con c3_00 mất nguồn em làm lên nguồn rồi giờ lắp pin bật nguồn thi lên trắng màn roi tắt nguồn luôn em bỏ buck check thì lock em no dây ae ai làm qua chỉ giúp em cái
Number of Image Files: 3
Processing Image File :
rm614__07.20.mcusw
CMT Type : BB5
CMT Algorithm : XSR 1.6
Secondary Sending Speed : 650000Hz
Algorithm Sending Speed : 6500000Hz
Program Sending Speed : 6500000Hz
Message Reading Speed : 98000Hz
Number of Blocks : 528
Entry Point: 0x01F2
Page Format : -1
MAX PAGE : 0x0000E000
rm614__07.20.ppm_v
CMT Type : BB5
Number of Blocks : 125
Entry Point: 0x0113
Page Format : -1
rm614__07.20.image_v_0598884
CMT Type : BB5
Number of Blocks : 228
Entry Point: 0x0147
Page Format : -1
AUTO SELECTED DEAD USB FLASHING...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
READING BOOTROM
Number of Sub Blocks 6 (0x06)
1 SYSTEM_ASIC_ID 01
Block Length : 17 (11)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000000
ID DWORD 1 : 00000000
ID DWORD 2 : 22000509
ID DWORD 3 : 200C0000
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 00005361
3 PUBLIC_ID 12
Block Length : 21 (15)
ID DWORD 1 : 008C3B29
ID DWORD 2 : B6522DC6
ID DWORD 3 : 5F8C2B8F
ID DWORD 4 : 8A312D22
4 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
5 ROOT_KEY_HASH 14
Hash : 1B 0D 74 C5 32 CA 1C 61 33 94 0C 74 0E 8C 78 6E
6 ROM_ID 15
Block Length : 9 (09)
CRC 0 : DE56D582
CRC 1 : BDDE7A3A
CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\BCM21351_u sb2nd.fg
Secondary Loader Sent....
MessageID : C1
SubBlocks : 06
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : RAM 05
Device Index : 00
Manufacturer Code : 0000 -> Flash
Device ID : 0000 -> Type not in database
Extended/Fixed ID : 0000
Revision ID : 0000
2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Type : NOR 00
Device Index : 00
Revision ID : 0000
4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Index : 01
Manufacturer Code : 0010 ->
Device ID : 0011 -> Type not in database
Revision ID : 0000
5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MuxOneNAND 03
Device Index : 00
Manufacturer Code : 00EC ->
Device ID : 0030 -> Type not in database
Revision ID : 0321
6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
Block Length : 09
Data :
Flash Descriptor
Device ID : 0030
Revision ID : 0000
Size : 08000000 (128 MB)
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\BCM21351_X SR16_usbalg.fg
Algorithm Loader Sent...
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok
START READING RPL DATA
IMEI: 353760046283828
Reading : NPC... OK!
Reading : CCC... OK!
Reading : HWC... OK!
Reading : R&D... OK!
RPL Backup was Successful...
Plain RPL saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\353760046283828\3537600462838 28_30502.rpl
Pabub KEY Request
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
697F747788AD72E77DB3BC8DFEC0C28DA22F16D8
ImagePath: D:\flash nokia\c3_00\
ImageFilename: rm614__07.20.mcusw
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
Certificate 5
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 4E 44 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 B6
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
Partition Blocks : 1
1 PARTITION_INFO_BB5
BB ASIC Index : 0x00 CMT
Device Type : 0x03 MuxOneNAND
Device Index : 0x00
Partition Version : 00010000
Spare : FFFFFFFF
Num Partitions : 00000004
Partition 1
Attribute : 00000002 RO
Start Address : 00020000
Partition 2
ID : 00000008 FILESYSTEM
Attribute : 00000001 RW
Start Address : 02A00000
Partition 3
Start Address : 07540000
Partition 4
Start Address : 07B40000
PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 000200020000025E0000000000080000000102A0000004B400 000000000A0000000107540000006000000000000B00000001 07B40000001800000D
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength : 0x90 (144)
ERASE Blocks : 0x03 (3)
0 ERASE_AREA_BB5 0x12
Block Length : 0x2B (43)
Device Index : 0x00
0 : 00000000-0001FFFF
1 : 00020000-000203FF
2 : 00060000-012FFFFF
3 : 01300000-01DFFFFF
4 : 02600000-029FFFFF
1 FORMAT_PARTITION_BB5 0x19
Block Length : 0x2F (47)
Device Index : 0x00
Format Info ID : 0x02000000
Format Info : 000000000000000A0000000100000002000000640000000200 000002000000010000000000000000
2 FORMAT_PARTITION_BB5 0x19
Device Index : 0x00
Format Info : 000000000000000B0000000000000002000000640000000200 000002000000010000000000000000
ERASE_REQUEST_BB5 : 5005120B000300000000000001FFFF120B0003000002000000 0203FF120B00030000060000012FFFFF120B00030001300000 01DFFFFF120B00030002600000029FFFFF11
FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A000000010000 00020000006400000002000000020000000100000000000000 003B
FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000B000000000000 00020000006400000002000000020000000100000000000000 003B
Successfully Erased...
Total blocks to write : 528
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : ADA
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : RAP3NAND
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS
>> CMT Rootkey Hash CERT : UPDAPP
>> CMT Rootkey Hash CERT : MCUSW
>> CMT Rootkey Hash CERT : MCUSW1
>> CMT Rootkey Hash CERT : GENIO_INIT
>> CMT Rootkey Hash CERT : ISA+DYNSW
ImageFilename: rm614__07.20.ppm_v
Partition Info
Device Index : 0x00
Spare : FFFFFFFF
Partition 1
Partition 2
Partition 3
Partition 4
StartErase_DCT5...
BlockLength : 0x0E (14)
ERASE Blocks : 0x01 (1)
Block Length : 0x0B (11)
Device Index : 0x00
0 : 01E00000-025FFFFF
ERASE_REQUEST_BB5 : 5001120B00030001E00000025FFFFF9E
Total blocks to write : 125
ImageFilename: rm614__07.20.image_v_0598884
Partition Info
Device Index : 0x00
Spare : FFFFFFFF
Partition 1
Partition 2
Partition 3
Partition 4
ProcessPartitionInfo_DCT5 : Error
Flashing Failed....
Booting/Flashing Failed...
Please Try Again...
