Kết quả 1 tới 10 của 15
    Thành viên tích cực TÍNH-NGHI_MOBILE's Avatar
    Feb 2011
    Mặc định xin giúp x1-01 rơi nước mất nguồn
    nokia x1-01 rơi nước mất nguồn....vệ sinh kỹ....not ok...có dao động 1-2..đã thay mh vẫn vậy.nhờ ae giúp với.và đay là log em nó.buschek va flahs+info lun
    08:36:00 : Advance Turbo Flasher Found
    08:36:00 : ================================================
    08:36:00 : Driver Version : 00020824
    08:36:00 : Library Version : 00030207
    08:36:02 : Box Type : AdvanceBox Turbo
    08:36:02 : Box Firmware : LogiCore 10.3.30
    08:36:02 : Software Version : v9.61
    08:36:02 : AdvanceBox SN : E2D37D6EC2374746DE92DADD
    08:36:02 : Box Status : ACTIVATED
    08:36:02 : ================================================
    08:36:02 : Box Successfully Initialized
    08:36:02 :
    08:36:02 : VBATT Powering Down <<<<
    08:36:07 : VBATT Powering Up >>>>
    08:36:07 : SET VCCIO Level Done
    08:36:07 : SET BSI Load Done
    08:36:07 :
    08:36:07 :
    08:36:07 :
    08:36:07 : ///////// /// /// /////// /////// /////////
    08:36:07 : /// /// /// /// // /// /// /// ///
    08:36:07 : /// /// /// /////// /////// /// ///
    08:36:07 : /// /// /// /// /// /// /// /// ///
    08:36:07 : /// ///// /// /// /////// //////
    08:36:07 :
    08:36:07 : =======================================
    08:36:07 : /// /// /// ///////// /////// //////
    08:36:07 : ///// /// /// /// /// // /// ///
    08:36:07 : /// ///// /// /// /////// /// ///
    08:36:07 : /// //// /// /// /// /// /// ///
    08:36:07 : /// /// /// /// /// /// //////
    08:36:07 :
    08:36:15 : Make sure that you plugged the cable to the
    08:36:15 : RJ-45 Port Marked << EXTENSION >>
    08:36:15 :
    08:36:15 : =======================================
    || FLASHBUS EXTENSION ||
    || | | (O) (O) (O) | CABLE | ||
    PLUG IN
    CABLE HERE
    08:36:20 : VBATT Powering Down <<<<
    08:36:23 : VBATT Powering Up >>>>
    08:36:23 : SET VCCIO Level Done
    08:36:23 : SET BSI Load Done
    08:36:23 :
    08:36:23 : Booting Phone...
    08:36:24 : CPU ID Response: A200341100
    08:36:24 : CPU Type: XG110 2.1B
    08:36:24 : Phone Booted at after First attempt...
    08:36:24 :
    08:36:24 : ************************************************** ****
    08:36:24 : START INFINEON BUS CHECK
    08:36:24 :
    08:36:24 :
    08:36:24 : Sending PBL 37888 bytes...
    08:36:24 : PBL Successfully Sent...
    08:36:24 : Sending SBL 65024 bytes...
    08:36:25 : SBL Successfully Sent...
