ddasdasdas
    Nov 2010
    Mặc định VolcanoBox 1.8.8 Boomb/\World's 1st Android read Custom Emmc area/\World's 1st SPD
    Boomb Boomb Boomb
    VolcanoBox 1.8.8
    Presents Some
    World's 1st & Exclusives
    Exclusively Presents :
    MTK andriod Read Infor added system files(file address and length)
    Based on MTK andriod read info
    it can read seperate address and length
    SPD 6530a added new flash 25q128FWPM
    This is world's 1st. i had tested on all other boxes
    Added coolsand usb CT1128CPU read flash
    Normal:
    Adjust coolsand usb Read flash auto identify address and length
    Details:
    What is MTK andriod Read Infor added system files(file address and length) and Based on MTK andriod read info ?
    This is for Experts only !! if you don't know what are you doing then Don't try this @ home or office or @ school
    whenever you got any Chinese mobiles MTK Android, you may need to know it's emmc areas. you can simply click on read info, select read info, select Usb mode, Click on run, when Volcano says Analize for usb, Insert usb cable into phone ( keep in mind some phones need to press & hold any button to put phone into preloader mode & some need to insert usb cable without battery & when software start downloading boot then insert battery), it will 1st read mobile Flash area after that volcano will read it's Emmc area which is same like in OG Tools, there you can see all their Emms parts, Specially Boot, Recovery etc, you will get complete info include Length & Size. also if you use little mind you will also no need to find scatters files so let me show you some examples how you can do it...
    for example i have MTK 6575
    • Click on read info
    • Select built-in-boot 10
    • Tick on usb mode
    • Untick Auto pinfind
    • Click on run
    Code:
    After format or Flash you have to press & hold power button for at least 1.30 mins. Available Ports:COM1 COM4 COM19 COM20 Analysis of USB port,Please insert phone USB cable.
    • when software says this then insert usb cable to mobile
    it will read like this
    Code:
    CPU TYPE:6575 Hardware version:CB00 Software version:E201 Boot downloading complete! EMMC_ID:0x1501004E4A5330304D00000000000000 EMMC_PRODUCT_NAME: SAMSUNG :0x4E4A5330304D EMMC_BOOT1_SIZE: 0x00100000 EMMC_BOOT2_SIZE: 0x00100000 EMMC_PRMB_SIZE: 0x00020000 EMMC_GP1_SIZE: 0x00000000 EMMC_GP2_SIZE: 0x00000000 EMMC_GP3_SIZE: 0x00000000 EMMC_GP4_SIZE: 0x00000000 EMMC_USER_SIZE:E9000000 Analysis of USB port... Analysis of system files... PRELOADER addr:0x000000 --length:0x040000 DSP_BL addr:0x040000 --length:0x5C0000 MBR addr:0x600000 --length:0x004000 EBR1 addr:0x604000 --length:0x004000 __NODL_PMT addr:0x608000 --length:0x400000 __NODL_NVRAM addr:0xA08000 --length:0x500000 __NODL_SECCFG addr:0xF08000 --length:0x020000 UBOOT addr:0xF28000 --length:0x060000 BOOTIMG addr:0xF88000 --length:0x600000 RECOVERY addr:0x1588000 --length:0x600000 SEC_RO addr:0x1B88000 --length:0x600000 __NODL_MISC addr:0x2188000 --length:0x060000 LOGO addr:0x21E8000 --length:0x300000 __NODL_EXPDB addr:0x24E8000 --length:0x200000 ANDROID addr:0x26E8000 --length:0x20100000 CACHE addr:0x227E8000 --length:0xA100000 USRDATA addr:0x2C8E8000 --length:0x41100000 FAT addr:0x6D9E8000 --length:0x000001 __NODL_BMTPOOL addr:0xFFFF0000 --length:0x000000 Format addr:0x2C8E8000 --Format length:0x1270000 >>Read phone information success.
    so here you can see
    Code:
    This is General NAND Flashing Area.
    and
    Code:
    This is it's emmc details area. this is same like Factory Provide scatter file. in this you can find all details. like you can see it's master boot record, Boot image, Recovery area and lot of other things which you will need to know for repairing any phone, AT THE MOMENT WE ONLY SUPPORT FOR READ CUSTOM AREA, WRITING WILL BE ON NEXT UPCOMING UPDATES, how you can read any specific area ?
    let me give you an example. like from this phone you need to read it's boot image only. this is really help if you got any phone with boot dead. you can simply read boot image from any same working phone and write on faulty phone your faulty phone will be repaired. i am repeating again AT THE MOMENT WE SUPPORT ONLY READ CUSTOM AREA, WE DO NOT SUPPORT WRITING AT THE MOMENT, WRITING CUSTOM AREA WILL BE COME IN NEXT UPCOMING UPDATE, after you read info you can see it's all address, now you want to read it's boot image and it's details are
    here it is. as you see
    "addr:0xF88000" this is START ADDRESS.
    "length:0x600000" this is FLASH SIZE.
    "addr" should be written in "START ADDRESS" in volcanobox MTK tab
    "length" should be written in "FLASH SIZE" in volcanobox MTK tab
    If somehow reading not read at your desired address then remove "0x" from address
    i suggest do copy/paste instead of writing with your keyboard. after you done. click on read flash and click on run. it will read you desire Flash area !!
    SPECIAL GIFT FOR ALL VOLCANOBOX USERS
    i just make special MTK ALL IN ONE DRIVER. now you don't need to found many drivers. if you have just this ONE DRIVER it will cover your all MTK Drivers needs. This will cover all these needed drivers,
    "MediaTek Inc."
    "MTK USB Port"
    "MTK USB Modem Port"
    "MTK USB Debug Port"
    "MediaTek PreLoader USB VCOM Port"
    "MediaTek DA USB VCOM Port"
    "USB Serial emulation modem driver"
    so just download only this ONE Driver and you will have cover all these drivers.
    Click here to Download MTK Universal Drivers
    Click here to download VolcanoBox 1.8.8
    Volcanobox Mirror Support Area, Here you can find all old & Full installers
    Click here for Best online unlock code server, Click here to register and get amazing discount !!
  2. ( toilatoi142001 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    hoangdaika (20-01-2013)
  1. VolcanoBox 2.3.3 World's Most Advanced Engineered Android Tool
    Bài viết cuối: 01-10-2013, 15:39
  2. @ VolcanoBox 2.3.1 World's Unique & Exclusive Solutions Provider @ MTK Android NV R/W
    Bài viết cuối: 14-09-2013, 15:14
  3. VolcanoBox 2.1.6 MTK Android SYSTEM Area Read & Su & Privacy Code new method
    Bài viết cuối: 10-06-2013, 18:50
  4. VolcanoBox1.9.9 SPD Android Imei,MTK Android Root,MTK Android Custom area write !!
    Bài viết cuối: 23-03-2013, 09:58
  5. World First MTK Android Read Flash and Imei Change Supported !!
    By HoangThong_hotrokythuat5 in forum Volcano Box
    Bài viết cuối: 06-03-2012, 08:33
