    Thành viên chính thức numberfour's Avatar
    Nov 2012
    Mặc định ATF của em hình như có vấn đề ai biết giúp với
    tình hình là em nhận 1 con asha 311 mã bảo vệ nhưng check ngon nhưng thiếu cái simlock thế là không reset được mã có ai biết không chỉ em với log nó đây Booting Phone via USB...
    USB Phone BUSCheck Boot
    1. Remove USB and Battery...
    2. Insert USB.
    3. Insert Battery. (Some phones boot automatically)
    4. Please Power on phone shortly...
    AdvanceFBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    READING BOOTROM
    BootFlashModeDCT5Ex Succeded After 0 Tries
    SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned
    Number of Sub Blocks 7 (0x07)
    1 SYSTEM_ASIC_ID 01
    Block Length : 21 (15)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000003
    ID DWORD 1 : 00000226
    ID DWORD 2 : 00010007
    ID DWORD 3 : 400C1921
    ID DWORD 4 : 03042108
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00001051
    3 EM_ASIC_ID 02
    ID DWORD 0 : 00001060
    4 PUBLIC_ID 12
    ID DWORD 0 : 7E1C0080
    ID DWORD 1 : FFFB3C40
    ID DWORD 2 : E4E497E4
    ID DWORD 3 : CB233276
    ID DWORD 4 : B16C561E
    5 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    Block Length : 17 (11)
    Hash : 6D 95 6B 2D 26 FE C3 C7 84 E2 16 49 2B 7C C9 0A
    7 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : 2CAC45E2
    CRC 1 : 1CB478AF
    CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv21_2nd.fg
    Secondary Loader Sent....
    MessageID : C1
    SubBlocks : 06
    Block Length : 0B
    BB ASIC Index : CMT 00
    Device Type : RAM 05
    Device Index : 00
    Manufacturer Code : 0000 -> Flash
    Device ID : 0000 -> Type not in database
    Extended/Fixed ID : 0000
    Revision ID : 0000
    2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MMC 04
    Device Index : 00
    Revision ID : 0000
    Block Length : 0B
    Device Type : NOR 00
    Device Index : 00
    Revision ID : 0000
    4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Index : 01
    Manufacturer Code : 0000 -> SPANSION
    Device ID : 0001 -> Type not in database
    Revision ID : 0000
    5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MuxOneNAND 03
    Device Index : 00
    Manufacturer Code : 00EC ->
    Device ID : 0040 -> Type not in database
    Revision ID : 0241
    6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
    Block Length : 09
    Data : XSR 1.6
    Flash Descriptor
    Device ID : 0040
    Revision ID : 0000
    Size : 10000000 (256 MB)
    VPP Info : 0000
    Erase10s : 1E
    Block1s : 32
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv21_XSR17_alg.fg
    Algorithm Loader Sent...
    FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
    FUR control Ok
    PA PUBLIC KEY Request
    PHONE_INFO_RESPONSE_BB5
    PAPUB_KEYS_HASH_RESP_BB5 2A
    BB Asic Index : 00
    CMT PAPUBKEYS HASH:
    A3E0AA6F2F86410BA6D666BACF6186EEFBC82D28
    FlashInfo.RestartMode : Test Mode
    Process Done... chạy đến đây là thôi reset all thì báo faild. em chưa muốn chạy lại ai biết thì giúp em
    Nov 2012
    mọi người đi ăn cơm hết rùi à :'(
    V.I.P vinhkiengiang's Avatar
    Aug 2010
    con này flash lại luôn anh. nhanh mà
    Đ/C: 205 NGUYỄN BỈNH KHIÊM, PHƯỜNG VĨNH THANH, TP RẠCH GIÁ, KIÊN GIANG.
    UNLOCK - REAPAIR BOOT - NẠP TIẾNG VIỆT ALL MOBILE <==> YAHOO: vinhkiengiang
    Nov 2012
    Trích Được post bởi vinhkiengiang Xem bài viết
    thế giờ không check được có phải do hộp không hay là do điện thoại
    em không muốn chạy lắm mấy dòng nokia mới này có con chuối lắm nhất là con nokia 200
    Nov 2012
    flash lại log đẹp lên ngon thế mà cho vào check không được hay check phải dùng FBUS nhỉ ???
  1. Trả lời: 1
    Bài viết cuối: 03-11-2012, 12:02
  2. Trả lời: 5
    Bài viết cuối: 09-09-2012, 11:42
  3. ai biết chạy PM bàng HWK xin 1 khóa bàng ly thuyết ai biết giup em voi
    By kithuatga in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 23-03-2012, 17:15
