Kết quả 1 tới 10 của 11
    Thành viên tích cực caokyit's Avatar
    Nov 2010
    468 Hùng Vương-Tam Kỳ - Quảng Nam
    Mặc định x2-01 chạy phần mềm lỗi: Warning: Phone did not reboot to normal mode cần giúp
    Tình hình là máy khởi động lên đến menu là trắng màn hình sau đó tắt ngúm lun.mình chạy lại nhưng báo lỗi.ae xem log và giúp mình với
    MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C0874A13
    Using device: USB Phonet and HTI, FW ver: 00.50, SN: 0100AF22
    Connection status: EHCI:HUB:USB 2.00 (High-speed)
    Driver: nmwcdnsuc, ver: 7.1.32.75
    Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
    Phone detected in ADL mode, flash backup skipped.
    Processing MCU file: rm709__08.70.mcusw
    [BB5,XSR 1.6] size: 26.61 MB
    Supported Ids: 2200050920030000, 22000509200C0000
    Waiting for USB ROM device ...
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 17B1488A
    CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0]
    CMT EM0 ID: 00005361
    CMT PUBLIC ID: 0000000000AABB50115EEE46D2B1ED212671D24F
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
    CMT ROM ID: DE56D582BDDE7A3A
    Loading CMT secondary boot code
    SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940
    Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
    eBB5ProtocolType: NEW
    Secondary boot loaded.
    Storage2: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,NOR, asic:CMT
    Storage3: 0010 0011 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.6
    Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D
    Update server code loaded.
    Waiting for USB device removal ...
    FUR: Adding Asic CMT as client OK.
    Reading CMT HWC (0xD4 bytes).
    Reading CMT R&D (0x0 bytes).
    RPL(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35484204520614_CE RT.rpl).
    CMT PAPUBKEYS HASH: 37955B6FC432998EF0DB240E332228384D19ED09
    Storing certificate [NPC, CCC, HWC, RND, R&D] ...OK
    Partitioning....
    Partitioning complete
    Erase size: 33.88 MB
    CMT FLASH,MuxOneNAND area [00000000-0001FFFF]
    CMT FLASH,MuxOneNAND area [00020000-000203FF]
    CMT FLASH,MuxOneNAND area [00060000-012FFFFF]
    CMT FLASH,MuxOneNAND area [01300000-01DFFFFF]
    CMT FLASH,MuxOneNAND area [02600000-029FFFFF]
    Formating partition ...
    Flash programming ...
    CMT KEYS block sent
    CMT ADA block sent
    CMT PRIMAPP block sent
    CMT RAP3NAND block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 37955B6F [] sent
    CMT UPDAPP block sent
    CMT MCUSW block sent
    CMT MCUSW1 block sent
    CMT GENIO_INIT block sent
    CMT ISA+DYNSW block sent
    Programming completed in 10.641 s
    Processing PPM file: rm709__08.70.ppm_t
    [BB5,XSR 1.6] size: 6.80 MB
    Erase size: 8 MB
    CMT FLASH,MuxOneNAND area [01E00000-025FFFFF]
    Programming completed in 2.579 s
    Processing CNT file: rm709__08.70_003.image_t_ctv_ph_9g4b0
    [BB5,XSR 1.6] size: 29.05 MB
    Erase size: 75.31 MB
    CMT FLASH,MuxOneNAND area [02A00000-0753FFFF]
    Programming completed in 11.234 s
    Total time for flashing process(boot+erase+write) was 53.187 s
    Open device failed: FFFFFFFF (4) The system cannot open the file
    Warning: Phone did not reboot to normal mode.
    [RebootFromFlashMode] Please press "OK" or "Accept" on your phone (if SIM Card is not inserted to the phone) !
    TP Hồ Chí Minh
    không đồng bộ đc, có box khác bỏ qua chạy lại thử xem.
    Jan 2012
    bác thay cáp khác hoặc cho vào best chạy xem thế nào
    best chay ngon lắm lắm
    manhdung81mobile@gmail.com
  4. ( manhdung81mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    songhuynh1988 (12-03-2013)
    ko dc chiến phonnix xem sao
    yh chanyenmobile_led1202
    ctk hà Văn Yên face hachanyen
    sdt zalo..0972444489
    BỘ ngoại giao trùm các 4r
    chạY băngd usb pin phải đây nhé mà a e chú y dong x2 mình chay ko dòng bộ dc mà máy vẫn lên nguôn bt thế mới lạ chứ x2-01 x2 nhỏ cũng vật mình đa chyaj rât nhiu rồi ko đòng bộ ma vân sai bt chay usb wa mxbox chúc a e thành công
    Thành viên chính thức bumbum_94210's Avatar
    Dec 2011
    phonenix hay BEST infinity crack cũng đc
    Thành viên tích cực trong_mobile's Avatar
    Jun 2012
    Sao không múc Phoenix sẽ hay hơn không .........dễ kiếm tra hơn.....
    Có khi nào trên đường đời tấp nập
    Ta vô tình vấp phải cục iphone
  9. #8
    Thành viên mới hp9088's Avatar
    Feb 2011
    Trích Được post bởi trong_mobile Xem bài viết
    cac bac oi giup em voi
  10. #9
    May 2014
    CẨM KHÊ-PHÚ THỌ
    Trích Được post bởi hp9088 Xem bài viết
    chạy ver cao nhất chuyển qua tool khác hoặc box khác xem sao.không được thì tháo camera ra rồi chạy lại ok
    0985210545
  11. #10
    Thành viên mới nokia305's Avatar
    Aug 2014
    toi cung bi vay anh em nao con file pm khac ko
  1. Trả lời: 5
    Bài viết cuối: 20-10-2012, 12:36
  2. Trả lời: 6
    Bài viết cuối: 26-09-2012, 14:54
  3. Trả lời: 16
    Bài viết cuối: 13-09-2011, 10:00
  4. Trả lời: 3
    Bài viết cuối: 28-02-2010, 00:55
  5. ko vào được chế độ local mode hoặc tét mode
    By dongxoai mobile in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 19-09-2009, 20:32
