Kết quả 1 tới 10 của 12
    Thành viên tích cực ThùyThương_GSM's Avatar
    May 2011
    Mặc định c2-01 rm 721 contacsevic cần dúp
    máy khách mang tới bảo rơi nước em đã vệ sinh sạch sẽ sấy khô.bật nguồn hiện nokia rồi contacsevic đã chạy lại phần mềm thay ic nguồn vẫn not oki đây là log flass của em nó
    ATF
    Number of Image Files: 3
    Processing Image File :
    rm721__11.20.mcusw
    CMT Type : BB5
    CMT Algorithm : XSR 1.6
    Secondary Sending Speed : 3250000Hz
    Algorithm Sending Speed : 6500000Hz
    Program Sending Speed : 19500000Hz
    Message Reading Speed : 98000Hz
    Number of Blocks : 158
    Entry Point: 0x0259
    Page Format : -1
    MAX PAGE : 0x00040000
    rm721__11.20.ppm_v
    CMT Type : BB5
    Number of Blocks : 30
    Entry Point: 0x011D
    Page Format : -1
    rm721__11.20.image_v_059G1J8_006
    CMT Type : BB5
    Number of Blocks : 76
    Entry Point: 0x0154
    Page Format : -1
    AUTO SELECTED DEAD USB FLASHING...
    1. Remove USB and Battery...
    2. Insert USB.
    3. Insert Battery. (Some phones boot automatically)
    4. Please Power on phone shortly...
    AdvanceFBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    READING BOOTROM
    Number of Sub Blocks 7 (0x07)
    1 SYSTEM_ASIC_ID 01
    Block Length : 21 (15)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000001
    ID DWORD 1 : 00000226
    ID DWORD 2 : 00000001
    ID DWORD 3 : 020C1921
    ID DWORD 4 : 02044100
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00001040
    3 EM_ASIC_ID 02
    ID DWORD 0 : 00001030
    4 PUBLIC_ID 12
    ID DWORD 0 : 37D00107
    ID DWORD 1 : 42241449
    ID DWORD 2 : C6DD2896
    ID DWORD 3 : 076CA145
    ID DWORD 4 : 9F253E02
    5 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    Block Length : 17 (11)
    Hash : 7B 04 54 00 E1 75 20 22 F9 EB 80 B0 DE A9 C6 5D
    7 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : 67E82268
    CRC 1 : F29CEA60
    CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAP3Gv40_2 nd.fg
    Secondary Loader Sent....
    MessageID : C1
    SubBlocks : 06
    Block Length : 0B
    BB ASIC Index : CMT 00
    Device Type : RAM 05
    Device Index : 00
    Manufacturer Code : 0000 -> Flash
    Device ID : 0000 -> Type not in database
    Extended/Fixed ID : 0000
    Revision ID : 0000
    2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MMC 04
    Device Index : 00
    Revision ID : 0000
    Block Length : 0B
    Device Type : NOR 00
    Device Index : 00
    Revision ID : 0000
    4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Index : 01
    Manufacturer Code : 0000 -> SPANSION
    Device ID : 0001 -> Type not in database
    Revision ID : 0000
    5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MuxOneNAND 03
    Device Index : 00
    Manufacturer Code : 00EC ->
    Device ID : 0030 -> Type not in database
    Revision ID : 0431
    6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
    Block Length : 09
    Data :
    Flash Descriptor
    Device ID : 0030
    Revision ID : 0000
    Size : 08000000 (128 MB)
    VPP Info : 0000
    Erase10s : 1E
    Block1s : 32
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAP3Gv40_X SR17_alg.fg
    Algorithm Loader Sent...
    FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
    FUR control Ok
    START READING RPL DATA
    IMEI: 354107052895872
    Reading : NPC... OK!
    Reading : CCC... OK!
    Reading : HWC... OK!
    Reading : R&D... OK!
    RPL Backup was Successful...
