ae em lock infor giùm,máy ban đầu hay tắt nguồn mình chạy lại thấy ok máy báo local mode tính là ok ùi ko ngờ bỏ binvao2 mở nguồn máy báo contac ae đã làm qua chỉ mình với
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 6.00
30-09-09
RH-99
(c) NMP
HW version: 2502
PCI version:
UEM version: 1328
UPP version: 8850
RFIC version: 0700
DSP version: ICPR62_08w31_UPP
LCD version: WIN:MYKS:04
ST7507
PPM version: V 6.00
30-09-09
RH-99
(c) NMP
MR
ADSP SW version: V 6.00\n30-09-09\nRH-99\n(c) NMP\nmr
Production serial number: INL375405
Product code: 0546971
Module code: 0203402
Basic production code: 0571402
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 353105029168762
IMEI spare to net: 3A 35 01 05 92 61 78 06
IMEI SV to net: 33 35 01 05 92 61 78 76 F2
Master Code: 6512720374
Phone type: RH-99, Software version: 6.00, Language Pack: MR
User code: "!!
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-99.ini
Setting local mode...
Reading product code...
Product Code: 0546971
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RH-99\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_06.000
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_06.00mr
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai6.00mr
Done!
Reading...
30-09-09
RH-99
(c) NMP
HW version: 2502
PCI version:
UEM version: 1328
UPP version: 8850
RFIC version: 0700
ST7507
PPM version: V 6.00
30-09-09
RH-99
(c) NMP
MR
Flash code:
Order number:
Long production SN:
ATO:
Default SN type:
User code: "!!
Done!
			 1200 contac cần ae giúp
