Kết quả 1 tới 10 của 10
    Thành viên tích cực phamtrung's Avatar
    Mặc định c2-00 không nhân sim
    các bac xem giúp cai log giúp em. máy khách mang tới đã bị sửa chữa đương sim khách mang tới bảo không nhận sim em láp sim vào thì báo không đang ký được thẻ sim,không phục vụ.nhưng vào danh bạ sim vẫn tháydanh bạ sim.em thử chạy lại vẫn thấy vậy.xin các báo giúp đỡ
    MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C08747CE
    Using device: USB Phonet and HTI, FW ver: 00.50, SN: 0100CA16
    Driver: nmwcdc, ver: 7.1.32.75
    Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
    Battery voltage: 4043 mV
    Waiting for USB device removal ...
    Waiting for USB ROM device ...
    Device synchronized.
    CPU: XGOLD 213
    Using embedded SBL from MCU.
    Sending EBL Loader...OK
    Sending EBL ...OK
    Getting EBL Version ...
    Boot mode: 0xCC
    EBL version major/minor: 10.44
    EBL version: Quantum_Bootloader_10.44_M1S1
    Protocol version suggested by phone: 3
    Set baud rate to: 6.50 Mbit/s
    Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits]
    CFI information:
    Flash settings: 0/1024, size: 0x04000000
    1 Block regions:
    512 x 0x00020000 = 0x04000000
    EBL ready !
    Original IMEI: 35906304329970
    IMEI_DATA saved OK
    CCC_DATA saved OK
    HWC_DATA saved OK
    LOCK120_DATA saved OK
    RPL saved to "C:\mobileEx\3.5\data\backup\XGOLD_35906304329970_ back.RPL"
    Processing file: rm704__03.82.mcusw
    Downloading item CODE:rm704__03.82.mcusw_ebl_psi.fls, num block: 4, size: 26 MB
    Erasing area 0x40000000-0x4001FFFE ...OK
    Programming completed in 0.360 s
    Erasing area 0x40040000-0x4005FFFE ...OK
    Programming completed in 0.344 s
    Erasing area 0x40060000-0x4015FFFE ...OK
    Programming completed in 1.406 s
    Erasing area 0x40280000-0x41B3FFFE ...OK
    Programming completed in 31.140 s
    Checksum verified (0xE70B)
    Processing file: rm704__03.82.ppm_v
    Downloading item CUSTackage_v.ppm_ebl_psi.fls, num block: 1, size: 3.97 MB
    Erasing area 0x41BC0000-0x41FB874E ...OK
    Programming completed in 5.125 s
    Checksum verified (0xF4E7)
    Processing file: rm704__03.82.image_v_magenta_059C8N6
    Downloading item CUSTackage_v_magenta_059C8N6.image. , num block: 1, size: 11.75 MB
    Erasing area 0x421C0000-0x43E1FFFE ...OK
    Programming completed in 15.078 s
    Checksum verified (0x451D)
    Total time for flashing process(boot+erase+write) was 7 min 38.875 s
    Device connected: nmwcdc\Nokia C2-00 USB Phonet, PORT_ID: 1071CC47
    Verifying communication to device OK.
    Phone type: RM-704 (C2-00)
    SW version: V 03.82 17-10-11 RM-704 (c) Nokia
    Imei plain: 35906304329970-5
    Product code: 059C8L1
    Battery voltage: 4038 mV, current: 87 mA
    Cellular system: GSM
    ASIC ID: 0x0000, type: 11
    Ppm Id: V
    Language Pack:
    - not available.
    Master code: 4701510361
    Camera config: NI00CS0000040C213402, ver: 002.006
    Imei net: 35906304329970
    Version: SIMLOCK SERVER
    Provider: GSM Test Operator
    Counter: 0/3, 0/10
    CONFIG_DATA: 0010100000000000
    PROFILE_BITS: 800000000003000B
    Market items is empty, please select the correct products path !
    Counter: 0/3, 0/10
    Thành viên tích cực ĐứcmobileGSM's Avatar
    Aug 2012
    Bắc Giang
    test sim khác chưa anh . hôm bữa em dính 1 cây y trang bác , thay sim khác = Done
    SDT : 0972 520 530 and 0904 32 32 62
    Yahoo : loveparadise_3129@yahoo.com
    Jun 2012
    kt xem co trở k áp v sim có k tét cái sim khác xem ntn
    V.I.P LOC_PHAT_ĐAT's Avatar
    Jan 2010
    không nhận sim sao mà có danh bạ.xem lại hay máy mất sóng...phải chính xác là danh bạ trong sim hay là trong máy.nếu trong sim thì máy đã nhận sim rồi là máy mấy sóng đó
    Feb 2012
    tây ninh
    log bình thường.test sim khác ko ok thì làm cứng thôi.
    mình làm song rồi.mình làm nghề 5n rồi nhưng gạp con nào hài quá. con này mình thao gia làm phàn cúng nhưng vệ sinh láp vào có một qua pin khác gàn đó lấy láp vao thấy đươc luôn nhưng láp vào lấy pin của may đó thì không đươc nữa vậy là đổi pin ok.kiếm 100k
    Thành viên tích cực trinhquangha's Avatar
    Dec 2011
    Usa
    Trích Được post bởi phamtrung Xem bài viết
    hê.đúng là ít gặp !!
    dt_0904 464 102.yahoo:trinhhahl_qn
    Mar 2012
    nam định
    Trích Được post bởi trinhquangha Xem bài viết
    C1-C2 BÊNH NÀY KO PHẢI HIẾM ĐÂU
    kẹp dòng nếu nhận sim thì thay pin...những cái đơn giản test trước để tránh phải mất công
    HÃY HẾT LÒNG VÌ KHÁCH HÀNG
    Thành viên tích cực vankhuong77's Avatar
    Aug 2008
    Trích Được post bởi A & T Mobile Xem bài viết
    bác này nói chính xác nè phải làm từ dể đến khó
    TK DONG A : 0110296040
    Thành viên chính thức truonghan162's Avatar
    Jun 2011
    Nha Trang
    cái này đúng nè
    TH Mobile - 0906674262
    Lelenguyen162
