như tieu đề mình flash n81 rm-223 vào nhưng kg đồng bộ dc!
mình nạp file eno rm-223 vào thì máy info ra dc! nhưng là rm-179!lại bị imei? mà kg sửa dc! kì lạ quá!
anh em nào rảnh wa team giúp mình với! mình đã backup full ok!
cám ơn!
112 249 905
5011
				 n81 rm-223 nạp file eno cần giúp!
cám ơn!
112 249 905
5011
				ATF Software Version v9.20
ATF Nitro FBUS Flash Started...
Number of Image Files: 1
Processing Image File :
C:\Program Files\Nokia\Phoenix\Products\RM-223\rm223_ENO_x_2007wk24v0.070_001.fpsx
CMT Type : BB5
CMT Algorithm : XSR 1.5
Secondary Sending Speed : 650000 Hz
Algorithm Sending Speed : 6500000 Hz
Program Sending Speed : 6500000 Hz
Message Reading Speed : 98000 Hz
Number of Blocks : 105
Entry Point : 0x1FDD94
Page Format : 128K
Maximum Page Size : 0x00020000
Changing MODE : FLASH
Booting Phone via FBUS...
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
AdvanceBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded after 3 Attempts
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00010006
ID DWORD 3 : 400C1921
ID DWORD 4 : 01021103
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 00000295
3 EM_ASIC_ID 02
ID DWORD 0 : 00000B22
4 PUBLIC_ID 12
ID DWORD 0 : 0CD0000B
ID DWORD 1 : 89630052
ID DWORD 2 : 3883FDE2
ID DWORD 3 : 4C3ED0F4
ID DWORD 4 : D5F5087A
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 9A 28 E1 19 03 3B 91 D1 4D 22 83 8C 86 D0 D5 3C
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : A8C1D671
CRC 1 : 3E691FF8
Checksum BC
SearchForBootstrap_DCT5..
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg
Boot File - Version 012.08.00
Boot File - Revision 0x0002 (2)
eBB5ProtocolType == New
PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
Secondary Loader Sent...
TransmissionTypeRequest_DCT5_NewProtocol
TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
Transmission Type Request Sent...
MessageID : 06
SubBlocks : 06
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : RAM 05
Device Index : 00
Manufacturer Code : 0000 -> Flash
Device ID : 0000 -> not detected
Extended/Fixed ID : 0000
Revision ID : 0000
2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Type : NOR 00
Device Index : 00
Manufacturer Code : 0400 -> Flash
Device ID : 0000 -> Type not in database
Revision ID : 0000
4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Index : 01
Manufacturer Code : 0000 -> SPANSION
Device ID : 0001 -> not used
Revision ID : 0000
5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MuxOneNAND 03
Device Index : 00
Manufacturer Code : 00EC ->
Device ID : 0030 -> K5W1G13ACB
Revision ID : 0121
6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
Block Length : 09
Data : XSR 1.5
Checksum : 35
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0030 ExtID :0000 RevID :0121
Flash Descriptor
Device ID : 0030
Revision ID : 0000
Size : 08000000 (128 MB)
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.f g
Algorithm File - Version 012.08.00
Algorithm File - Revision 0x0002 (2)
Algo Loader Sent...
SendCodeStart_NewProtocol :
SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok...
VPP Enabled by Software
Using Internal VPP
FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
PAPUB_KEYS_HASH_REQ_BB5
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
E70C21157D5AB5AF61AAD376910751FB06D6E9FD
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
Partition Blocks : 1
1 PARTITION_INFO_BB5
BB ASIC Index : 0x00 CMT
Device Type : 0x03 MuxOneNAND
Device Index : 0x00
Partition Version : 00010000
Spare : FFFFFFFF
Num Partitions : 00000005
Partition 1
Attribute : 00000002 RO
Start Address : 00080000
Partition 2
ID : 00000004 DEMANDONOS
Start Address : 01780000
Partition 3
ID : 00000008 FILESYSTEM
Attribute : 00000001 RW
Start Address : 05B80000
Partition 4
ID : 00000009 FILESYSTEM1
Start Address : 079E0000
Partition 5
Start Address : 07B40000
PARTITION_INFO_REQUEST_BB5 : 64012F5F00030000010000FFFFFFFF00000005000000030000 00020008000001700000000000040000000201780000044000 00000000080000000105B8000001E600000000000900000001 079E0000001600000000000A0000000107B4000000160000DC
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength : 0x78 (120)
ERASE Blocks : 0x03 (3)
0 ERASE_AREA_BB5 0x12
Block Length : 0x13 (19)
Device Index : 0x00
0 : 00040000-00082FFF
1 : 00083400-05B7FFFF
1 FORMAT_PARTITION_BB5 0x19
Block Length : 0x2F (47)
Device Index : 0x00
Format Info ID : 0x00000000
Format Info : 000000000000000A0000000000000002000000640000000300 000001000000010000000000000000
2 FORMAT_PARTITION_BB5 0x19
Device Index : 0x00
Format Info : 00000000000000090000000000000002000000640000000300 000001000000010000000000000000
Erase_SendEraseBlock_BB5_NAND
Task in Progress... Please Wait...