    08:36:25 :
    08:36:25 : Flash Chip Manufacturer: STMicroelectronics
    08:36:25 : Flash Chip Type: M58WR064 64 Mbit (4Mb x 16) NOR
    08:36:25 : Extended Information: Multiple Bank / Burst / 1.8v
    08:36:25 :
    08:36:25 : ************************************************** ****
    08:36:25 : INFINEON BUS CHECK DONE
    08:36:25 :
    08:36:27 :
    08:36:28 : MCU: V 07.50 29-11-11 RM-713 (c) Nokia
    08:36:28 : IMEI: 354602059013222
    08:36:28 : Product Serial Number: C88BBA8AH
    08:36:28 : Product Code : 059D8Q7
    08:36:30 : Basic Production Code: 0204727
    08:36:30 : PPM SW Version : V 07.50 29-11-11 RM-713 (c) Nokia MR
    08:36:30 : ADSP Version : p V 07.50\n29-11-11\nRM-713\n(c) NMP\nmr
    08:36:30 : MCU SW Version : V 07.50 29-11-11 RM-713 (c) Nokia
    08:36:30 : HW Version : 1002
    08:36:31 : UEM Version : 1328
    08:36:31 : UPP Version : 8850
    08:36:31 : LCD Version : WIN:BAFFINv80 NT39121
    08:36:33 : ********** SIMLOCK INFO **********
    08:36:33 : CONFIG_DATA : 0010100000000000
    08:36:33 : PROFILE_BITS : 0000000000040002
    08:36:33 : ASIC : 11
    08:36:33 : PROVIDER : Default Test Operator
    08:36:33 :
    08:36:34 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
    08:36:34 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
    08:36:34 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
    08:36:34 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
    08:36:34 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
    08:36:34 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
    08:36:34 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
    08:36:34 : ST_LCD_TEST : PASSED
    08:36:34 :
    08:36:37 :
    08:36:37 : Make sure you have installed the
    08:36:37 : COMPLETE Flash Package for this Phone...
    08:36:37 :
    08:36:37 : Goto "Settings" --> "Nokia Settings" and verify that
    08:36:37 : the Folder where you installed your Flash Files are
    08:36:37 : in the "PRODUCT PATH TO SCAN" List...
    08:37:34 :
    08:37:34 : Only Phoenix.ini Flash Files are
    08:37:34 : supported for Checksum Verification...
    08:37:35 : VBATT Powering Down <<<<
    08:37:39 : VBATT Powering Up >>>>
    08:37:39 : SET VCCIO Level Done
    08:37:39 : SET BSI Load Done
    08:37:39 :
    08:37:39 : Booting Phone...
    08:37:39 : CPU ID Response: A200341100
    08:37:39 : CPU Type: XG110 2.1B
    08:37:39 : Phone Booted at after First attempt...
    08:37:39 :
    08:37:39 : ************************************************** ****
    08:37:39 : TIME STARTS HERE
    08:37:39 :
    08:37:39 :
    08:37:39 : Sending PBL 19456 bytes...
    08:37:39 : PBL Successfully Sent...
    08:37:39 :
    08:37:39 : Sending SBL 65024 bytes...
    08:37:40 : SBL Successfully Sent...
    08:37:40 :
    08:37:40 : Flash Chip Manufacturer: STMicroelectronics
    08:37:40 : Flash Chip Type: M58WR064 64 Mbit (4Mb x 16) NOR
    08:37:40 : Extended Information: Multiple Bank / Burst / 1.8v
    08:37:40 :
    08:37:40 : Processing Image File: E:\FILE-NOKIA\RM-713-X1-01\rm713_007.500
    08:37:40 :
    08:37:40 : FIRMWARE Image Found...
    08:37:40 : Number of Sections: 03
    08:37:40 : FIRMWARE Certificate Block Sent Successfully...
    08:37:40 : Processing Section 01 of 03
    08:37:40 : FIRMWARE Erase Block: 0x00000000~0x0001FFFE
    08:37:40 : Start Erasing...
    08:37:40 : Erasing Please Wait...
    08:37:42 : Block Erase Done...
    08:37:42 : Preparing Data Blocks...
    08:37:42 : Data Size: 24576 bytes
    08:37:42 : Data Checksum: 55FD
    08:37:42 : Uploading Data Blocks to phone...
    08:37:42 : FIRMWARE Data Blocks uploaded to phone...
    08:37:42 : Processing Section 02 of 03
    08:37:42 : FIRMWARE Erase Block: 0x00800000~0x00BFFFFE
    08:37:42 : Start Erasing...
    08:37:42 : Erasing Please Wait...