    Plain RPL saved to:
    C:\AdvanceBox Turbo Flasher\Nokia\Backup\354107052895872\3541070528958 72_34638.rpl
    Pabub KEY Request
    PHONE_INFO_RESPONSE_BB5
    PAPUB_KEYS_HASH_RESP_BB5 2A
    BB Asic Index : 00
    CMT PAPUBKEYS HASH:
    8443ECD57D2EDADDAADBAD248F1B3B559E14D184
    ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-721\
    ImageFilename: rm721__11.20.mcusw
    Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
    Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
    Certificate 1
    ASIC Index : CMT 0
    Certificate 2
    ASIC Index : CMT 0
    Certificate 3
    ASIC Index : CMT 0
    Certificate 4
    ASIC Index : CMT 0
    STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
    STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
    ProcessPartitionInfo_DCT5...
    Partition Info
    Partition Blocks : 1
    1 PARTITION_INFO_BB5
    BB ASIC Index : 0x00 CMT
    Device Type : 0x03 MuxOneNAND
    Device Index : 0x00
    Partition Version : 00010000
    Spare : FFFFFFFF
    Num Partitions : 00000004
    Partition 1
    Attribute : 00000002 RO
    Start Address : 000A0000
    Partition 2
    ID : 00000008 FILESYSTEM
    Attribute : 00000001 RW
    Start Address : 02CC0000
    Partition 3
    Start Address : 077C0000
    Partition 4
    Start Address : 07B40000
    PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 0002000A000002720000000000080000000102CC000004B000 000000000A00000001077C0000003800000000000B00000001 07B4000000180000C9
    PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
    ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
    StartErase_DCT5...
    BlockLength : 0xE1 (225)
    ERASE Blocks : 0x04 (4)
    0 ERASE_AREA_BB5 0x12
    Block Length : 0x4B (75)
    Device Index : 0x00
    0 : 00020000-000203FF
    1 : 00060000-0009FFFF
    2 : 000A0000-0025FFFF
    3 : 003E0000-005DFFFF
    4 : 005E0000-010DFFFF
    5 : 01EC0000-01EDFFFF
    6 : 027C0000-02CBFFFF
    7 : 077C0000-07B3FFFF
    8 : 010E0000-01EBFFFF
    1 FORMAT_PARTITION_BB5 0x19
    Block Length : 0x2F (47)
    Device Index : 0x00
    Format Info ID : 0x02000000
    Format Info : 00000000000000080000000000000002000000640000000200 000002000000010000000000000000
    2 FORMAT_PARTITION_BB5 0x19
    Device Index : 0x00
    Format Info : 000000000000000A0000000100000002000000640000000200 000002000000010000000000000000
    3 FORMAT_PARTITION_BB5 0x19
    Device Index : 0x00
    Format Info : 000000000000000B0000000000000002000000640000000200 000002000000010000000000000000
    ERASE_REQUEST_BB5 : 5009120B00030000020000000203FF120B0003000006000000 09FFFF120B000300000A00000025FFFF120B000300003E0000 005DFFFF120B000300005E0000010DFFFF120B00030001EC00 0001EDFFFF120B000300027C000002CBFFFF120B000300077C 000007B3FFFF120B000300010E000001EBFFFF3D
    FORMAT_REQUEST_BB5 : 5001192F000300000000020000000000000008000000000000 00020000006400000002000000020000000100000000000000 003E
    FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A000000010000 00020000006400000002000000020000000100000000000000 003B
    FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000B000000000000 00020000006400000002000000020000000100000000000000 003B
    Successfully Erased...
    Total blocks to write : 158
    >> CMT Rootkey Hash CERT : ADA
    >> CMT Rootkey Hash CERT : KEYS
    >> CMT Rootkey Hash CERT : PRIMAPP
    >> CMT Rootkey Hash CERT : PASUBTOC
    >> CMT Rootkey Hash CERT : PAPUBKEYS
    >> CMT Rootkey Hash CERT : RAP3NAND
    >> CMT Rootkey Hash CERT : UPDAPP
    >> CMT Rootkey Hash CERT : DSP0
    >> CMT Rootkey Hash CERT : MCUSW
    >> CMT Rootkey Hash CERT : MCUSW1
    >> CMT Rootkey Hash CERT : GENIO_INIT
    >> CMT Rootkey Hash CERT : ISA+DYNSW
    ImageFilename: rm721__11.20.ppm_v
    Partition Info
    Device Index : 0x00
    Spare : FFFFFFFF
    Partition 1
    Partition 2
    Partition 3
    Partition 4
    StartErase_DCT5...
