Kết quả 1 tới 10 của 11
    Thành viên chính thức yenbai's Avatar
    Jun 2012
    Mặc định s5220 xin các cao thủ giúp gấp
    máy bị lỗi em chạy bằng tool . dã cài đủ river . mà chạy được 38% thì báo lỗi . xin ae cho ý kiến.thank
    Device synchronized.
    Injecting EBL-Loader (RPSI).
    Injecting EBL
    Boot-loader is active
    EBL version: 2150_OD_KL1_3.1 3..1
    Boot mode is: BB
    Using: Faster CRC, Writing all blocks , Skip data CRC , Skip protocol CRC
    Package length is 16384 - protocol: 3.32
    Baud rate set to 921600
    Get flash id.
    Flash ID is: 003000EC
    Boot process finished
    Start downloading item 'BOOT CORE PSIsi.fls'' from file 'C:\Documents and Settings\Admin\Desktop\New Folder\S5220DXLC2\S5220DXLC2_psi.fls''.
    Sending sec-pack.
    Load region 0
    - Sending data.
    Sending end-pack.
    Checksum OK (0x0000)
    Verify OK
    Process time was 828 msec.
    Start downloading item 'BOOT CORE SLB:slb.fls'' from file 'C:\Documents and Settings\Admin\Desktop\New Folder\S5220DXLC2\S5220DXLC2_slb.fls''.
    Sending sec-pack.
    Load region 0
    - Sending data.
    Sending end-pack.
    Verify OK
    Process time was 735 msec.
    Start downloading item 'CODE:CATFISH.fls'' from file 'C:\Documents and Settings\Admin\Desktop\New Folder\S5220DXLC2\S5220DXLC2_BSY.fls''.
    Sending sec-pack.
    Load region 0
    - Sending data.
    Load region 1
    - Sending data.
    Sending end-pack.
    Verify OK
    Process time was 56.7 sec.
    Start downloading item 'CODE:CATFISH.fls'' from file 'C:\Documents and Settings\Admin\Desktop\New Folder\S5220DXLC2\S5220DXLC2_CDS.fls''.
    Sending sec-pack.
    Load region 0
    - Sending data.
    Sending end-pack.
    Verify OK
    Process time was 812 msec.
    Start downloading item 'CUST:temp_GT-S5220_OLA.dffs'' from file 'C:\Documents and Settings\Admin\Desktop\New Folder\S5220DXLC2\S5220OLALC2_CSC.dffs''.
    Sending sec-pack.
    Load region 0
    - Sending data.
    Process time was 1 min 32 sec.
    Stopped at 38% total, 44% current
    Timeout occured during packet reception
    The phone did not answer within the timeout period. This could be that the communication is interrupted or that the target SW is in an endless loop.
    Check the connection to the phone, battery etc. If the problem persists report the error to the developer.
    Channel 1 is succesfully closed.
    V.I.P ThanhHai_GSM's Avatar
    có hwk không mượn tool Sams và chọn model 3560 hoặc 3750 trên tool hwk chọn file 5220 flash qua usb done
    Jun 2012
    em có hwk. nhưng vào tìm dâu co model nào như bác noi dâu. còn cách nào không các bác.
    Trích Được post bởi yenbai Xem bài viết
    chuyên sang tab Sky/infi
    Jun 2012
    có 3550 thôi bác thanhhai. mà bác có file. và hướng dan em cách chon file luôn. em chỉ có file chạy tool .
    s3550 cũng đc và cũng dùng file 5220 đo luôn
    chọn thứ tự theo đuôi file
    BSY
    PSI
    CDS
    CSC
    SLB
    chọn USB0
    Thành viên tích cực phamtrung's Avatar
    bạn cho vào mx chạy đi mà bạn o chỗ nào yên bái thế ?
    Jun 2012
    em co hộp z3x.nhưng kêt nối không được. không biết z3x có chạy được em này không các bác.
    Thành viên tích cực chicong2008's Avatar
    Nov 2011
    z3x múc ngot lun nà cần gì wa em giúp
    Jun 2012
    chien bang z3x đã ok rồi.thank cac bác
  1. Xin giúp chọn file flash cho samsung S5220 bằng hwk !
    By PhùngMobile in forum Phần mềm Samsung
    Bài viết cuối: 05-08-2013, 10:24
  2. s5220 mất đèn
    By ĐôngSơn_mobile in forum Các loại máy khác của Samsung
    Bài viết cuối: 29-04-2013, 20:01
  3. ứng dụng s5220
    By quocdungayp in forum BB5
    Bài viết cuối: 30-03-2013, 12:40
  4. ss s5220 gọi đến tự khởi động lại.
    By ♠mobilebien™♂ in forum Phần mềm Samsung
    Bài viết cuối: 17-01-2013, 18:01
  5. samsung s5220 cần giúp !!! thaks
    By newnice in forum Phần mềm Samsung
    Bài viết cuối: 12-11-2012, 10:05