    08:38:20 : Block Erase Done...
    08:38:20 : Preparing Data Blocks...
    08:38:20 : Data Size: 4128768 bytes
    08:38:20 : Data Checksum: AA06
    08:38:20 : Uploading Data Blocks to phone...
    08:39:08 : FIRMWARE Data Blocks uploaded to phone...
    08:39:08 : Processing Section 03 of 03
    08:39:08 : FIRMWARE Erase Block: 0x00C5D000~0x00E5FFFE
    08:39:08 : Start Erasing...
    08:39:08 : Erasing Please Wait...
    08:39:27 : Block Erase Done...
    08:39:27 : Preparing Data Blocks...
    08:39:27 : Data Size: 1697536 bytes
    08:39:27 : Data Checksum: C1B9
    08:39:27 : Uploading Data Blocks to phone...
    08:39:47 : FIRMWARE Data Blocks uploaded to phone...
    08:39:47 : Start Data Verification... (Please wait)
    08:39:51 : Data Verification Successful...
    08:39:51 :
    08:39:51 :
    08:39:51 : Processing Image File: E:\FILE-NOKIA\RM-713-X1-01\rm713_007.50mr
    08:39:52 :
    08:39:52 : PPM Image Found...
    08:39:52 : Number of Sections: 01
    08:39:52 : PPM Certificate Block Sent Successfully...
    08:39:52 : Processing Section 01 of 01
    08:39:52 : PPM Erase Block: 0x00100000~0x006120BE
    08:39:52 : Start Erasing...
    08:39:52 : Erasing Please Wait...
    08:40:40 : Block Erase Done...
    08:40:40 : Preparing Data Blocks...
    08:40:40 : Data Size: 5316800 bytes
    08:40:40 : Data Checksum: 93CE
    08:40:40 : Uploading Data Blocks to phone...
    08:41:43 : PPM Data Blocks uploaded to phone...
    08:41:43 : Start Data Verification... (Please wait)
    08:41:43 : Data Verification Successful...
    08:41:43 :
    08:41:43 :
    08:41:43 : Processing Image File: E:\FILE-NOKIA\RM-713-X1-01\rm7130_nai07.50mr
    08:41:43 :
    08:41:43 : CONTENT Image Found...
    08:41:43 : Number of Sections: 01
    08:41:43 : CONTENT Certificate Block Sent Successfully...
    08:41:43 : Processing Section 01 of 01
    08:41:43 : CONTENT Erase Block: 0x00E60000~0x00F0E53E
    08:41:43 : Start Erasing...
    08:41:43 : Erasing Please Wait...
    08:41:50 : Block Erase Done...
    08:41:50 : Preparing Data Blocks...
    08:41:50 : Data Size: 714048 bytes
    08:41:50 : Data Checksum: 111B
    08:41:50 : Uploading Data Blocks to phone...
    08:41:59 : CONTENT Data Blocks uploaded to phone...
    08:41:59 : Start Data Verification... (Please wait)
    08:41:59 : Data Verification Successful...
    08:41:59 :
    08:41:59 :
    08:41:59 : Exit Flash Mode Done...
    08:41:59 : Time Elapse : 00:04:19
    08:42:02 :
    08:42:02 : ************************************************** ****
    08:42:02 : You must Factory Reset the phone to enable the
    08:42:02 : ringtones and other customized settings to work
    08:42:02 :
    08:42:02 :
    08:42:02 : Waiting For Phone to go Online...
    08:42:02 :
    08:42:02 : 5,
    08:42:02 : 4,
    08:42:02 : 3,
    08:42:03 : 2,
    08:42:03 : 1...