    BlockLength : 0x0E (14)
    ERASE Blocks : 0x01 (1)
    Block Length : 0x0B (11)
    Device Index : 0x00
    0 : 01EE0000-027BFFFF
    ERASE_REQUEST_BB5 : 5001120B00030001EE0000027BFFFF74
    Total blocks to write : 30
    ImageFilename: rm721__11.20.image_v_059G1J8_006
    Partition Info
    Device Index : 0x00
    Spare : FFFFFFFF
    Partition 1
    Partition 2
    Partition 3
    Partition 4
    StartErase_DCT5...
    BlockLength : 0x3F (63)
    ERASE Blocks : 0x02 (2)
    Device Index : 0x00
    0 : 02CC0000-077BFFFF
    Device Index : 0x00
    ERASE_REQUEST_BB5 : 5001120B00030002CC0000077BFFFF90
    Total blocks to write : 76
    ContinueFlash_DCT5 Complete
    Continue Flash Complete : : No Error - 0 (0x00)
    STATUS_REQUEST_BB5...
    1 Sub Block ID : 15 STATUS_NAND_OK_BB5
    Block Length : 0F
    BB ASIC Index : 00
    Device Type : 05
    Device Type : 0F
    Num Bad Blocks : 00000000
    Additional Bad : 00000000
    Correctable ECC : 00000000
    FlashInfo.RestartMode : 2
    Flashing Done...
    Total Flashing Time (Erase + Flashing) : 00:11:04
    (Booting time is NOT Included)
    Waiting for Phone to Start-Up..(Max 150 seconds)
    SW: V 11.20 27-10-11 RM-721 (c) Nokia
    CONFIG KEY : 0000000000000000
    PROVIDER KEY : 2440700000000000
    NETWORK NAME : Nokia Default;Finland
    LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
    SIMLOCK TABLE :
    Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
    SIMLOCK STATE : Not Locked
    SIMLOCK_TEST : PASSED
    SECURITY_TEST : PASSED
    SUPER_DONGLE_TEST : PASSED
    SECURITY_CODE : 12345
    SL3 Phone detected
    * Firmware Version Downgrade will KILL PHONE !!!
    * Manual Full Erase WILL KILL PHONE!!!
    * Simlocks are in PM 120 Only...
    * PM 308 is Write Protected...
    FACTORY SET TO : Full Factory Set
    OK
    FACTORY SET TO : User Data
    OK
    FACTORY SET TO : Leave Factory
    OK
    FACTORY SET TO : Service Center
    OK
    FACTORY SET TO : Software Upgrade
    OK
    FACTORY SET TO : Production Tune
    OK
    RESET LIFE TIMER TO : 0000:00
    OK
    PHOENIX
    Flashing started
    Creating product data items list
    Product data items list created
    Backup not required
    Flashing phone
    Initializing
    Scanning image files...
    Waiting for USB device...
    Loading secondary boot code: 15040 bytes
    Secondary boot loaded
    BB Asic Index is: 00
    Asic ID is: 000000010000022600000001020C192102044100
    EM Asic ID is: 00001040
    EM Asic ID is: 00001030
    Public ID is: 37D0010742241449C6DD2896076CA1459F253E02
    Asic Mode ID: 00
    Hash: 7B045400E1752022F9EB80B0DEA9C65D
    ROM ID: 67E82268F29CEA60
    Device type is: 05
    Device Index is: 00
    Manufacturer code: 0000
    Device ID: 0000
    Extended device ID: 0000
    Revision ID: 0000
    Device type is: 04
    Device Index is: 00
    Manufacturer code: FFFF
    Device ID: 0000
    Revision ID: 0000
    Device type is: 00
    Device Index is: 00
    Device ID: 0000
    Revision ID: 0000
    Device type is: 00
    Device Index is: 01
    Device ID: 0001
    Revision ID: 0000
    Device type is: 03
    Device Index is: 00
    Manufacturer code: 00EC
    Device ID: 0030
    Revision ID: 0431
    Loading update server code: 596946 bytes
    Update server loaded
    Asic CMT: Start programming 56485 KB...
