máy bật nguồn lên vào nhận trắng màn hình rồi cụp nguồn luôn.khách bảo đang gọi bị luôn.em đã flas lại nhưng vẫn vậy.nhờ anh em giúp thank a.đây là lock của nó.
MXKEY [FT SCR2000 0], SN: C08318D2
Using device: USB ROM
Connection status: EHCI:HUB:HUB::USB 2.00 (Full-speed)
Driver: nmwcdnsuc, ver: 7.1.32.75
Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
Processing MCU file: rm578__10.47.mcusw
[BB5,BB5 ALGORITHM] size: 21.65 MB
Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000010000022600010006030C192101023000 [RAP3G ver: PA 3.0]
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 13300016609F04566213AE049F03AECD747A2ED5
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT ROM ID: 273F6D55DFAAF68F
Flashing CMT Update Server Data, ULO: 0x3900 bytes
Update Server code succesfully sent to phone.
Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes
Flashing CMT Update Server Data, PASUBTOC: 0x59980 bytes
Waiting for USB device removal ...
Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 2A42FBB3
Verifying communication to device OK.
Erase size: 23.25 MB
CMT FLASH,NOR area [00000000-000006BF] erased in 0.560 s
CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.548 s
CMT FLASH,NOR area [00040000-000BFFFF] erased in 1.956 s
CMT FLASH,NOR area [000C0000-0013FFFF] erased in 2.144 s
CMT FLASH,NOR area [00140000-0155FFFF] erased in 1 min 20.425 s
CMT FLASH,NOR area [01560000-0175FFFF] erased in 7.963 s
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
Selecting first CMT PAPUB block with matching RootKey.
CMT PAPUBKEYS: 8669C775 [RAP Certificate 215 v1] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
Programming completed in 1 min 49.761 s
Processing PPM file: rm578__10.47.ppm_v
[BB5,BB5 ALGORITHM] size: 6.78 MB
Erase size: 8.62 MB
CMT FLASH,NOR area [01760000-01FFFFFF] erased in 35.090 s
Programming completed in 34.611 s
Processing CNT file: rm578__10.47.image_v_black_v2
[BB5,BB5 ALGORITHM] page size: 128 K size: 15.64 MB
Erase size: 31.75 MB
CMT FLASH,NOR area [02000000-0245FFFF] erased in 19.085 s
CMT FLASH,NOR area [02460000-03FBFFFF] erased in 1 min 50.642 s
Programming completed in 1 min 18.341 s
Total time for flashing process(boot+erase+write) was 8 min 29.494 s
Phone not found, retrying ...
Device connected: nmwcdc\Nokia 2730 classic USB Phonet, PORT_ID: 1D664B59
Phone type: RM-578 (Nokia 2730 classic)
SW version: V 10.47 27-08-10 RM-578 (c) Nokia
Imei plain: 35626104601019-3
Product code: 059C0H1
Battery voltage: 3969 mV, current: 65 mA
Language Pack:
- not available.
Camera config: NI00IIIIRR030102F201, ver: 006.006
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 356261046010193
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
Market items is empty, please select the correct products path !
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
SERVICE CENTER... OK
SOFTWARE UPGRADE... OK
PRODUCTION TUNING... OK
Reset User Code (to default:12345) ... OK
Completed in 1.434 s
Completed in 1.144 s
đây là lock của nó.
