Kết quả 1 tới 4 của 4
    Thành viên tích cực tientrung199x's Avatar
    Mặc định anh em xem hộ log 3110c
    log chạy bị lỗi MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C087B2FE
    Using device: HTI, FW ver: 00.50, SN: 0100980D
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
    Processing MCU file: rm237__07.30.mcusw
    [BB5,BB5 ALGORITHM] size: 14.49 MB
    Supported Ids: 0103192101001101, 010C192101001101
    CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAP3G ver: PA 1.x]
    EM0 ID: 00000232
    EM1 ID: 00000353
    PUBLIC ID: 22F0000E32BF6F56C29FB6E494D0C073B3AD6B60
    ASIC MODE ID: 00
    ROM ID: 191EC665DFAAF68F
    eBB5ProtocolType: OLD
    Storage0: 0020 881C - 0000 6A21 [ST M58LR256JU,256 Mbits] type: FLASH,NOR, asic:CMT
    Storage content: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
    TransmissionMode: 16Bit
    TransmissionMode: DDR&TX2
    Storing certificate [NPC, VARIANT, R&D] ...OK
    Erase size: 16.37 MB
    CMT FLASH,NOR area [00000000-000006BF]
    CMT FLASH,NOR area [000006C0-0001FFFF]
    CMT FLASH,NOR area [00020000-0007FFFF]
    CMT FLASH,NOR area [00080000-000DFFFF]
    CMT FLASH,NOR area [00100000-001FFFFF]
    CMT FLASH,NOR area [00200000-0031FFFF]
    CMT FLASH,NOR area [00320000-0105FFFF]
    CMT FLASH,NOR area [01060000-01067FFF]
    CMT FLASH,NOR area [01068000-0107FFFF]
    erased in 3.875 s
    Prog.status for Asic CMT ...
    NOR: OK
    Flash programming ...
    Error chk C7012D0103CD
    RX2 not responding, please check BSI/cable/pinout !
    Error while programming [00] at 0x00020000, Result: 0000
    Task failed at (0800001C)!!!
    Last RX buffer: C7 01 2D 01 03 CD 00
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    kiểm tra lại cáp
    Nov 2012
    ĐỒNG THÁP
    lỗi rx2 vệ sinh sợi cáp có atf hay mt chiến đi bạn mx rx2 này chua
    close ... do em cắm cáp đa năng nhầm ...
