ban đầu bị chớp tắt,chạy lại cung ko ok
DLL not found...
BB5 Easy Service Tool v1.14.1 (c) Infinity-Box Team Ready
Connect phone on selected interface...
UFS S/N 75444 boot - Ok
Phone found!
Series 40 Device detected!
read info... - Ok
Read and Check phone data...
SimLock status : SimLock is Ok
Security status : Security is Ok
SDD Key status : SD Data is Ok
PA_SimLock Version :
PA_SL phone detected
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT ASICID : 000000010000022600010006010C192101001101
CMT EM0 ID : 00000232
CMT EM1 ID : 00000353
CMT PUB ID : 2A20010947206F56ED9126DAFEA5C5571A3195DB
CMT MODE ID : 00
CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1
CMT ROM ID : 191EC665DFAAF68F
CMT : Sending 2nd loader...
Use : RAP3Gv3_2nd.fg
CMT Loader sent, Boot Ok
MCU Configuration
FLASHID : 00410001 , CMT , NOR
CMT Flash ID : 00410001 < SPANSION => 72NS256PD
FLCNT : 00000000000000000000000000000000000000
FLASHID : 0000FFFF , CMT , MMC , EXT
CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok
Sending ALGO....
Use : RAP3Gv3_algo.fg
CMT Algo sent
CMT PAPUB : 7E6491E8D30494B45630BB3A8599F4E1C674C95500
Transmission mode : Dual (Ddr, TX2)
Boot Done!
Init Service mode... Wait...
Phone found!
read info... - Ok
Selected FlashSettings : FullFlash
Files Set for Flashing :
MCU : rm217__07.30.mcusw
PPM : rm217__07.21.ppm_v
CNT : rm217__07.30.image_ctv_cn
Check FlashFiles, Please, wait...
-> SWversion check skipped : Manual mode selected
Backup enabled, Will read Certificates now...
Backup CRT308
CRT308 Backup Created...
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
Sending ALGO....
CMT Algo sent
Boot Done!
CMT : Read NPC certificate...
Cert size : 12288 byte(s)
IMEI : 352939027782807
CMT : Read CCC certificate...
Cert size : 8192 byte(s)
CMT : Read HWC certificate...
CMT : Read VARIANT certificate...
Cert size : 20480 byte(s)
Cert Read done!
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
WMDRM_PD Data saved...
RPL saved : D:\BEST infinity\Backup\Cert\352939027782807_2nd.rpl
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
Sending ALGO....
CMT Algo sent
Boot Done!
Erase : Processing rm217__07.30.mcusw
Found 9 areas to erase, erase group
Asic : CMT , Sub : NOR
CMT , NOR , Area : 0x00000000 - 0x000006BF
CMT , NOR , Area : 0x000006C0 - 0x0001FFFF
CMT , NOR , Area : 0x00020000 - 0x0007FFFF
CMT , NOR , Area : 0x00080000 - 0x000DFFFF
CMT , NOR , Area : 0x00100000 - 0x001FFFFF
CMT , NOR , Area : 0x00200000 - 0x0031FFFF
CMT , NOR , Area : 0x00320000 - 0x0105FFFF
CMT , NOR , Area : 0x01060000 - 0x01067FFF
CMT , NOR , Area : 0x01068000 - 0x0107FFFF
Using TimeOut : 5 min ( 300 sec )
Erasing, wait.....
CMT : Group erase Ok
TIME : Erase time : 00:00:47
Write : Processing rm217__07.30.mcusw
CMT: Writing Hash CERT [NOLO]
CMT: Writing Hash CERT [KEYS]
CMT: Writing Hash CERT [PRIMAPP]
CMT: Writing Hash CERT [PASUBTOC]
CMT: Writing Hash CERT [PAPUBKEYS]
CMT: Writing Hash CERT [UPDAPP]
CMT: Writing Hash CERT [DSP0]
CMT: Writing Hash CERT [MCUSW]
CMT: Writing Hash CERT [PMM_CONF]
CMT: Writing Hash CERT [SBIF_CONF]
Total writen 943 blocks
TIME : Write time : 00:01:40
Erase : Processing rm217__07.21.ppm_v
Found 1 areas to erase, erase group
CMT , NOR , Area : 0x01080000 - 0x015FFFFF
Erasing, wait.....
TIME : Erase time : 00:00:17
Write : Processing rm217__07.21.ppm_v
Total writen 330 blocks
TIME : Write time : 00:00:35
ConvertImage: Processing rm217__07.30.image_ctv_cn
ConvertImage: Page Size is 64K, converting...
ConvertImage: File converted
Erase : Processing rm217__07.30.image_ctv_cn_128
CMT , NOR , Area : 0x01600000 - 0x01FDFFFF
Erasing, wait.....
TIME : Erase time : 00:00:36
Write : Processing rm217__07.30.image_ctv_cn_128
Total writen 296 blocks
TIME : Write time : 00:00:31
Reading Phone Info....
Connected phone - Nokia 6300
Software Info: V 07.30
07-05-09
RM-217
(c) Nokia.
IMEI: 352939027782807
Product code: 0554259
Checking...
Read Info Done!
Settings After Flash Defaults...
FullFactorySet...OK!
ProductTuneSet...OK!
SwUpgradeSet...OK!
Product code update...
Checking User Certificates...
Total - 0 certs
Uploading certificates...
Writen 0 certs!
AfterFlash operations done... Reconnect, wait...
Phone found!
read info... - Ok
