DLL not found...
BB5 Easy Service Tool v1.14.1 (c) Infinity-Box Team Ready
Connect phone on selected interface...
UFS S/N 75444 boot - Ok
Read and Check phone data...
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT ASICID : 000000010000022600010006030C192101033000
CMT EM0 ID : 00000296
CMT EM1 ID : 00000B22
CMT PUB ID : 030002152CB203561BCD87C349EE02904A6150A4
CMT MODE ID : 00
CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT ROM ID : 273F6D55DFAAF68F
CMT : Sending 2nd loader...
Use : RAP3Gv3_2nd.fg
CMT Loader sent, Boot Ok
MCU Configuration
FLASHID : 240000EC , CMT , NOR
CMT Flash ID : 240000EC < UNKNOW [NOT IN BASE]
FLCNT : 00000000000000000000000000000000000000
FLASHID : 0000FFFF , CMT , MMC , EXT
CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok
Sending ALGO....
Use : RAP3Gv3_algo.fg
CMT Algo sent
CMT PAPUB : A22A1DDA660002E56108DB5072A10F8709443FA800
Transmission mode : Dual (Ddr, TX2)
Boot Done!
Init Service mode... Wait...
SimLock status : SimLock Damaged!!!!!
Security status : Security is Ok
SDD Key status : SD Data is Ok
PA_SimLock Version :
PA_SL3 phone detected
Done!
Phone found!
Series 40 Device detected!
read info... - Ok
Selected FlashSettings : FullFlash
Files Set for Flashing :
MCU : rm561__09.98.mcusw
PPM : rm561__09.98.ppm_v
CNT : rm561__09.98.image_v_blac
Check FlashFiles, Please, wait...
-> SWversion check skipped : Manual mode selected
Backup enabled, Will read Certificates now...
CRT308 Backup Created...
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
Sending ALGO....
CMT Algo sent
Boot Done!
CMT : Read NPC certificate...
Cert size : 20480 byte(s)
IMEI : 356240048913737
CMT : Read CCC certificate...
Cert size : 30600 byte(s)
CMT : Read HWC certificate...
CMT : Read VARIANT certificate...
Cert size : 0 byte(s)
Cert Read done!
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
SimLock Data saved...
SimLock Key saved...
WMDRM_PD Data saved...
RPL saved : D:\BEST infinity\Backup\Cert\356240048913737.rpl
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
Sending ALGO....
CMT Algo sent
Boot Done!
Erase : Processing rm561__09.98.mcusw
Found 6 areas to erase, erase group
Asic : CMT , Sub : NOR
CMT , NOR , Area : 0x00000000 - 0x000006BF
CMT , NOR , Area : 0x000006C0 - 0x0001FFFF
CMT , NOR , Area : 0x00040000 - 0x000BFFFF
CMT , NOR , Area : 0x000C0000 - 0x0013FFFF
CMT , NOR , Area : 0x00140000 - 0x0137FFFF
CMT , NOR , Area : 0x01380000 - 0x0151FFFF
Using TimeOut : 5 min ( 300 sec )
Erasing, wait.....
CMT : Group erase Ok
TIME : Erase time : 00:01:21
Write : Processing rm561__09.98.mcusw
CMT: Writing Hash CERT [NOLO]
CMT: Writing Hash CERT [KEYS]
CMT: Writing Hash CERT [PRIMAPP]
CMT: Writing Hash CERT [PASUBTOC]
CMT: Writing Hash CERT [PAPUBKEYS]
CMT: Writing Hash CERT [UPDAPP]
CMT: Writing Hash CERT [DSP0]
CMT: Writing Hash CERT [MCUSW]
Total writen 1247 blocks
TIME : Write time : 00:02:11
Erase : Processing rm561__09.98.ppm_v
Found 1 areas to erase, erase group
CMT , NOR , Area : 0x01520000 - 0x01DBFFFF
Erasing, wait.....
TIME : Erase time : 00:00:29
Write : Processing rm561__09.98.ppm_v
Total writen 442 blocks
TIME : Write time : 00:00:47
Erase : Processing rm561__09.98.image_v_blac
Found 2 areas to erase, erase group
CMT , NOR , Area : 0x01DC0000 - 0x0215FFFF
CMT , NOR , Area : 0x02160000 - 0x03FBFFFF
Erasing, wait.....
TIME : Erase time : 00:02:21
Write : Processing rm561__09.98.image_v_blac
Total writen 872 blocks
TIME : Write time : 00:01:38
Reading Phone Info....
Connected phone - Nokia 2700 classic
Software Info: V 09.98
06-09-10
RM-561
(c) Nokia
IMEI: 356240048913737
Product code: 0581057
Checking...
Read Info Done!
Settings After Flash Defaults...
FullFactorySet...OK!
ProductTuneSet...OK!
SwUpgradeSet...OK!
Product code update...
Checking User Certificates...
Total - 0 certs
Uploading certificates...
Writen 0 certs!
AfterFlash operations done... Reconnect, wait...
Phone found!
read info... - Ok
Phone disconected!