    08:42:03 :
    08:42:03 : MCU: V 07.50 29-11-11 RM-713 (c) Nokia
    08:42:03 : IMEI: 354602059013222
    08:42:04 : Product Serial Number: C88BBA8AH
    08:42:04 : Product Code : 059D8Q7
    08:42:04 : Module Code : 0204727
    08:42:04 : Basic Production Code: 059N2M2
    08:42:04 : PPM SW Version : V 07.50 29-11-11 RM-713 (c) Nokia MR
    08:42:04 : ADSP Version : p V 07.50\n29-11-11\nRM-713\n(c) NMP\nmr
    08:42:05 : MCU SW Version : V 07.50 29-11-11 RM-713 (c) Nokia
    08:42:05 : HW Version : 1002
    08:42:14 : ********** SIMLOCK INFO **********
    08:42:14 : ERROR : Unable to read Simlock Info ...
    08:42:14 : Maybe you are reading BB5 phone ...
    08:42:15 : ST_LCD_TEST : PASSED
    08:42:15 :
    08:42:15 : WARNING: DCC Unavailable in Current State
    08:42:15 : Change Phone Mode to TEST MODE
    08:42:15 :
    08:42:16 :
    08:42:16 : FACTORY SET TO : Full Factory Set
    08:42:18 : FAILED
    08:42:18 : FACTORY SET TO : User Data
    08:42:19 : FAILED
    08:42:19 : FACTORY SET TO : Leave Factory
    08:42:20 : FAILED
    08:42:20 : FACTORY SET TO : Service Center
    08:42:21 : FAILED
    08:42:21 : FACTORY SET TO : Software Upgrade
    08:42:22 : FAILED
    08:42:22 : FACTORY SET TO : Production Tune
    08:42:24 : FAILED
    08:44:18 :
    08:44:18 : Please Wait while Loading MNC-MCC List...
    08:44:18 : Parsing Entries...
    08:44:20 : Load Done!
    08:44:28 :
    08:44:28 : ERROR: Use Numbers Only
    08:44:40 : Error: This is only for BB5/Infineon XG213
    08:44:44 : ERROR: Input Must be 15 Bytes Long
    08:44:44 : Example: 010203040506070809000102030405
    08:44:49 : VBATT Powering Down <<<<
    08:44:52 : VBATT Powering Up >>>>
    08:44:52 : SET VCCIO Level Done
    08:44:52 : SET BSI Load Done
    08:44:52 :
    08:44:52 : Booting Phone...
    08:44:52 : CPU ID Response: A200341100
    08:44:52 : CPU Type: XG110 2.1B
    08:44:52 : Phone Booted at after First attempt...
    08:44:52 :
    08:44:52 : ************************************************** ****
    08:44:52 : START INFINEON BUS CHECK
    08:44:52 :
    08:44:52 :
    08:44:52 : Sending PBL 37888 bytes...
    08:44:53 : PBL Successfully Sent...
    08:44:53 : Unique Data: A0900131020081809D15
    08:44:53 : Sending SBL 65024 bytes...
    08:44:54 : SBL Successfully Sent...
    08:44:54 :
    08:44:54 : Flash Chip Manufacturer: STMicroelectronics
    08:44:54 : Flash Chip Type: M58WR064 64 Mbit (4Mb x 16) NOR
    08:44:54 : Extended Information: Multiple Bank / Burst / 1.8v
    08:44:54 :
    08:44:54 : Dumping: PMM Plain
    08:45:01 : Dumping: PMM Protected
    08:45:03 : PMM Dump Done...
    08:45:03 :
    08:45:03 : Reading Simlock Information...
