Kết quả 1 tới 10 của 17
    Thành viên chính thức tuantu_gsm's Avatar
    Mặc định C5-00 bộ nhớ đầy xin giúp
    tình trạng máy báo đầy bộ nhớ và tự khởi động lại , em đã nạp lại phần mềm nhưng vãn nguyên tình trạng , anh nào đã gặp qua xin giúp dùm em
    đây là log Atf
    Booting Phone via FBUS...
    AdvanceBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    TIME STARTS HERE
    Number of Sub Blocks 7 (0x07)
    1 SYSTEM_ASIC_ID 01
    Block Length : 21 (15)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000003
    ID DWORD 1 : 00000226
    ID DWORD 2 : 00010007
    ID DWORD 3 : 600C1921
    ID DWORD 4 : 02031104
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00000C35
    3 EM_ASIC_ID 02
    ID DWORD 0 : 00000C30
    4 PUBLIC_ID 12
    ID DWORD 0 : 18700217
    ID DWORD 1 : 2F230049
    ID DWORD 2 : 04867C76
    ID DWORD 3 : 3B3179FA
    ID DWORD 4 : AAED7C69
    5 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    Block Length : 17 (11)
    Hash : 91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B
    7 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : E693EF0D
    CRC 1 : AC22615B
    Checksum 3B
    SearchForBootstrap_DCT5..
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg
    Boot File - Version 012.014.00
    Boot File - Revision 0x0003 (3)
    eBB5ProtocolType == New
    PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
    PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
    Secondary Loader Sent...
    TransmissionTypeRequest_DCT5_NewProtocol
    TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
    FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
    Transmission Type Request Sent...
    MessageID : 06
    SubBlocks : 06
    Block Length : 0B
    BB ASIC Index : CMT 00
    Device Type : RAM 05
    Device Index : 00
    Manufacturer Code : 0000 -> Flash
    Device ID : 0000 -> not detected
    Extended/Fixed ID : 0000
    Revision ID : 0000
    2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MMC 04
    Device Index : 00
    Revision ID : 0000
    Block Length : 0B
    Device Type : NOR 00
    Device Index : 00
    Manufacturer Code : 0020 ->
    Device ID : 0040 -> Type not in database
    Revision ID : 0031
    4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Index : 01
    Manufacturer Code : 0000 -> SPANSION
    Device ID : 0001 -> not used
    Revision ID : 0000
    5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MuxOneNAND 03
    Device Index : 00
    Revision ID : 0031
    6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
    Block Length : 09
    Data : XSR 1.6
    Checksum : 54
    FLS1SendAlgoCodeEx..
    SendAlgoCode_DCT5..
    SearchForAlgorithm_DCT5..
    Looking for ALL Devices...
    Searching Algorithm Files MuxOneNAND (03) ManID :0020 DevID :0040 ExtID :0000 RevID :0031
    Flash Descriptor
    Device ID : 0040
    Revision ID : 0000
    Size : 10000000 (256 MB)
    VPP Info : 0000
    Erase10s : 1E
    Block1s : 32
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_XSR17_alg.fg
    Algorithm File - Version 012.014.00
    Algorithm File - Revision 0x0003 (3)
    Algo Loader Sent...
    SendCodeStart_NewProtocol :
    SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
    FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
    FUR control Ok...
    VPP Enabled by Software
    Using Internal VPP
    FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
    PAPUB_KEYS_HASH_REQ_BB5
    PHONE_INFO_RESPONSE_BB5
    PAPUB_KEYS_HASH_RESP_BB5 2A
    BB Asic Index : 00
    CMT PAPUBKEYS HASH:
    D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057
    Scanning Simlock Applet Type...
    OK
    PA_SIMLOC30 Applet detected
    Use "Scan Phone" Button to Check if this Phone
    uses a 15-digit NCK or a 20-digit NCK...
    * Firmware Version Downgrade will KILL PHONE !!!
    * Manual Full Erase WILL KILL PHONE!!!
    * Simlocks are in PM 120 Only...
    * PM 308 is Write Protected...
    Basic Phone Information
    MCU Version: V ICPR82_11w16.4 02-06-11 RM-645 (c) Nokia
    IMEI Plain : 359345035549563
    IMEI Spare : A359345035549560
    IMEI SV : 33593450355495615F
    Phone Model: Nokia C5-00
    Category : Classic Phone
    Phone Type : RM-645
    Extended Phone Information
    Product Serial Number: CGM248664
    Product Code : 0593574
    Module Code : 0204492
    Basic Production Code: 0591907
    Long Production SN : 0
    MCU SW Version : V ICPR82_11w16.4 02-06-11 RM-645 (c) Nokia
    HW Version : 6000
    RFIC Version : |Vapaus_5.1 | Mikki_1.1
    DSP Version : ICPR82_11w16
    Content : rm645_071.005_U000.000_prd
    AHNE Version : 11
    APE SW Core Version : 071.005
    Variant Version : 071.005071.005.16.01071.005.C00.01
    APE Test Version : 10wk48v0.001_APEONLY
    RETU Version : 35
    TAHVO Version : 00
    APE HW Version : 256
    APE ADSP SW Version : 256
    Bluetooth ID : 80:50:1B:70:2C:28
    CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA VIII
    Simlock Information
    CONFIG KEY : 0000000000000000
    PROVIDER KEY : 2440700000000000
    NETWORK NAME : Nokia Default;Finland
    LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
    SIMLOCK TABLE :
    Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
    SIMLOCK STATE : Not Locked
    SIMLOCK_TYPE : PA_SL3 (15-digit NCK)
    SIMLOCK_TEST : PASSED
    SECURITY_TEST : PASSED
    SECURITY_CODE : ENCRYPTED
    PHONE_MODE : TEST
    DCC ID : NOT USED
    Selected VPL File:
    RM645_0593574_071.005_001.vpl
    Variant Details : VIETNAM WM GREY
    Software Version : 071.005
    Product Type : RM-645
    Variant Version : 001
    Nov 2012
    ĐỒNG THÁP
    camera chụp báo bộ nhớ đầy hả bác
    DCC ID : NOT USED
    Trích Được post bởi phithanhmobile Xem bài viết
    DCC ID : NOT USED
    mở nguồn lên là nó báo bộ nhớ đầy và khởi động lại lun anh ah
    May 2010
    ĐIỆN BIÊN
    flash úbb by phonnix đi coi hết ko bạn .nhièu khi flash qua box lại ko by đc mã vs ko hết lỗi là chuyện thường tình mà
    TRUNG HIẾU MOBILE
    Moderator Apple179's Avatar
    Sep 2010
    đưa qua jaf focmat là ok ...nhiều cái hộp đời cao chiến kg đc mà đua qua jaf cùi lạ ok
    DV sửa chữa iphone cho anh em
    Nov 2012
    ĐỒNG THÁP
    khả năng lỗi bạn lấy bộ file hwc-ccc về nạp vô coi sao
    Feb 2013
    factory cho e nó phát
    để em thử lại bằng tool , có gì em sẽ báo lại
    em thử bằng phonenix và bes vẫn nguyên tình trạng anh ah
    Thành viên tích cực trong_mobile's Avatar
    Jun 2012
    Phoenix, BOx cũng phải bó tay à .....Factory full thử xem sao bạn cái này báo lỗi PM mà...
    Có khi nào trên đường đời tấp nập
    Ta vô tình vấp phải cục iphone
