xin giúp x2-00 vô nước mất nguồn,xin chi giúp
men dẹp,không bi oxy hóa.chạy phần mềm atf,hwk,phonenix,mxbox
đây là long mxbox
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D
Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
Update server code loaded.
Waiting for USB device removal ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 880E3B3
FUR: Adding Asic CMT as client OK.
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
RPL(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35827404201798_CE RT.rpl).
CMT PAPUBKEYS HASH: E9700989029D9E899915F781B1582048E042A738
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 32.88 MB
CMT FLASH,MuxOneNAND area [00000000-0001FFFF]
CMT FLASH,MuxOneNAND area [00020000-000203FF]
CMT FLASH,MuxOneNAND area [00060000-011BFFFF]
CMT FLASH,MuxOneNAND area [011C0000-01CFFFFF]
CMT FLASH,MuxOneNAND area [02500000-028FFFFF]
Formating partition ...
Flash programming ...
CMT KEYS block sent
CMT PAPUBKEYS: E9700989 [RAP Certificate v1 237] sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT ADA block sent
CMT RAP3NAND block sent
CMT ISA+DYNSW block sent
CMT MCUSW block sent
CMT MCUSW1 block sent
CMT GENIO_INIT block sent
CMT UPDAPP block sent
Programming completed in 8.406 s
Processing PPM file: rm618__08.35.ppm_v
[BB5,XSR 1.6] size: 6.98 MB
Supported Ids: 2200050920030000, 22000509200C0000
Erase size: 8 MB
CMT FLASH,MuxOneNAND area [01D00000-024FFFFF]
Programming completed in 2.359 s
Processing CNT file: rm618__08.35.image_v_059B618
[BB5,XSR 1.6] size: 20.99 MB
Erase size: 76.31 MB
CMT FLASH,MuxOneNAND area [02900000-0753FFFF]
Programming completed in 7.094 s
Total time for flashing process(boot+erase+write) was 27.563 s
Open device failed: FFFFFFFF (4) The system cannot open the file
Warning: Phone did not reboot to normal mode.
[RebootFromFlashMode] Please press "OK" or "Accept" on your phone (if SIM Card is not inserted to the phone) !
Market items is empty, please select the correct products path !
báo vậy là sao các huynh
			 xin giúp x2-00 vo nước mất nguồn
