 1.6] size: 7.81 MB
    Erase size: 312.37 MB
    CMT FLASH,MuxOneNAND area [0B720000-1EF7FFFF]
    Programming completed in 11.031 s
    Total time for flashing process(boot+erase+write) was 2 min 30.578 s
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...OK
    Device connected: nmwcdc\Nokia X6-00 USB Phonet, PORT_ID: 9125605
    Verifying communication to device OK.
    Phone type: RM-559 (Nokia X6-00)
    SW version: V ICPR72_11w16.1 28-07-11 RM-559 (c) Nokia
    ApeCoreSw: V 40.0.002
    Imei plain: 35200604555237-0
    Product code: 0589429
    Battery voltage: 3747 mV, current: 307 mA
    Language Pack:
    - not available.
    SIMLOCK seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 352006045552370
    Version: SIMLOCK SERVER
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    FULL FACTORY... OK
    Completed in 1.219 s
    FULL FACTORY... OK
    USER DATA... OK
    LEAVE FACTORY... OK
    SERVICE CENTER... OK
    SOFTWARE UPGRADE... OK
    PRODUCTION TUNING... OK
    Reset User Code (to default:12345) ... OK
    Completed in 1.297 s
    nhờ anh em giúp đỡ thanks ae
    Trắng nhưng mà còn nghe gọi được không anh => máy có bị té ao,hay rớt đất gì không => anh cho thêm tí thông tin nửa đi => để ae có thể băt bệnh mau hơn !!!
    Thành viên chính thức ho nguyen gia huy's Avatar
    thế nạp lại pm cho nó chưa vậy ? chạy xong xem đã
    gia huy ha noi_________________________________---hhhhhhhhhhhhhhhhhhhhhhh_______________n
    Trích Được post bởi NKMobile™ Xem bài viết
    Trắng treo nhưng mà còn nghe gọi được không anh => máy có bị té ao,hay rớt đất gì không => anh cho thêm tí thông tin nửa đi => để ae có thể băt bệnh mau hơn !!!
    trắng treo mà còn nghe ghọi gì nữa vip
    Trích Được post bởi ho nguyen gia huy Xem bài viết
    Chẳng lẻ mở nguồn lên cái màn hình trắng đứng yên một chổ không thấy gì => thế gọi là trắng treo àh anh => ở đây em đề cặp tới cái chuyện là nếu cái máy còn nghe gọi được,thì có thể liên quan tới cái đường LCD hoặc có thể là cái màn hình bị cà tưng gì đấy => như vậy thì chúng ta khỏi cần lăn tăn chạy chương trình chi cho mệt => còn chuyện anh ấy flash cho máy rồi ,hay là chưa flash thì em không biết => nhưng hiện tại cái log của anh chủ thớt ở trên đả ok toàn bộ => nên có thể là do lổi HW rất cao => sau này anh đọc cho kỉ bài viết của người khác một chút,rồi hảy bình loạn nhé anh trai !
    V.I.P LOC_PHAT_ĐAT's Avatar
    Jan 2010
    trước hết làm cho lên mh đã..còn treo nữa thính tiếp.
    Jan 2010
    lên nokia tắc lên tắc rồi báo phone startup failed contact the retailer
    em hiểu rùi các anh ui . thay cặp cho chắc
  1. vấn đề n70 trang treo
    By aishikeru in forum BB5
    Bài viết cuối: 22-04-2012, 10:47
  2. c3-00 trang man treo
    By thanhhung48 in forum BB5
    Bài viết cuối: 20-08-2011, 12:34
  3. Nokia N70 bi trang treo heip!
    By anh thuan in forum DCT4 - WD2
    Bài viết cuối: 23-11-2009, 20:44
  4. N70 rớt nước treo trang MH
    By thanhhai1 in forum BB5
    Bài viết cuối: 28-02-2008, 03:22
