    Thành viên tích cực LongMy_Mobile79's Avatar
    Feb 2012
    Mặc định 6300 sáng 2 đèn hông
    MXKEY [MxKey Team HTI PLUS Flasher Interface 3], SN: C0871D8F
    Using device: USB Phonet and HTI, FW ver: 00.50, SN: 0100B1EC
    Connection status: UHCI:HUB::USB 2.00 (Full-speed)
    Driver: nmwcdnsuc, ver: 7.1.32.75
    Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
    Processing MCU file: rm217__07.30.mcusw
    [BB5,BB5 ALGORITHM] size: 14.50 MB
    Supported Ids: 0103192101001101, 010C192101001101
    Waiting for USB ROM device ...
    CMT SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAP3G ver: PA 1.x]
    CMT EM0 ID: 00000232
    CMT EM1 ID: 00000353
    CMT PUBLIC ID: 2EF0010771626F5630340395BD5836E9182DEED0
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
    CMT ROM ID: 191EC665DFAAF68F
    Flashing CMT Update Server Data, ULO: 0x38C0 bytes
    Update Server code succesfully sent to phone.
    Flashing CMT Update Server Data, UPDAPP: 0x3CA00 bytes
    Flashing CMT Update Server Data, PASUBTOC: 0x4A9C0 bytes
    Waiting for USB device removal ...
    Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 27339F3B
    Verifying communication to device OK.
    Erase size: 16.37 MB
    CMT FLASH,NOR area [00000000-000006BF] erased in 0.375 s
    CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.015 s
    CMT FLASH,NOR area [00020000-0007FFFF] erased in 1.094 s
    CMT FLASH,NOR area [00080000-000DFFFF] erased in 0.157 s
    CMT FLASH,NOR area [00100000-001FFFFF] erased in 0.500 s
    CMT FLASH,NOR area [00200000-0031FFFF] erased in 3.500 s
    CMT FLASH,NOR area [00320000-0105FFFF] erased in 39.843 s
    CMT FLASH,NOR area [01060000-01067FFF] erased in 0.391 s
    CMT FLASH,NOR area [01068000-0107FFFF] erased in 0.031 s
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    Selecting first CMT PAPUB block with matching RootKey.
    CMT PAPUBKEYS: 7F7E6491 [RAP Certificate 52 v1] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    CMT PMM_CONF block sent
    CMT SBIF_CONF block sent
    Programming completed in 2 min 6.813 s
    Processing PPM file: rm217__07.30.ppm_v_****
    [BB5,BB5 ALGORITHM] size: 5.16 MB
    Erase size: 5.50 MB
    CMT FLASH,NOR area [01080000-015FFFFF] erased in 16.344 s
    Programming completed in 41.547 s
    Processing CNT file: rm217__07.30.image_v_socola
    [BB5,BB5 ALGORITHM] page size: 64 K size: 5.88 MB
    Erase size: 9.87 MB
    CMT FLASH,NOR area [01600000-01FDFFFF] erased in 18.329 s
    Programming completed in 44.640 s
    Total time for flashing process(boot+erase+write) was 5 min 33.765 s
    Phone not found, retrying ...
    Warning: Phone did not reboot to normal mode.
    log em nó ó...em làm lại. 2 con nguồn khò nóng u lass rồi....hjx mùng 3 tết gặp toàn kèo "thơm" kô hà ...xin ae giúp đỡ
    0917752979_new member
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    khò nóng hay đụng lun vaòi u rồi ???
    bệnh sáng 2 dèn bên hông có thể do cặp nguồn + flash _ trung tầng
    giờ bạn làm chân trung tầng lại rồi flash lại xem có lên không ?
    Thành viên tích cực KIÊN NGUYỄN MOBILE's Avatar
    Feb 2010
    TP HCM
    đóng lại trung tuần ==>> 26m ==>> move 2 con tụ C2071 & C2076 như hình dưới đây
    Feb 2010
    TP HCM
    Thành viên chính thức HiepMobile1981's Avatar
    Dec 2011
    chưa thấy hình anh ơi
    LUÔN TÌM TÒI HỌC HỎI TÌM Ý TƯỞNG CHO TƯƠNG LAI
    Feb 2012
    anh up lại kái hình đi huynh
    Feb 2010
    TP HCM
    đây
    Feb 2012
    tây ninh
    cái này chưa gì mà đụng tùm lum.pó tay chủ thớt.bệnh sáng 2 đèn bên hông nhiều ae chia sẻ lắm rồi.bác coi con tahvo trên đường Vbat có mấy con tụ lọc nguồn nối mass mất 1 trong các con đó máy cũng sáng đèn ko lên nguồn.ko đc thiếu con nào.cái thứ 2 mà mình gặp đó là máy sáng đèn ko lên nguồn thường do mất áp vcore cấp cho U.và dao động 38.4MHZ.đối với máy có schema thì việc làm đầu tiên các bác toàn bỏ qua đó chính là đo các áp chính.nó ko làm mất nhiều time đâu.còn hơn đục đẽo ko ok quay lại từ đầu.nói chung máy có schema thì cứ từ từ làm từ đơn giản đến phức tạp.chúc bác may măn lần sau.
    Dec 2011
    làm được chưa chủ thớt lên chia sẽ cho ae rút kinh nghiệm
  1. Trả lời: 9
  2. Trả lời: 19
  3. Trả lời: 21
  4. 6300 đuôi sạc như 6300 xịn sạc tiếp xúc kém
    Trả lời: 21
