Kết quả 1 tới 3 của 3
    Thành viên tích cực 99999's Avatar
    Dec 2011
    Mặc định Xem log 1280 contac
    MÁY LỊCH SỬ RỚT NƯỚC VỆ SINH XÀI OK. BÂY GIỜ BỊ CONTAC , ĐÃ VỆ SINH KỈ , ĐÂY LÀ LOG FLASH NHỜ AE GIÚP
    Backup saved to "C:\mobileEx\3.5\data\backup\XGOLD_RM-647_643655850099176F_IMEI.back"
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C0855D93
    Using device: HTI, FW ver: 00.50, SN: 0000B3E9
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14214(25-10-2012)
    Device synchronized.
    CPU: XGOLD 110
    Using embedded SBL from MCU.
    Sending EBL Loader ...OK
    Sending EBL ...OK
    Getting EBL Version ...
    Boot mode: 0xCC
    EBL version major/minor: 10.19
    EBL version: Default_RAM_Bootloader
    Set baud rate to: 921.60 Kbit/s
    Flash ID: 0020 88C0 - 23280003 [ST M58MWR064FU,64 Mbits]
    CFI information:
    Flash settings: 0/1, size: 0x00800000
    2 Block regions:
    127 x 0x00010000 = 0x007F0000
    8 x 0x00002000 = 0x00010000
    EBL ready !
    Processing file: rm647_006.510
    Downloading item CODE:hw_b2_rm647_r06.510.fls, num block: 3, size: 4.04 MB
    Erasing area 0x00800000-0x00A0FFFE ...OK
    Programming completed in 37.969 s
    Erasing area 0x00C60000-0x00E5933E ...OK
    Programming completed in 36.813 s
    Erasing area 0x00FFC000-0x00FFC03E ...OK
    Programming completed in 0.156 s
    Error reading checksum!
    Processing file: rm647_006.51mr
    Downloading item CUST:hw_b2_rm647_006.51mr.fls, num block: 1, size: 1.10 MB
    Erasing area 0x00210000-0x003288BE ...OK
    Programming completed in 17.984 s
    Checksum mismatch: Phone calculated 0x0033, software calculated 0x1507
    Processing file: rm6470_nai06.51mr
    Downloading item CUST:hw_b2_rm6470_nai06.51mr.fls, num block: 1, size: 305.83 KB
    Erasing area 0x00EB0000-0x00EFBA3E ...OK
    Programming completed in 4.953 s
    Checksum mismatch: Phone calculated 0x00F0, software calculated 0xA1D0
    Total time for flashing process(boot+erase+write) was 2 min 56.438 s
    Phone type: RM-647
    SW version: V 06.51 13-05-11 RM-647 (c) Nokia
    Imei plain: 35742104218593-1
    Product code: 0592248
    Cellular system: GSM
    ASIC ID: 0x2292, type: 11
    Ppm Id: MR
    Language Pack:
    English,Hindi,Bengali
    Imei net: 35742104218593
    Provider: GSM Test Operator
    Counter: 0/3, 0/10
    CONFIG_DATA: 0010100000000000
    PROFILE_BITS: 0000000000030002
    Dec 2011
    CÒN ĐÂY LOG CHECK
    CPU: XGOLD 110
    Sending EBL ...OK
    Boot mode: 0xCC
    CFI information:
    2 Block regions:
    EBL ready !
    Phone type: RM-647
    Ppm Id: MR
    Language Pack:
    Counter: 0/3, 0/10
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    thay cái mh khác coi sao
  1. 1280 contac
    By Gsmlaocai in forum DCT4 - WD2
    Bài viết cuối: 28-09-2012, 06:35
  2. 1208 contac
    By ngocthanh1202 in forum DCT4 - WD2
    Bài viết cuối: 24-09-2011, 09:16
  3. xem cái log contac
    By CHHONGQUAN in forum DCT4 - WD2
    Bài viết cuối: 26-11-2009, 15:11
  4. sửa lỗi contac 1 số đây bà con
    By sybenlove in forum DCT4 - WD2
    Trả lời: 97
    Bài viết cuối: 07-05-2008, 10:02
  5. n73 contac
    By tienthanh05 in forum BB5
    Bài viết cuối: 13-04-2008, 21:09
