Tình hình mình chạy mx box bằng usb mà nó toàn báo lỗi vậy không mình đã thử trên nhiều model.ae nào biết nó bị sao và cách khắc phục xin ý kiến mọi ngừoi.thanks ae quan tâm.
MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C085CB01
Using device: USB ROM and HTI, FW ver: 00.50, SN: 0100EB03
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.75
Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0]
CMT EM0 ID: 00005361
CMT PUBLIC ID: 0000000000CCD260D75359DF1ADF1F6753183B64
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
CMT ROM ID: DE56D582BDDE7A3A
Loading CMT secondary boot code
SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940
Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage2: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,NOR, asic:CMT
Storage4: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D
Update server code loaded.
Waiting for USB device removal ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 3385C6E9
FUR: Adding Asic CMT as client OK.
CMT PAPUBKEYS HASH: E9700989029D9E899915F781B1582048E042A738
Original Imei: 35193305717568
Original Product code: 059F3H9
Bluetooth ID: F48E09A4EB5E
SIMLOCK PA identifier:
[0] PA_SIMLOC30
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Open device failed: FFFFFFFF (4) The system cannot open the file
Warning: Phone did not reboot to normal mode.
[RebootFromFlashMode] Please press "OK" or "Accept" on your phone (if SIM Card is not inserted to the phone) !
			 MX Box flash USB
 MX Box flash USB
