Em khởi động dòng lên 02 rồi treo ở đó, chạy PM thì nó như thế này:
MXKEY [MxKey Team HTI PLUS Flasher Interface 3], SN: C087ACC6
Using device: USB ROM and HTI, FW ver: 00.50, SN: 0100987B
Connection status: EHCI:HUB:HUB::USB 2.00 (Full-speed)
Driver: NMWCD, ver: 7.1.32.75
Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
Processing MCU file: rm243_07.02_prd_core.fpsx
[BB5,XSR 1.5] size: 23.98 MB
Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101031105, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103, 4003192101051105, 400C192101051105
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 1E90001665870052F25C1B00B5FD3ABE386797A5
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT ROM ID: 4B9B75103E691FF8
Loading CMT secondary boot code
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0030 - 0000 0221 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F
Update server code loaded.
FUR: Adding Asic CMT as client OK.
CERT backup skipped due to protocol limitation.
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 74.81 MB
CMT FLASH,MuxOneNAND area [00040000-00082FFF]
CMT FLASH,MuxOneNAND area [00083400-0087FFFF]
CMT FLASH,MuxOneNAND area [00B80000-04DFFFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
Selecting first CMT PAPUB block with matching RootKey.
CMT PAPUBKEYS: 0FE1BA92 [RAP Certificate 68 v1] sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT SOS*ISASW block sent
CMT SOS*CORE block sent
CMT SOS+ROFS block sent
Programming completed in 52.156 s
Processing PPM file: rm243_07.02_prd_vAP06_01_taiwan.fpsx
[BB5,XSR 1.5] size: 21.59 MB
Erase size: 27 MB
CMT FLASH,MuxOneNAND area [03300000-04DFFFFF]
CMT SOS+ROFX block sent
Programming completed in 52.000 s
Processing CNT file: rm243_07.02_prd_UDA_Pearl_White.fpsx
[BB5,XSR 1.5] size: 111.32 KB
Erase size: 45.25 MB
CMT FLASH,MuxOneNAND area [04E00000-07B3FFFF]
Programming completed in 1.094 s
Processing CNT file: rm243_ENO_A_2009wk15v0.100.fpsx
[BB5,XSR 1.5] size: 1.41 MB
Erase size: 3 MB
CMT FLASH,MuxOneNAND area [00880000-00B7FFFF]
CMT SOS*ENO block sent
Programming completed in 3.422 s
Total time for flashing process(boot+erase+write) was 2 min 1.937 s
Waiting for USB device removal ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2A723007
Ai đã làm qua rồi xin chỉ giúp với??
			 6120c mất nguồn
 6120c mất nguồn