Erase_SendFormatPartition_BB5_NAND
Successfully erased..
Time Taken to Erase : 00:00:01
Flashing Speed: 5.00 Mhz (AUTO)
Processing : rm223_ENO_x_2007wk24v0.070_001.fpsx
Total blocks to write : 105
>> CMT Rootkey Hash CERT : ADA
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : RAP3NAND
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS [E70C21157D5AB5AF61AAD376910751FB06D6E9FD]
>> CMT Rootkey Hash CERT : SOS*UPDAPP
>> CMT Rootkey Hash CERT : SOS*DSP0
>> CMT Rootkey Hash CERT : SOS*ISASW
>> CMT Rootkey Hash CERT : SOS*ENO
ContinueFlash_DCT5 Complete
Continue Flash Complete : : No Error - 0 (0x00)
Time Taken to Flash : 00:00:03
Total Flash Write Time (Flashing Only) : 00:00:03
Total Flashing Time (Booting + Erase + Flashing) : 00:00:08
STATUS_REQUEST_BB5...
1 Sub Block ID : 15 STATUS_NAND_OK_BB5
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Num Bad Blocks : 00000000
Additional Bad : 00000000
Correctable ECC : 00000000
Waiting for Phone to Go Online...
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
Basic Phone Information
MCU Version: Vp 06wk41v34_RD 01-08-07 RM-179 (c) Nokia
IMEI Plain : 12345610654321?
IMEI Spare : A123456106543210
IMEI SV : 31234561065432104F
Phone Model: Nokia N81
Category : Classic Phone
Phone Type : RM-179
Extended Phone Information
Product Serial Number: CRF093726
Product Code : 0550094
Module Code : 0203265
Basic Production Code: 0541202
Long Production SN : 0
MCU SW Version : Vp 06wk41v34_RD 01-08-07 RM-179 (c) Nokia
HW Version : 0542
RFIC Version : 17141715
DSP Version : bruce_06wk41v34
AHNE Version : 11
APE Test Version : rm223_ENO_x_2007wk24v0.070
RETU Version : 15
TAHVO Version : 22
APE HW Version : 256
APE ADSP SW Version : 256
Bluetooth ID : 00:02:5B:00:A5:A5
CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I
Simlock Information
Unable to read SP Data..
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
Phone Type : RM-179
HW Version : 0542
Simlock Information
SECURITY_TEST : FAILED
> Try SX4 "PM AUTH"
> Then Write PM 1 and 309
Phone NOT detected..
anh em nào rảnh tay giúp mình với
				yh duykhanhcbt mình xem giúp dc k nè
chứ team trên k đồng bộ k vào dc
NgocTin_Apple (05-03-2013)
				bạn duy khanh đã giúp mình nhưng vẫn chưa được cần anh em giúp!
con nay chua quá!
mình co luu lai log tôt cua nó trong atf
				anh em cho ý kiến giúp
				chưa ai gặp bệnh này sao! cao thủ phần mềm đâu cả rồi?
				bây giờ tình trạng máy ra sao đang rỗi cho tewm đi qua xem giúp
				vâng cám ơn anh hải
112 249 905
7628
				mong các anh em giỏi phần mềm và đã làm qua con này xem giúp mình với!
máy chưa có dấu hiêu sửa phần cứng gì hết! mà mình và hai bạn đã giúp nhưng chưa dc!
112 249 905
6919
nó là dòng sl1 sl2 mà sao khó chịu quá!
anh em rảnh đi ngang giúp mình với! mình cám ơn nhiều!
