Kết quả 1 tới 10 của 13
    Thành viên chính thức tuantu_gsm's Avatar
    Mặc định nhờ mọi người xem dùm em cái log 2700
    tình trạng máy khách đem vào treo nokia , nhờ mọi người xem dùm em
    đây là log chạy
    Version from phone: 09.95
    Version from file: 09.97
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C0820380
    Using device: HTI, FW ver: 00.50, SN: 000157C5
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
    Reading RPL backup ...
    Reading Phone IDs ...
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    PUBLIC ID: 17A0010C33110256A0A77601EE38C01CC2AA2AEC
    ASIC MODE ID: 00
    ROM ID: 273F6D55DFAAF68F
    SecondaryBoot: RAP3Gv30_2nd.fg [BB5] version: 11.34.0 revision: 3.0 size: 0x3B80
    eBB5ProtocolType: NEW
    TransmissionMode: DDR&TX2
    Storage2: 00EC 2400 - 0000 8A31 [Samsung K5N2833ATB,512 Mbits] type: FLASH,NOR, asic:CMT
    Algorithm: RAP3Gv30_XSR14_alg.fg [BB5 ALGORITHM] version: 11.34.0 revision: 3.0 size: 0x81324
    PRIVATE ID: CB29D45FC5B8AEEAA2E689416B0D408B65C238BC
    E-FUSE: C5D5525E
    SEC ROM CRC: DFAAF68F
    productData saved.
    Restarting phone ...
    Reading Secure Storage ...
    Reading Important data ...
    Reading SIMLOCK data ...
    Reading CERT data ...
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    eBB5ProtocolType: OLD
    Storage0: 00EC 2400 - 0000 8A31 [Samsung K5N2833ATB,512 Mbits] type: FLASH,NOR, asic:CMT
    TransmissionMode: 16Bit
    Reading CMT HWC (0xD4 bytes).
    Reading CMT R&D (0x0 bytes).
    Flash Imei: 35435004127521
    NPC_DATA saved OK
    CCC_DATA saved OK
    HWC_DATA saved OK
    SIMLOCK_DATA saved OK
    SIMLOCK_KEY_DATA saved OK
    SUPERDONGLE_KEY_DATA saved OK
    CMLA_KEY_DATA saved OK
    WMDRM_PD_DATA saved OK
    RF_DATA saved OK
    WARRANTY_DATA saved OK
    PROD_DATA saved OK
    BT_DATA saved OK
    LOCK_DATA saved OK
    LOCK120_DATA saved OK
    BB_DATA saved OK
    RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35435004127521_BA CK.rpl"
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    Processing MCU file: rm561__09.97.mcusw
    [BB5,BB5 ALGORITHM] size: 19.41 MB
    Erase size: 21 MB
    CMT FLASH,NOR area [00000000-000006BF]
    CMT FLASH,NOR area [000006C0-0001FFFF]
    CMT FLASH,NOR area [00040000-000BFFFF]
    CMT FLASH,NOR area [000C0000-0013FFFF]
    CMT FLASH,NOR area [00140000-0137FFFF]
    CMT FLASH,NOR area [01380000-0151FFFF]
    erased in 1 min 20.313 s
    Prog.status for Asic CMT ...
    NOR: OK
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 3EA22A1D [RAP Certificate 202 v.1] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    NOR: OK
    Programming completed in 1 min 22.485 s
    Processing PPM file: rm561__09.97.ppm_v
    [BB5,BB5 ALGORITHM] size: 6.90 MB
    Erase size: 8.62 MB
    CMT FLASH,NOR area [01520000-01DBFFFF]
    erased in 28.391 s
    NOR: OK
    NOR: OK
    Programming completed in 28.219 s
    Processing CNT file: rm561__09.97.image_v_blac
    [BB5,BB5 ALGORITHM] page size: 128 K size: 13.64 MB
    Erase size: 34 MB
    CMT FLASH,NOR area [01DC0000-0215FFFF]
    CMT FLASH,NOR area [02160000-03FBFFFF]
    erased in 2 min 19.625 s
    NOR: OK
    NOR: OK
    Programming completed in 55.360 s
    Total time for flashing process(boot+erase+write) was 7 min 1.157 s
    Phone type: RM-561 (Nokia 2700 classic)
    SW version: V 09.97 18-06-10 RM-561 (c) Nokia
    Imei plain: 35435004127521-6
    Product code: 0579808
    Battery voltage: 4603 mV, current: 58 mA
    Language Pack:
    - not available.
    SIMLOCK invalid!
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SECURITY_TEST passed
    Failed to read SP data
    đây là log chek :
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    Selected firmware certificate matched.
    Original Imei: 35435004127521
    Original Product code: 0579808
    Bluetooth ID: 303855F66A74
    SIMLOCK PA identifier:
    [0] PA_SL3
    Battery voltage: 4612 mV, current: 58 mA
    Language Pack:
    - not available.
    SIMLOCK invalid!
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    quất cho nó cái ver đụng nóc đy rồi tính sau
    em đã chạy đụng log rồi anh ah
    hình như thiếu 1 fai sim lock mà bạn
    yh chanyenmobile_led1202
    ctk hà Văn Yên face hachanyen
    sdt zalo..0972444489
    BỘ ngoại giao trùm các 4r
    Aug 2011
    khu đèn đỏ
    Trích Được post bởi tuantu_gsm Xem bài viết
    ver hiện tại là 9.98 bác xem kĩ lại tí coi sao
    dạ vâng để em chạy lại thử
    Thành viên tích cực damxuanquang's Avatar
    thấy có cái dòng này mừ ko có backup là thay cặp
    SIMLOCK invalid!
    em đã chạy lại vẻ 9.98 nhưng vẫn not ok , ai ghe qua xin giúp dùm em
    Thành viên chính thức banhkeohaiha's Avatar
    SIMLOCK invalid!
    tìn file bakup đập cho em nó phát là ok C:\mobileEx\3.5\data\backup\BB5_35435004127521_BA CK.rpl
  1. nhờ mọi người xem dùm em log 2700
    By tuantu_gsm in forum BB5
    Bài viết cuối: 23-10-2012, 14:04
  2. anh em xem dùm em cái log 2700
    By LongMy_Mobile79 in forum BB5
    Bài viết cuối: 04-10-2012, 10:07
  3. sem hộ dùm em con 2700
    By quan 369 in forum BB5
    Bài viết cuối: 01-08-2012, 13:45
  4. các bác 4r xem dùm em cai lốc máy 2700
    By meocon81 in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 28-04-2012, 20:14
  5. xem dùm log 2700
    By AHOANG_GSM in forum BB5
    Bài viết cuối: 16-02-2011, 23:29
