đây là log flash
Version from phone: 32.001
Version from file: 32.001
MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C087C5B9
Using device: HTI, FW ver: 00.50, SN: 0100E833
Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7600.16385
Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
Reading RPL backup ...
Reading Phone IDs ...
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 1820010206710052D1EDF828E493819F5B914947
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.34.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.34.0 revision: 2.0 size: 0x8FE30
CMT PAPUBKEYS HASH: B2075F4B793BB9017C8C0097C783C543F2A6A303
PRIVATE ID: DDDA30C10960FA60BC1BD2D14C42B17C24601E74
E-FUSE: 65FF8B12
SEC ROM CRC: 3E691FF8
productData saved.
Restarting phone ...
Reading Secure Storage ...
Reading Important data ...
Reading SIMLOCK data ...
Reading CERT data ...
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 10.48.1 revision: 2.0 size: 0x3B80
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 10.48.1 revision: 2.0 size: 0x84B10
Reading CMT NPC (0x190 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Flash Imei: 35638702200961
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
SUPERDONGLE_KEY_DATA saved OK
CMLA_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35638702200961_BA CK.rpl"
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Processing MCU file: RM-348_32.001_prd.core.fpsx
[BB5,XSR 1.5] size: 103.56 MB
Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103
Storing certificate [NPC, CCC, HWC, R&D] ...Error
Erase size: 165.19 MB
CMT FLASH,MuxOneNAND area [00040000-00082FFF]
CMT FLASH,MuxOneNAND area [00083400-003FFFFF]
CMT FLASH,MuxOneNAND area [00800000-00D5FFFF]
CMT FLASH,MuxOneNAND area [00D60000-0A95FFFF]
Formating partition ...
Prog.status for Asic CMT ...
Flash programming ...
Error while programming [00] at 0x00000000, Result: 0000
Task failed at (0800001C)!!!
Last RX buffer:
máy xài full.nhưng chỉnh sáng tối Mh ko đc.flash thì bị lỗi ae xem giùm cái
đây là busceck
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Selected firmware certificate matched.
Original Imei: 35638702200961
Original Product code: 0572739
Bluetooth ID: 0023B4B3B129
WLAN ID: 0023B4B3EFA9
SIMLOCK PA identifier:
[0] PA_SL2
Phone type: RM-348 (Nokia N79)
SW version: V ICPR72_09w18.4 14-10-09 RM-348 (c) Nokia
ApeCoreSw: 32.001
Imei plain: 35638702200961-8
Battery voltage: 4491 mV, current: 52 mA
Language Pack:
- not available.
SLPA ver[3]: PA_SL2/PA_SL3 (15 digit NCK)
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 356387022009618
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
			 ae xem giùm log N79
 ae xem giùm log N79