    08:45:03 : LOCK: 00000000000400020010100000000000818100080700000000 40000005FFFFFF00A4000005FFFFFF0108000005FFFFFF016C 000005FFFFFF01D0000005FFFFFF0234000005FFFFFF029800 0005FFFFFF000000003F007F206F07FFFFF80002FC03000503 000000003F007F206F3EFFFFC00002FF02000103000000003F 007F206F3FFFFFC000030102000103000000003F007F206F07 FFFF07FE030308000503000000003F007F206F07FFFF07FE03 0B08000503000000003F007F206F07FFFFF800031303000503 000000003F007F206F3EFFFFC000031602000103000000003F 007F206F3FFFFFC000031802000103000000003F007F206F07 FFFF07FE031A08000503000000003F007F206F07FFFF07FE03 2208000503000000003F007F206F07FFFFF800032A03000503 000000003F007F206F3EFFFFC000032D02000103000000003F 007F206F3FFFFFC000032F02000103000000003F007F206F07 FFFF07FE033108000503000000003F007F206F07FFFF07FE03 3908000503000000003F007F206F07FFFFF800034103000503 000000003F007F206F3EFFFFC000034402000103000000003F 007F206F3FFFFFC000034602000103000000003F007F206F07 FFFF07FE034808000503000000003F007F206F07FFFF07FE03 5008000503000000003F007F206F07FFFFF800035803000503 000000003F007F206F3EFFFFC000035B02000103000000003F 007F206F3FFFFFC000035D02000103000000003F007F206F07 FFFF07FE035F08000503000000003F007F206F07FFFF07FE03 6708000503000000003F007F206F07FFFFF800036F03000503 000000003F007F206F3EFFFFC000037202000103000000003F 007F206F3FFFFFC000037402000103000000003F007F206F07 FFFF07FE037608000503000000003F007F206F07FFFF07FE03 7E08000503000000003F007F206F07FFFFF800038603000503 000000003F007F206F3EFFFFC000038902000103000000003F 007F206F3FFFFFC000038B02000103000000003F007F206F07 FFFF07FE038D08000503000000003F007F206F07FFFF07FE03 9508000503FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
    08:45:03 : KEYS: CCFF14F885E904BF86B66662D405DF5905F7085EE311820477 9E3D9D3F0FC7CE880D6ABDB9C11FB164B70CDF174A95D3B9F0 2E52D039C12332255492FA87325C6DA33990B20FB97D4723BC 0DBF39D85F53C4CF6F1364C5916A14185607643AF72B3D94BA 42A4D968297BA8B33EA926CD6B96D7D9F4D424834DB5D79FF6 7709D0A7D5547A059345804576BB959F3307A79F75871B228F D3DDF2A2C85725B845E2
    08:45:03 : SIGN: 98CEE26EE4629582C2590730FBAF75B7A9AFE8A915DE7C16DD 61611C56098AA7FE170AF231F9E2798CA588D52BC08CF75BCF 4AFE0F470B89747A0E3AF4C30BE312B39038CFA1E6BEA2FA99 15A0B2B0265A5E45FF2323E6768666672C6EDB58B542FAE481 D868D753B554B693EA6E5AA0C805F0D1B09F9B24EE512009ED 6B4AB50300
    08:45:03 : CODE: 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000
    08:45:03 :
    08:45:03 : NCK Length: 20-digits (DO NOT BRUTEFORCE)
    08:45:03 : NCK Unlock: True
    08:45:03 :
    08:45:03 : ************************************************** ****
    08:45:03 : INFINEON BUS CHECK DONE
    08:45:03 :
    08:45:04 :
    08:45:04 : Waiting for Phone to Go Online...
