Kết quả 1 tới 10 của 12
    Thành viên chính thức nguyenduynhoxtai's Avatar
    Aug 2012
    Mặc định ae ai còn thức giúp em x2-01
    em chưa đủ bài post đúng mục mod đừng xóa thank mod nhiều
    tình trang máy quên mật khẩu chay bằng phonenix
    mở nguồn chớp tắ bỏ qua mx_box flash củng zây
    dây log em no ae xem dùm
    MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C087AC06
    Using device: USB ROM and HTI, FW ver: 00.50, SN: 0100E61A
    Connection status: EHCI:HUB::USB 2.00 (High-speed)
    Driver: NMWCD, ver: 7.1.32.84
    Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
    Processing MCU file: rm709__08.71.mcusw
    [BB5,XSR 1.6] size: 26.61 MB
    Supported Ids: 2200050920030000, 22000509200C0000
    Waiting for USB ROM device ...
    CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0]
    CMT EM0 ID: 00005361
    CMT PUBLIC ID: 00000000006308B8A0BA21A15030DD179D43870F
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
    CMT ROM ID: DE56D582BDDE7A3A
    Loading CMT secondary boot code
    SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940
    Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
    eBB5ProtocolType: NEW
    Secondary boot loaded.
    Storage2: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,NOR, asic:CMT
    Storage3: 0010 0011 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.6
    Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D
    Update server code loaded.
    Waiting for USB device removal ...
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1C361585
    FUR: Adding Asic CMT as client OK.
    Reading CMT HWC (0xD4 bytes).
    Reading CMT R&D (0x0 bytes).
    RPL(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35861504098989_CE RT.rpl).
    CMT PAPUBKEYS HASH: 37955B6FC432998EF0DB240E332228384D19ED09
    Storing certificate [NPC, CCC, HWC, RND, R&D] ...OK
    Partitioning....
    Partitioning complete
    Erase size: 33.88 MB
    CMT FLASH,MuxOneNAND area [00000000-0001FFFF]
    CMT FLASH,MuxOneNAND area [00020000-000203FF]
    CMT FLASH,MuxOneNAND area [00060000-012FFFFF]
    CMT FLASH,MuxOneNAND area [01300000-01DFFFFF]
    CMT FLASH,MuxOneNAND area [02600000-029FFFFF]
    Formating partition ...
    Flash programming ...
    CMT KEYS block sent
    CMT ADA block sent
    CMT PRIMAPP block sent
    CMT RAP3NAND block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 37955B6F [] sent
    CMT UPDAPP block sent
    CMT MCUSW block sent
    CMT MCUSW1 block sent
    CMT GENIO_INIT block sent
    CMT ISA+DYNSW block sent
    Programming completed in 16.985 s
    Processing PPM file: rm709__08.71.ppm_mh1
    [BB5,XSR 1.6] size: 6.98 MB
    Erase size: 8 MB
    CMT FLASH,MuxOneNAND area [01E00000-025FFFFF]
    Programming completed in 5.187 s
    Processing CNT file: rm709__08.71_004.image_mh1_ctv_in_v2_9l3w2
    [BB5,XSR 1.6] size: 33.94 MB
    Erase size: 75.31 MB
    CMT FLASH,MuxOneNAND area [02A00000-0753FFFF]
    Programming completed in 26.937 s
    Total time for flashing process(boot+erase+write) was 59.390 s
    Open device failed: FFFFFFFF (4) The system cannot open the file
    Warning: Phone did not reboot to normal mode.
    [RebootFromFlashMode] Please press "OK" or "Accept" on your phone (if SIM Card is not inserted to the phone) !
    tuan_vh16@yahoo.com
    May 2011
    Hà Nội City
    Bỏ sim ra và chạy lại ver cao hơn
    Aug 2012
    flash không bỏ sim vào anh ak mà báo zây đó
    flash ver 8.71 cao nhất rồi flash 5 lần rồi vẫn zậy
    ae nào còn thức xem giúp dùm cái
    tuan_vh16@yahoo.com
    V.I.P LOC_PHAT_ĐAT's Avatar
    Jan 2010
    Trích Được post bởi BN Mobile™ Xem bài viết
    làm như mod đi thớt...mà sao lại pos bên box này..
    Thành viên mới duc vinhmobile's Avatar
    Jul 2011
    dánh sạch chân u s b kiêm tra dây flash lai no bao nôi dây
    Thiết bị kết nối: nmwcdnsuc \ Nokia USB Flashing Chung, PORT_ID: 1C361585
    Thiết bị mở không thành công: FFFFFFFF (4) Hệ thống không thể mở tập tin
    Cảnh báo: điện thoại đã không khởi động lại để chế độ bình thường.
    Moderator Apple179's Avatar
    Sep 2010
    kiểm tra đá lại chân con ic nguồn đi........
    DV sửa chữa iphone cho anh em
    mxbox chiến không ngọt dòng này,bác mang qua mtbox chạy cỏng usb là ok
    Thành viên chính thức longthuanthien's Avatar
    cho vào phoenix chạy đi chủ thớt
    đt : 0975.651.156 yahoo : philongthuanthien
    Thành viên tích cực liencuongmobile's Avatar
    Oct 2009
    có box j trong tay mang ra chiến thử đi hay chỉ có phonenix thôi, nếu vậy thì kiếm ai có box flash lại xem
    Thành viên chính thức whanh2005's Avatar
    Oct 2011
    sao ko thử dùng best tool hả bạn?
  1. Bác nào còn thức giúp e phát
    By ĐỨCTHẮNGmobile_QB in forum Phần mềm và các mã lệnh
    Bài viết cuối: 04-06-2013, 08:12
  2. Trả lời: 5
    Bài viết cuối: 08-03-2013, 13:07
  3. ae ai còn xài MX bản 3.5 rev 1.3 giúp mình chút :D
    By phone_lucky in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 15-10-2011, 17:31
  4. Trả lời: 2
    Bài viết cuối: 06-05-2011, 15:41
  5. 3110C còn 12 tháng cần giúp đỡ
    By haigoshi in forum BB5
    Bài viết cuối: 04-11-2008, 19:30
