Kết quả 1 tới 10 của 17
    Thành viên chính thức quangminh.mobile's Avatar
    Jul 2011
    Mặc định xem giúp em long con 2730 voi
    em mới mua atf nên không biết chạy.anh nào qua team giúp em với .
    ATF Software Version v9.10
    ATF Lightning FBUS Flash Started...
    Number of Image Files: 3
    Forcing Test Mode via BUSCHECK...
    Booting Phone via FBUS...
    AdvanceBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    TIME STARTS HERE
    Number of Sub Blocks 7 (0x07)
    1 SYSTEM_ASIC_ID 01
    Block Length : 21 (15)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000001
    ID DWORD 1 : 00000226
    ID DWORD 2 : 00010006
    ID DWORD 3 : 030C1921
    ID DWORD 4 : 01023000
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00000296
    3 EM_ASIC_ID 02
    ID DWORD 0 : 00000B22
    4 PUBLIC_ID 12
    ID DWORD 0 : 0D10010C
    ID DWORD 1 : F8A70356
    ID DWORD 2 : DE3C846E
    ID DWORD 3 : 90784E3B
    ID DWORD 4 : 47768B11
    5 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    Block Length : 17 (11)
    Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
    7 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : 273F6D55
    CRC 1 : DFAAF68F
    Checksum 8E
    SearchForBootstrap_DCT5..
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
    Boot File - Version 010.042.00
    Boot File - Revision 0x0000 (0)
    eBB5ProtocolType == Original
    Secondary Loader Sent...
    MessageID : 03
    SubBlocks : 03
    Block Length : 0B
    BB ASIC Index : CMT 00
    Device Type : NOR 00
    Device Index : 00
    Manufacturer Code : 0089 ->
    Device ID : 8982 -> NU48F512
    Extended/Fixed ID : 0000
    Revision ID : 8A31
    2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5
    Block Length : 13
    Device Index : 00
    Device Contents : 00000000000000000000
    Block Length : 0B
    Device Type : MMC 04
    Device Index : 00
    Revision ID : 0000
    Checksum : 51
    FLS1SendAlgoCodeEx..
    SendAlgoCode_DCT5..
    SearchForAlgorithm_DCT5..
    Looking for ALL Devices...
    Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31
    Flash Descriptor
    Device ID : 8982
    Revision ID : 0000
    Size : 04000000 (64 MB)
    VPP Info : 0009
    Erase10s : 28
    Block1s : 64
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
    Algorithm File - Version 010.040.00
    Algorithm File - Revision 0x0000 (0)
    SearchForAlgorithm_DCT5 : No Error - 0 (0x00)
    TransmissionTypeRequest_DCT5...
    SuggestedType : 01 16BIT
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC
    ReturnedType : 01 16BIT
    TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
    Uploading ALGO File...
    PAPUB_KEYS_HASH_REQ_BB5
    No PAPUBKeysHash Returned
    Scanning Simlock Applet Type...
    OK
    SL1/SL2 Applet detected
    Waiting for Phone to Go Online...
    Elapsed Time: 1s
    Elapsed Time: 2s
    Elapsed Time: 3s
    Elapsed Time: 4s
    Elapsed Time: 5s
    Elapsed Time: 6s
    Elapsed Time: 7s
    Elapsed Time: 8s
    Elapsed Time: 9s
    Elapsed Time: 10s
    Basic Phone Information
    WARNING: Simlock Backup Failed
    If this is a Dead Phone, just click YES
    to Continue with the Flash Procedure...
    Cản ơn Đời mỗi Sớm Mai thức dậy
    Ta Có Thêm Ngày Nữa,Để Yêu Thương.
    Thành thật mà nói, nhìn cái log của ATF thì không thể nào bắt bệnh, chuẩn bằng MX được, nhiều lúc log check của ATF, còn thua cả Best, tốt nhất check bằng MX cho chắc ăn
  3. ( Lính Khang ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    quangminh.mobile (04-02-2013)
    Jul 2011
    để em đổi qua mxbox
    Jan 2009
    Hải Phòng
    ko backup dc simlock, nếu máy die thì chọn yes để tiếp tục flash, máy sống thì test lại cable, vệ sinh tiếp xúc pinout rồi thử lại.
    Jul 2011
    MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: C0851833
    Using device: HTI, FW ver: 00.50, SN: 0100BD2F
    Connection status: OHCI:HUB:USB 2.00 (Full-speed)
    Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7600.16385
    Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14213(16-10-2012)
    ERROR: Packet Error(0xAA), code 0xC0000002
    CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006030C192101023000 [RAP3G ver: PA 3.0]
    EM0 ID: 00000296
    EM1 ID: 00000B22
    PUBLIC ID: 0D10010CF8A70356DE3C846E90784E3B47768B11
    ASIC MODE ID: 00
    ROM ID: 273F6D55DFAAF68F
    SecondaryBoot: RAP3Gv30_2nd.fg [BB5] version: 10.48.1 revision: 3.0 size: 0x3B80
    eBB5ProtocolType: NEW
    TransmissionMode: DDR&TX2
    Storage2: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT
    Not supported flash chip, please disable "Use New Protocol for RAP3GV3" in config
    Jul 2011
    máy die rồi... em chạy bằng cáp đa năng bb5-d
    Jul 2011
    giúp em với... cho em hương giải quyết
  9. #8
    Trích Được post bởi quangminh.mobile Xem bài viết
    Máy của anh tình trạng đang bị gì vậy, cho ae chút thông tin nửa đi, chứ anh nói không không như thế này, thì ae biết cái gì mà giúp cho anh
  10. #9
    Jan 2009
    Hải Phòng
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    cài lại, bỏ dấu ở ô RAP3G rồi thử lại
  11. #10
    Jul 2011
    máy bình thường.. chỉ bị chậm khách yêu cầu phải nâng v em chay 10.47 đang chạy máy báo lỗi flash
  1. Trả lời: 8
    Bài viết cuối: 03-10-2013, 17:53
  2. Trả lời: 4
    Bài viết cuối: 05-07-2013, 17:35
  3. anh em xem hộ em long con 2730c-1
    By duybach9x in forum BB5
    Bài viết cuối: 05-11-2012, 20:38
  4. anh em xem ho cai long
    By langngo in forum BB5
    Bài viết cuối: 20-11-2009, 10:32