    08:45:05 : Elapsed Time: 1s
    08:45:06 : Elapsed Time: 2s
    08:45:07 : Elapsed Time: 3s
    08:45:08 : Elapsed Time: 4s
    08:45:09 : Elapsed Time: 5s
    08:45:10 : Elapsed Time: 6s
    08:45:11 : Elapsed Time: 7s
    08:45:12 : Elapsed Time: 8s
    08:45:13 : Elapsed Time: 9s
    08:45:14 : Elapsed Time: 10s
    08:45:14 :
    08:45:14 : ================================================
    08:45:14 : Basic Phone Information
    08:45:14 : MCU Version: V 07.50 29-11-11 RM-713 (c) Nokia
    08:45:14 : IMEI Plain : 354602059013222
    08:45:14 : IMEI Spare : A354602059013220
    08:45:14 : IMEI SV : 33546020590132257F
    08:45:14 : IMEI (2nd) : 354602059013230
    08:45:14 : IMEI Spare : A354602059013230
    08:45:14 : IMEI SV : 33546020590132357F
    08:45:15 : Phone Type : RM-713
    08:45:15 :
    08:45:15 : ================================================
    08:45:15 : Extended Phone Information
    08:45:15 : Product Serial Number: C88BBA8AH
    08:45:15 : Product Code : 059D8Q7
    08:45:15 : Module Code : 0204727
    08:45:15 : Basic Production Code: 059N2M2
    08:45:15 : PPM SW Version : V 07.50 29-11-11 RM-713 (c) Nokia MR
    08:45:15 : ADSP Version : p V 07.50\n29-11-11\nRM-713\n(c) NMP\nmr
    08:45:16 : MCU SW Version : V 07.50 29-11-11 RM-713 (c) Nokia
    08:45:16 : HW Version : 1002
    08:45:16 : UEM Version : 1328
    08:45:16 : UPP Version : 8850
    08:45:16 : LCD Version : WIN:BAFFINv80 NT39121
    08:45:18 :
    08:45:19 :
    08:45:19 : ==================================================
    08:45:19 : Decrypt XGOLD PM 120 HASHES for Brute Force Unlock
    08:45:19 : Decrypting PM 120...
    08:45:19 :
    08:45:19 : PM 120 HASHES Extracted Successfully
    08:45:19 :
    08:45:19 : A36BB1F1EA65953268764749FC09078FAFA20948
    08:45:19 : 25C69690BF0EEDFD5BACC91426F84C07E58692DE
    08:45:19 : 65B467FC31516A8CDA02C9884B1BF06F48369B0D
    08:45:19 : 251BA25FBEE74F24F20A674F659E73DAE541380F
    08:45:19 : 7BFCF0E19460AC5160352ED60D14B71B041AF17B
    08:45:19 : C34502FD591C16CD60DC6767A8CA4743373393FD
    08:45:19 : 0DF8D22E7E01AEDB1D21D540A81E7792FBA9C568
    08:45:19 : B62242E77CFA3F8C9A9AA655D920779E35D4D380
    08:45:19 :
    08:45:19 :
    08:45:19 :
    08:45:19 : ================================================== ====
    08:45:19 : WARNING: This Phone requires a 20-digit NCK !!!
    08:45:19 : Brute Force Unlock is USELESS for this Phone...
    08:45:19 :
    08:45:19 : Process Done!
    08:45:19 :
    08:45:19 :
    08:45:30 :
    08:45:30 : Please Wait while Loading MNC-MCC List...
    08:45:30 : Parsing Entries...
    08:45:31 : Load Done!
    08:45:34 : Error: This is only for BB5/Infineon XG213
    08:45:49 :
    08:45:49 : MCU: V 07.50 29-11-11 RM-713 (c) Nokia
    08:45:49 : IMEI: 354602059013222
    08:45:50 : Product Serial Number: C88BBA8AH
    08:45:50 : Product Code : 059D8Q7
    08:45:50 : Module Code : 0204727
    08:45:50 : Basic Production Code: 059N2M2
    08:45:50 : PPM SW Version : V 07.50 29-11-11 RM-713 (c) Nokia MR
    08:45:51 : AEM Version : p V 07.50\n29-11-11\nRM-713\n(c) NMP\nmr
    08:45:52 : MCU SW Version : V 07.50 29-11-11 RM-713 (c) Nokia
    08:45:52 : HW Version : 1002
    08:45:52 : UEM Version : 1328
    08:45:52 : UPP Version : 8850
    08:45:52 : LCD Version : WIN:BAFFINv80 NT39121
    08:45:53 : ********** SIMLOCK INFO **********
    08:45:53 : CONFIG_DATA : 0010100000000000
    08:45:53 : PROFILE_BITS : 0000000000040002
    08:45:53 : ASIC : 11
    08:45:53 : PROVIDER : Default Test Operator
    08:45:53 :
    08:45:54 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
    08:45:54 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
    08:45:54 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
    08:45:54 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
    08:45:54 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
    08:45:54 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
    08:45:54 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
    08:45:54 : ST_LCD_TEST : PASSED
    08:45:54 :
    08:45:58 :
    08:45:58 : Make sure you have installed the
    08:45:58 : COMPLETE Flash Package for this Phone...
