v0.914016/UNI
Card serial:00021378
Loaded 51 flash descriptors
SERVER SUPPORT ENABLED.
ALTERNATIVE SECURITY BYPASS ENABLED.
Open COM port OK
ChipID:9900,EMP protocol:0301
Speed:921600
Flash ID check:897E
Flash props sent ok
OTP LOCKED:1 CID:51 PAF:1 IMEI:35928501745311 CERT:N/A
FLASH CID:52 COLOR:RED
Can't read SCRC unit
Elapsed:114 secs.
Open COM port OK
Speed:921600
Flash ID check:897E
Flash props sent ok
Elapsed:74 secs.
Open COM port OK
Speed:921600
PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
Flash ID check:897E
Flash props sent ok
CID52 BYPASS PROCEDURE STARTED
Processing part1...
Processing part2...
Processing part3....
Open COM port OK
Flash ID check:897E
Flash props sent ok
RESTARTING PHONE,IF PHONE NOT RESTARTS,THEN
REMOVE BATTERY FROM PHONE AND INSERT IT BACK
Open COM port OK
CID52 BYPASS PROCEDURE FINISHED
Open COM port OK
Speed:921600,Abort all operations.
embedded flashloader not responds !
Elapsed:507 secs.
Đó là cái log khi em chạy w580 .Xin các anh tiếp tay giúp .THANK
