Kết quả 1 tới 10 của 12
    Thành viên kỳ cựu dinhhieu444's Avatar
    ĐỒNG NAI
    Mặc định HEPL write imei n72 bao loi Not supported flash chip, please disable
    ĐIỆN THOẠI N72 E NHẬN LẠI CỦA HÀNG ĐANG SÀI LỖI TIN NHẮN FLASH ĐỦ KIỂU NGỦ LUÔN NÊN ĐƯA CHO EM CỨU EM E FLASH JAF VÀ HWK KHÔNG ĐƯỢC ,BẤM NGUÔN LÊN KIM ĐỨNG , EM LẤY JAF BACKUP IMAI LẠI DÙNG FILE XÓA FLASH TRẮNG FLASH LẠI FIMWARER LEN NGUỒN BANH IMAIL EM DÙNG MX WRITE REPAIR VẪN KHÔNG ĐƯỢC AE AI CÓ GIẢI PHÁP GIÚP EM MOT VÉ OR BOX NÀO WRITE IMAIL N72 ĐƯỢC MẤY ANH ?
    LOG
    Imei: 35572102585875
    MXKEY [MxKey Team HTI PLUS Flasher Interface 3], SN: C087AD82
    Using device: HTI, FW ver: 00.50, SN: 01009649
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
    APE Data :
    SYSTEM ASIC ID: 17100701 [OMAP1710 ver: 1.1]
    ASIC MODE ID: 00
    PUBLIC ID: 24B92D533D2B6FEBCD18223028177F9BE5BE923C
    ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000
    ROM ID: AB5E4ADB27A06946
    CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006000C192101012200 [RAP3G ver: PA 2.2]
    EM0 ID: 00000232
    EM1 ID: 00000353
    PUBLIC ID: 16D0011744CA4F5134B007EC3BCB4A1FC102ADF0
    ASIC MODE ID: 00
    ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14
    ROM ID: F28A211FCEA7B19D
    SecondaryBoot: RAP3Gv30_2nd.fg [BB5] version: 11.34.0 revision: 3.0 size: 0x3B80
    eBB5ProtocolType: NEW
    TransmissionMode: DDR&TX2
    Storage2: 0001 2B7E - 0000 0121 [AMD S29NS064N,64 Mbits] type: FLASH,NOR, asic:CMT
    Not supported flash chip, please disable "Use New Protocol for RAP3GV3" in config
    Phone type: RM-180 (Nokia N72)
    SW version: V 05wk07v47 30-01-07 RM-180 (c) Nokia.
    Imei plain: 12345610654321-?
    Battery voltage: 4615 mV, current: 0 mA
    Language Pack:
    - not available.
    SLPA ver[1]: PA_SL (15 digit NCK)
    Imei plain is invalid !!!
    Imei net: 12345610654321?
    Version: SIMLOCK SERVER VERSION 58
    Provider: Hutchison 3G UK Ltd. , Country: United Kingdom
    Counter: 0/3, 0/10
    CONFIG_DATA: 2342000000000000
    BLOCK1: 1=OPEN
    BLOCK2: 1=OPEN
    BLOCK3: 1=OPEN
    BLOCK4: 1=OPEN
    DINHHIEUMOBILE444 _ WELLCOM SỬA CHỮA ALL MOBILE
    444 TRẢNG BOM-ĐỒNG NAI : 0909613891
    Thành viên tích cực BMmobile's Avatar
    Dec 2012
    buz yahoo lên làm giúp bạn wa teamviwer nhé
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    lấy box khác viết vào coi có được không ?
    còn không thì coppy đoạn NPC đó sang rpl con n72 nào đó viết lại
    ĐỒNG NAI
    Trích Được post bởi bmmobile Xem bài viết
    a co yahoo không cho em với
    ĐỒNG NAI
    Flash Loader directory(C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\12.14.001.4\) does not exists, please select the correct path !
    APE Data :
    ASIC MODE ID: 00
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    SecondaryBoot: RAP3Gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00
    Supported Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200
    eBB5ProtocolType: OLD
    Storage0: 0001 0033 - 0000 0121 [AMD S29NS064N,64 Mbits] type: FLASH,NOR, asic:CMT
    TransmissionMode: 16Bit
    ERROR: Packet Error(0xAA), code 0xC2000002
    loader not responding (020000C2C00000)
    Battery voltage: 4682 mV, current: 0 mA
    Language Pack:
    - not available.
    Counter: 0/3, 0/10
    BLOCK1: 1=OPEN
    BLOCK2: 1=OPEN
    BLOCK3: 1=OPEN
    BLOCK4: 1=OPEN
    Thành viên tích cực KIÊN NGUYỄN MOBILE's Avatar
    Feb 2010
    TP HCM
    Trích Được post bởi BMmobile Xem bài viết
    kêu buz yahoo nhưng đâu thấy yahoo đâu mà buz BMmobile
    Feb 2012
    tây ninh
    đá con flash lại write là ok ah.gặp hoài kiểu này
    Dec 2012
    tuyetnhi200523@yahoo.com nhé em nokiachuong20
    ĐỒNG NAI
    Trích Được post bởi thuanwhisky90 Xem bài viết
    làm theo bạn rồi vẫn chưa được hix
    ĐỒNG NAI
    buzz yahoo chua thay hồi âm
  1. giải pháp Flash 1202 chip infineon ok 100% không lock chip by Volcano
    By thanhtienmobile499 in forum Phần mềm và các mã lệnh
    Bài viết cuối: 23-01-2014, 16:00
  2. VolcanoBox 2.1.0 Update SPD Android Imei now 95% SPD Androind Supported for imei
    By Lính Khang in forum THÔNG TIN CẬP NHẬT MỚI NHẤT CỦA THIẾT BỊ
    Bài viết cuối: 15-05-2013, 21:58
  3. SamSung 8600 2 sim chip SpreadTrum SC6800H Write Flash ok by Volcano.
    By thanhdatvt_mobile in forum Phần mềm và các mã lệnh
    Bài viết cuối: 22-03-2012, 14:52
  4. World First MTK Android Read Flash and Imei Change Supported !!
    By HoangThong_hotrokythuat5 in forum Volcano Box
    Bài viết cuối: 06-03-2012, 08:33
  5. Trả lời: 1
    Bài viết cuối: 08-08-2008, 07:58