    Asic CMT: Programming data sent: 0%
    Asic CMT: Programming data sent: 10%
    Asic CMT: Programming data sent: 20%
    Asic CMT: Programming data sent: 30%
    Asic CMT: Programming data sent: 40%
    Asic CMT: Programming data sent: 50%
    Asic CMT: Programming data sent: 60%
    Asic CMT: Programming data sent: 70%
    Asic CMT: Programming data sent: 80%
    Asic CMT: Programming data sent: 90%
    Asic CMT: Programming data sent: 100%
    Programming complete
    Asic CMT: Verifying communication to device...
    Phone flashing completed. Waiting for phone to boot up
    Bootup successful
    Verifying communication to product (before flash finalizing)
    Communication verified
    Product code changed
    Doing factorysets
    Factorysets complete
    Reading Dynamic Camera Configuration ID 1
    Updating configuration of camera with ID 1
    Dynamic Camera Configuration updating failed: 0x84167501 - AudioVisual: No configuration file matching the camera name string NI00IIIIRR030C219803 was found.
    Loading default data to phone
    Getting Data Package
    Reading product state
    Starting backup/restore sub-procedure: data item pre-delay
    data item pre-delay
    data item pre-delay
    Sub-procedure completed: Succeeded., result code: 0
    Starting to backup/restore data item: ProductProfile, version: 1.1
    Data Item backup/restore completed: Succeeded., result code: 0
    Starting backup/restore sub-procedure: data item post-delay
    data item pre-delay
    data item pre-delay
    Starting to backup/restore data item: ISSVariantActivator, version: 1.0
    data item pre-delay
    data item pre-delay
    Starting to backup/restore data item: DateTimeSettings, version: 1.0
    Backup/restore result: 0 out of 3 items were not backed up
    Default data loading complete
    Stopping all operations, returning phone to default mode
    All operations completed
    Firmware updating succeeded.
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    lock thấy ok mà , cho nhựa thông khò vào gầm cặp xem thế nào
  3. ( duykhanh_gsm ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    ThùyThương_GSM (07-01-2013)
    May 2011
    đã ray lại 2 tầng rồi anh.còn phương pháp nào ko vậy anh
    Trích Được post bởi ThùyThương_GSM Xem bài viết
    xác định con nguồn ok thì tháo cặp ra làm chân đóng lại đi chờ gì nữa !
  6. ( hà_vũng tàu ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    sáy kỉ không được thì làm chân lại đi bác
  8. ( mobingoc ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  9. #6
    đóng lại con nguồn đi xem thế nào
  10. ( Trường_Mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  11. #7
    May 2011
    Trích Được post bởi DoanhTruong_090 Xem bài viết
    em đã thay luồn nguồn rồi anh
  12. #8
    May 2011
    upp cho AE vô dúp
  13. #9
    Thành viên tích cực QuocDat_mobile's Avatar
    Oct 2011
    Đà Nẵng
    làm nhà lầu đi bạn mình làm nguồn không xong múc luôn nhà lầu ok rùi
    zalo: 0905 990078
    Tel;0905990078.0979233646
  14. ( QuocDat_mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    ThùyThương_GSM (08-01-2013)
  15. #10
    May 2011
    thank anh để em thử
  1. 1200 contacsevic
    By hoangphiz3 in forum DCT4 - WD2
    Trả lời: 16
    Bài viết cuối: 23-03-2012, 10:04
  2. 1200 contacsevic
    Bài viết cuối: 13-03-2012, 17:36
  3. 110i bao contacsevic
    By xuananhmobile1992 in forum DCT4 - WD2
    Bài viết cuối: 12-09-2011, 21:50
  4. N 70 contacsevic
    By hoangsuu@mobile in forum BB5
    Bài viết cuối: 10-06-2008, 20:40
  5. N 70 contacsevic
    By hoangsuu@mobile in forum DCT4 - WD2
    Bài viết cuối: 10-06-2008, 11:38
