    Thành viên mới sellykenmobile's Avatar
    Oct 2012
    Mặc định C5-00 Flash Mất Nguồn
    log: buz check nó báo vầy à bác bác nào giúp em với...:dead:
    MXKEY [MxKey Team HTI PLUS Flasher Interface 5], SN: C0841114
    Using device: USB ROM and HTI, FW ver: 00.50, SN: 0100A412
    Connection status: EHCI:HUB:HUB::USB 2.00 (High-speed)
    Driver: NMWCD, ver: 7.1.32.75
    Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
    Waiting for USB ROM device ...
    CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1]
    CMT EM0 ID: 00000C35
    CMT EM1 ID: 00000C30
    CMT PUBLIC ID: 2580020CEE8E0344BA9B3831866ACA7FB4F4A011
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
    CMT ROM ID: E693EF0DAC22615B
    Loading CMT secondary boot code
    SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40
    Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
    eBB5ProtocolType: NEW
    Secondary boot loaded.
    Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT
    Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.6
    Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5
    Update server code loaded.
    Waiting for USB device removal ...
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2AECE95B
    FUR: Adding Asic CMT as client OK.
    CMT PAPUBKEYS HASH: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057
    Selected firmware certificate matched.
    Original Imei: 35379204098346
    Original Product code: 0593549
    Bluetooth ID: D4CBAFE433AA
    SIMLOCK PA identifier:
    [0] PA_SIMLOC30
    Reading CMT HWC (0xD4 bytes).
    Reading CMT R&D (0x0 bytes).
    Warning: Phone did not reboot to normal mode.
    đây là log flash
    Using device: USB Phonet and HTI, FW ver: 00.50, SN: 0100A412
    Driver: nmwcdnsuc, ver: 7.1.32.75
    Processing MCU file: rm645_071.005_prd.core.fpsx
    [BB5,XSR 1.6] size: 96.64 MB
    Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104
    RPL(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35379204098346_CE RT.rpl).
    Storing certificate [NPC, CCC, HWC, R&D] ...OK
    Partitioning....
    Partitioning complete
    Erase size: 170.06 MB
    CMT FLASH,MuxOneNAND area [00020000-0003FFFF]
    CMT FLASH,MuxOneNAND area [00060000-004DFFFF]
    CMT FLASH,MuxOneNAND area [008E0000-0AE3FFFF]
    Formating partition ...
    Flash programming ...
    CMT ADA block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT RAP3NAND block sent
    CMT SOS+PMML block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: D7D05CFC [RAP Certificate v1 249] sent
    CMT GENIO_INIT block sent
    CMT SOS*UPDAPP block sent
    CMT SOS*DSP0 block sent
    CMT LDSP block sent
    CMT SOS*ISASW block sent
    CMT SOS+CORE block sent
    CMT SOS+ROFS1 block sent
    Programming completed in 19.735 s
    Processing PPM file: rm645_071.005_16.01_Vietnam_prd.rofs2.fpsx
    [BB5,XSR 1.6] size: 30.75 MB
    Erase size: 51 MB
    CMT FLASH,MuxOneNAND area [06D40000-0A03FFFF]
    CMT SOS+ROFS2 block sent
    Programming completed in 8.265 s
    Processing PPM file: rm645_071.005_C00.01_DEFAULT_prd.rofs3.fpsx
    [BB5,XSR 1.6] size: 8.01 KB
    Erase size: 14 MB
    CMT FLASH,MuxOneNAND area [0A040000-0AE3FFFF]
    CMT SOS+ROFS3 block sent
    Programming completed in 0.053 s
    Processing CNT file: RM645_ENO_10wk48v0.001.fpsx
    [BB5,XSR 1.6] size: 2.25 MB
    Erase size: 4 MB
    CMT FLASH,MuxOneNAND area [004E0000-008DFFFF]
    CMT SOS*ENO block sent
    Programming completed in 0.590 s
    Processing CNT file: rm645_071.005_U000.000_prd.uda.fpsx
    [BB5,XSR 1.6] size: 1.32 MB
    Erase size: 72 MB
    CMT FLASH,MuxOneNAND area [0AE40000-0F63FFFF]
    Programming completed in 0.886 s
    Total time for flashing process(boot+erase+write) was 41.999 s
    log fbus
    Using device: HTI, FW ver: 00.50, SN: 0100A412
    Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed)
    Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7600.16385
    CMT Data :
    EM0 ID: 00000C35
    EM1 ID: 00000C30
    ASIC MODE ID: 00
    SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 12.14.0 revision: 3.0 size: 0x3B40
    TransmissionMode: DDR&TX2
    Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 12.14.0 revision: 3.0 size: 0xD4569
    Storing certificate [NPC, CCC, HWC, R&D] ...ERROR: Packet Error(0xAA), code 0xA4000002
    Error
    Error while erasing, Result: 00000000000000 , 0
  1. Trả lời: 5
    Bài viết cuối: 15-05-2013, 10:22
  2. e66 mất nguồn do ic flash!
    By NgocTin_Apple in forum BB5
    Bài viết cuối: 16-03-2013, 15:27
  3. Trả lời: 13
  4. 6100 mất nguồn check ok flash mất nguồn
    By kim nhut truong in forum DCT4 - WD2
    Bài viết cuối: 13-12-2009, 21:28
  5. N70 Flash mất nguồn
    By THÔNG THÁI_GSM™ in forum BB5
    Bài viết cuối: 12-10-2009, 16:14