    08:45:58 :
    08:45:58 : Goto "Settings" --> "Nokia Settings" and verify that
    08:45:58 : the Folder where you installed your Flash Files are
    08:45:58 : in the "PRODUCT PATH TO SCAN" List...
    08:46:09 :
    08:46:09 : FACTORY SET TO : Full Factory Set
    08:46:10 : OK
    08:46:10 : FACTORY SET TO : User Data
    08:46:11 : OK
    08:46:11 : FACTORY SET TO : Leave Factory
    08:46:11 : OK
    08:46:11 : FACTORY SET TO : Service Center
    08:46:11 : OK
    08:46:11 : FACTORY SET TO : Software Upgrade
    08:46:11 : OK
    08:46:11 : FACTORY SET TO : Production Tune
    08:46:11 : OK
    lyvant@yahoo.com.vn 0934030540
    dơi nước thì đóng lại upp.nếu non thì lắc lại cặp không được rồi tính
    gmail: Doanhtruong_090
    Agribank STK:3503205057189
    Thành viên tích cực abc020010's Avatar
    cao lãnh ĐỒNG THÁP
    bạn kiểm tra LCD koi sau
    yahoo:boy_caolanh14 phường 11 cao lãnh ĐỒNG THÁP!
    sdt 01866206731
  4. ( abc020010 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    minhthu84 (12-08-2013)
    Nov 2012
    ĐỒNG THÁP
    08:45:54 :
    08:45:58 :
    08:45:58 :
    08:46:09 :
    08:46:10 : OK
    08:46:11 : OK
    08:46:11 : OK
    08:46:11 : OK
    08:46:11 : OK
    08:46:11 : OK
    log đẹp nha coi lại đường màng hình ATF rest ok hết rồi info ra đẹp luôn coi dường màng nha
    Thành viên mới khuongsocson's Avatar
    May 2012
    câu lại đường màn hình là ok làm gì ma chay lai fw làm gi http://ng8.upanh.com/b6.s24.d1/cbcf7...c76863d120.jpg
    kt kỹ dg mh nhé bạn
    yh chanyenmobile_led1202
    ctk hà Văn Yên face hachanyen
    sdt zalo..0972444489
    BỘ ngoại giao trùm các 4r
    Feb 2011
    ST_LCD_TEST : PASSED nó báo vậy rồi mà????
  9. #8
    Thành viên tích cực TRUONGMOBILE-123's Avatar
    Aug 2012
    máy có giao dộng màn hình ok rồi thì bạn kt dường BSI xem còn ko,dứt dường này ko lên nguồn dâu bạn ơi!
  10. #9
    Thành viên tích cực thaituan_mobile's Avatar
    Jan 2010
    coi lại đường màn hình làm từ từ những bước cơ bản đã rồ tính tiếp
    chuyên máy cỏ giá cực sốc .0973202719.0932696577
  11. #10
    Thành viên tích cực haomobilest's Avatar
    Nov 2012
    bạn thaituan noi đúng đó hãy làm từng giai đoạn rồi mới đụng đến phần cứng
    'haomobilest@yahoo.com':o
  1. Trả lời: 10
  2. Trả lời: 5
    Bài viết cuối: 30-01-2013, 14:51
  3. Trả lời: 12
    Bài viết cuối: 30-09-2012, 04:37
  4. Trả lời: 13
  5. Trả lời: 8
    Bài viết cuối: 07-01-2010, 22:14
