DLL not found...
BB5 Easy Service Tool v1.14.1 (c) Infinity-Box Team Ready
Connect phone on selected interface...
UFS S/N 75444 boot - Ok
Read and Check phone data...
Setting FlashMode
FlashMode set Ok
No answer from phone...
1. Check cable/connection, try again
2. Maybe HW fault or bad cable
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT ASICID : 000000010000022600010006010C192101001101
CMT EM0 ID : 00000232
CMT EM1 ID : 00000353
CMT PUB ID : 15700010D1CD6E56B21B5FF583EC4DF11CEF018C
CMT MODE ID : 00
CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1
CMT ROM ID : 191EC665DFAAF68F
CMT : Sending 2nd loader...
Use : RAP3Gv3_2nd.fg
CMT Loader sent, Boot Ok
MCU Configuration
FLASHID : 881C0020 , CMT , NOR
CMT Flash ID : 881C0020 < ST => M39L0R807
FLCNT : 00000000000000000000000000000000000000
FLASHID : 0000FFFF , CMT , MMC , EXT
CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok
Sending ALGO....
Use : RAP3Gv3_algo.fg
CMT Algo sent
CMT PAPUB : E691EA16A7593A9BB28832D7312A39F7ED668D0500
Transmission mode : Dual (Ddr, TX2)
Boot Done!
Init Service mode... Wait...
Init Service Mode Failed, can't proceed checking...
Selected FlashSettings : Manual
Files Set for Flashing :
MCU : rm237_07.30.mcusw
PPM : rm237_07.30.ppm_v
CNT : rm237__07.30.image_ora_pl_games_128k
Check FlashFiles, Please, wait...
-> SWversion check skipped : Dead mode selected
Backup enabled, Will read Certificates now...
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
Sending ALGO....
CMT Algo sent
Boot Done!
CMT : Read NPC certificate...
Cert size : 12288 byte(s)
IMEI : 352047021803312
CMT : Read CCC certificate...
Cert size : 8192 byte(s)
CMT : Read HWC certificate...
CMT : Read VARIANT certificate...
Cert size : 20480 byte(s)
Cert Read done!
Init Service Mode Failed!
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : D:\BEST infinity\Backup\Cert\352047021803312_CRT.rpl
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
Sending ALGO....
CMT Algo sent
Boot Done!
Erase : Processing rm237_07.30.mcusw
Found 9 areas to erase, erase group
Asic : CMT , Sub : NOR
CMT , NOR , Area : 0x00000000 - 0x000006BF
CMT , NOR , Area : 0x000006C0 - 0x0001FFFF
CMT , NOR , Area : 0x00020000 - 0x0007FFFF
CMT , NOR , Area : 0x00080000 - 0x000DFFFF
CMT , NOR , Area : 0x00100000 - 0x001FFFFF
CMT , NOR , Area : 0x00200000 - 0x0031FFFF
CMT , NOR , Area : 0x00320000 - 0x0105FFFF
CMT , NOR , Area : 0x01060000 - 0x01067FFF
CMT , NOR , Area : 0x01068000 - 0x0107FFFF
Using TimeOut : 5 min ( 300 sec )
Erasing, wait.....
CMT : Group erase Ok
TIME : Erase time : 00:00:55
Write : Processing rm237_07.30.mcusw
CMT: Writing Hash CERT [NOLO]
CMT: Writing Hash CERT [KEYS]
CMT: Writing Hash CERT [PRIMAPP]
CMT: Writing Hash CERT [PASUBTOC]
Error write CERT block at : 10
ERR : FC03FC03FC03FC0410000000
Error on Flashing Phone!
Error...
			 nhờ các bác xem hộ dùm cái log 3110c
