tinh hình là em có cây c2-01 bi châp treo lên đến 0;4 em gỡ bluetoot ra thì hết nhưng bật nguồn thì treo 0;1 em lay nguồn ko được chạy lai phần mềm tMXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C087B51C
Using device: USB ROM and HTI, FW ver: 00.50, SN: 01009848
Connection status: UHCI:HUB::USB 2.00 (Full-speed)
Driver: NMWCD, ver: 7.1.32.75
Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
Processing MCU file: rm721__11.20.mcusw
[BB5,XSR 1.6] size: 28.57 MB
Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000010000022600000001020C192102044100 [RAPS2 ver: PA 4.x]
CMT EM0 ID: 00001051
CMT EM1 ID: 00001060
CMT PUBLIC ID: 22F001084D61114958B81330D779368E7D917ED9
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D
CMT ROM ID: 67E82268F29CEA60
Loading CMT secondary boot code
SecondaryBoot: RAP3Gv40_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3AC0
Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Algorithm: RAP3Gv40_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0x91BD2
Update server code loaded.
Waiting for USB device removal ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 14B948AE
FUR: Adding Asic CMT as client OK.
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
RPL(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35193605741935_CE RT.rpl).
CMT PAPUBKEYS HASH: 8443ECD57D2EDADDAADBAD248F1B3B559E14D184
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 37.69 MB
CMT FLASH,MuxOneNAND area [00020000-000203FF]
CMT FLASH,MuxOneNAND area [00060000-0009FFFF]
CMT FLASH,MuxOneNAND area [000A0000-0025FFFF]
CMT FLASH,MuxOneNAND area [003E0000-005DFFFF]
CMT FLASH,MuxOneNAND area [005E0000-010DFFFF]
CMT FLASH,MuxOneNAND area [01EC0000-01EDFFFF]
CMT FLASH,MuxOneNAND area [027C0000-02CBFFFF]
CMT FLASH,MuxOneNAND area [077C0000-07B3FFFF]
CMT FLASH,MuxOneNAND area [010E0000-01EBFFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 8443ECD5 [] sent
CMT RAP3NAND block sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
CMT MCUSW1 block sent
CMT GENIO_INIT block sent
CMT ISA+DYNSW block sent
Programming completed in 35.281 s
Processing PPM file: rm721__11.20.ppm_v
[BB5,XSR 1.6] size: 7.35 MB
Erase size: 8.87 MB
CMT FLASH,MuxOneNAND area [01EE0000-027BFFFF]
Programming completed in 9.031 s
Processing CNT file: rm721__11.20.image_v_059G361_005
[BB5,XSR 1.6] size: 18.76 MB
Erase size: 75.06 MB
CMT FLASH,MuxOneNAND area [02CC0000-077BFFFF]
Programming completed in 23.610 s
Total time for flashing process(boot+erase+write) was 1 min 17.250 s
Open device failed: FFFFFFFF (4) The system cannot open the file
Warning: Phone did not reboot to normal mode.
hì nó như thế này mong các bác giúp em với
			 c2-01 xin giúp
 c2-01 xin giúp
