như tiêu đề máy ko có sóng, nhung tìm dc mạng, đăng ký mạng thì ko dc,
minh flash cho em nó ver 10.10 nhưng cũng ko có, nạp PM nhiều cái cứ failed
đây là Pm cũa nó, mình dùng turbo
Field : 1 Sub : 0 Byte(s): 48 - Failed
Field : 1 Sub : 2 Byte(s): 88 - Failed
Field : 1 Sub : 4 Byte(s): 48 - Failed
Field : 1 Sub : 6 Byte(s): 88 - Failed
Field : 1 Sub : 8 Byte(s): 48 - Failed
Field : 1 Sub : 11 Byte(s): 12 - Failed
Field : 1 Sub : 12 Byte(s): 24 - Failed
Field : 1 Sub : 13 Byte(s): 88 - Failed
Field : 1 Sub : 16 Byte(s): 24 - Failed
Field : 1 Sub : 18 Byte(s): 24 - Failed
Field : 4 Sub : 1 Byte(s): 800 - Ok
Field : 4 Sub : 3 Byte(s): 12 - Ok
Field : 4 Sub : 4 Byte(s): 8 - Ok
Field : 4 Sub : 5 Byte(s): 8 - Ok
Field : 4 Sub : 6 Byte(s): 8 - Ok
Field : 4 Sub : 9 Byte(s): 8 - Ok
Field : 120 Sub : 0 Byte(s): 944 - Ok
Field : 120 Sub : 1 Byte(s): 160 - Ok
Field : 120 Sub : 2 Byte(s): 132 - Ok
Field : 120 Sub : 3 Byte(s): 112 - Ok
Field : 308 Sub : 0 Byte(s): 4 - Failed
Field : 308 Sub : 1 Byte(s): 8192 - Failed
Field : 308 Sub : 3 Byte(s): 4 - Failed
Field : 308 Sub : 4 Byte(s): 4 - Failed
Field : 308 Sub : 5 Byte(s): 12 - Failed
Field : 308 Sub : 6 Byte(s): 4 - Failed
Field : 308 Sub : 7 Byte(s): 4 - Failed
Field : 308 Sub : 8 Byte(s): 4 - Failed
Field : 308 Sub : 9 Byte(s): 40 - Failed
Field : 309 Sub : 0 Byte(s): 4 - Failed
Field : 309 Sub : 1 Byte(s): 4 - Failed
Field : 309 Sub : 2 Byte(s): 12 - Failed
Field : 309 Sub : 4 Byte(s): 12 - Failed
Field : 309 Sub : 7 Byte(s): 12 - Failed
Field : 320 Sub : 0 Byte(s): 148 - Ok
Field : 320 Sub : 1 Byte(s): 148 - Ok
Field : 320 Sub : 2 Byte(s): 148 - Ok
Field : 320 Sub : 3 Byte(s): 148 - Ok
Field : 320 Sub : 4 Byte(s): 148 - Ok
Field : 320 Sub : 5 Byte(s): 148 - Ok
Field : 320 Sub : 6 Byte(s): 148 - Ok
Field : 320 Sub : 7 Byte(s): 148 - Ok
Field : 320 Sub : 8 Byte(s): 148 - Ok
Field : 320 Sub : 9 Byte(s): 148 - Ok
Field : 320 Sub : 10 Byte(s): 148 - Ok
Field : 320 Sub : 11 Byte(s): 148 - Ok
Field : 320 Sub : 12 Byte(s): 148 - Ok
Field : 320 Sub : 13 Byte(s): 148 - Ok
Field : 320 Sub : 14 Byte(s): 148 - Ok
Field : 320 Sub : 15 Byte(s): 148 - Ok
Field : 320 Sub : 16 Byte(s): 148 - Ok
Field : 320 Sub : 17 Byte(s): 148 - Ok
Field : 320 Sub : 18 Byte(s): 148 - Ok
Field : 320 Sub : 19 Byte(s): 148 - Ok
Field : 320 Sub : 20 Byte(s): 148 - Ok
Field : 320 Sub : 21 Byte(s): 148 - Ok
Field : 320 Sub : 22 Byte(s): 148 - Ok
Field : 320 Sub : 23 Byte(s): 148 - Ok
Field : 320 Sub : 24 Byte(s): 148 - Ok
Field : 320 Sub : 25 Byte(s): 148 - Ok
Field : 320 Sub : 26 Byte(s): 148 - Ok
Field : 320 Sub : 27 Byte(s): 148 - Ok
Field : 320 Sub : 28 Byte(s): 148 - Ok
Field : 320 Sub : 29 Byte(s): 148 - Ok
Field : 320 Sub : 30 Byte(s): 148 - Ok
Field : 320 Sub : 31 Byte(s): 148 - Ok
Field : 320 Sub : 32 Byte(s): 148 - Ok
Field : 320 Sub : 33 Byte(s): 148 - Ok
Field : 320 Sub : 34 Byte(s): 148 - Ok
Field : 320 Sub : 35 Byte(s): 148 - Ok
Field : 320 Sub : 36 Byte(s): 148 - Ok
Field : 320 Sub : 37 Byte(s): 148 - Ok
Field : 320 Sub : 38 Byte(s): 148 - Ok
Field : 341 Sub : 0 Byte(s): 4 - Ok
Field : 341 Sub : 3 Byte(s): 4 - Ok
Field : 341 Sub : 4 Byte(s): 4408 - Ok
PM Upload Done!...
anh em từng gặp xin hướng dẫn đễ khắc phục sữa lỗi, thank tất cả
			 Anh Em Giup 6303c Mat Song
