    Thành viên tích cực domdomvang's Avatar
    lào cai
    Mặc định 2690 không vào wed được
    tình hình là em lại mới nhận cây 2690 không vào dc wed mà em đã chay ver 10.65 mà vẫn ko vào dc wed anh em giúp em với
    học nữa học mãi đúp học lại
    lào cai
    Version from phone: 10.65
    Version from file: 10.65
    MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C087F037
    Using device: HTI, FW ver: 00.50, SN: 010119D5
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
    Reading RPL backup ...
    Reading Secure Storage ...
    Reading Important data ...
    Reading SIMLOCK data ...
    Reading CERT data ...
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    PUBLIC ID: 24500101CF5D05560C4B220D3EF4086D066C335C
    ASIC MODE ID: 00
    ROM ID: 273F6D55DFAAF68F
    eBB5ProtocolType: OLD
    Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT
    TransmissionMode: 16Bit
    CMT PAPUBKEYS HASH: C6B9354E81AC464DED33FC7B90295086150F4539
    TransmissionMode: DDR&TX2
    Reading CMT HWC (0xD4 bytes).
    Reading CMT R&D (0x0 bytes).
    Flash Imei: 35625104718189
    NPC_DATA saved OK
    CCC_DATA saved OK
    HWC_DATA saved OK
    SIMLOCK_DATA saved OK
    SIMLOCK_KEY_DATA saved OK
    SUPERDONGLE_KEY_DATA saved OK
    CMLA_KEY_DATA saved OK
    WMDRM_PD_DATA saved OK
    RF_DATA saved OK
    WARRANTY_DATA saved OK
    PROD_DATA saved OK
    BT_DATA saved OK
    LOCK_DATA saved OK
    LOCK120_DATA saved OK
    BB_DATA saved OK
    RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35625104718189_BA CK.rpl"
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    Processing MCU file: rm635__10.65.mcusw
    [BB5,BB5 ALGORITHM] size: 17.99 MB
    Erase size: 21 MB
    CMT FLASH,NOR area [00000000-000006BF]
    CMT FLASH,NOR area [000006C0-0001FFFF]
    CMT FLASH,NOR area [00040000-000BFFFF]
    CMT FLASH,NOR area [000C0000-0013FFFF]
    CMT FLASH,NOR area [00140000-0137FFFF]
    CMT FLASH,NOR area [01380000-0151FFFF]
    erased in 1 min 56.328 s
    Prog.status for Asic CMT ...
    NOR: OK
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: C6B9354E [RAP Certificate v1 246] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    NOR: OK
    Programming completed in 1 min 8.437 s
    Processing PPM file: rm635__10.65.ppm_v
    [BB5,BB5 ALGORITHM] size: 4.06 MB
    Erase size: 8.62 MB
    CMT FLASH,NOR area [01520000-01DBFFFF]
    erased in 26.579 s
    NOR: OK
    NOR: OK
    Programming completed in 14.016 s
    Processing CNT file: rm635__10.65.image_v_black
    [BB5,BB5 ALGORITHM] page size: 128 K size: 10.01 MB
    Erase size: 34 MB
    CMT FLASH,NOR area [01DC0000-0215FFFF]
    CMT FLASH,NOR area [02160000-03FBFFFF]
    erased in 4 min 46.891 s
    NOR: OK
    NOR: OK
    Programming completed in 36.203 s
    Total time for flashing process(boot+erase+write) was 9 min 14.282 s
    Phone type: RM-635 (Nokia 2690)
    SW version: V 10.65 09-12-10 RM-635 (c) Nokia
    Imei plain: 35625104718189-5
    Product code: 0592405
    Battery voltage: 4965 mV, current: 28 mA
    Language Pack:
    - not available.
    Camera config: NI00IIIIRR030C213402, ver: 003.002
    SIMLOCK seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 356251047181895
    Version: SIMLOCK SERVER
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    FULL FACTORY... OK
    USER DATA... OK
    LEAVE FACTORY... OK
    SERVICE CENTER... OK
    SOFTWARE UPGRADE... OK
    PRODUCTION TUNING... OK
    Reset User Code (to default:12345) ... OK
    Completed in 2.250 s
    V.I.P LOC_PHAT_ĐAT's Avatar
    Jan 2010
    kiểm tra xem sim có đăng kí chưa..lấy sim khác thử xem sao
    May 2012
    lấy sim viêt teo đã đk gprs . nếu đã có đk rồi thì soạn tin CAUHINH gởi 107, tônge đài trả về cấu hình rồi cài đặt vào sẽ ok mà
    May 2010
    Thủ Đức - TP HCM
    vấn đề ở chỗ cấu hình mấy chưa cài đặt bạn a.đừng flash mất thời jan. mỗi mạng có mỗi cách cài riêng. bạn seach cách cài cấu hình cho máy đầy trên gôgle ây.nếu khó wa nhờ tổng đài hổ trợ nha ban.
    Thành viên chính thức QuangDung_GSM's Avatar
    Jun 2010
    Nghệ An
    bạ đăng kí sim chưa. cấu hình nữa vào cài đặt cài đặt cấu hình mặc định đi
    lào cai
    cái đos em làm rùi cấu hình máy em cài rùi gprs em cũng cài luôn mà vẫn không dc thế mới ảo chứ nên em mới hỏi các pro
    lào cai
    em dùng viettel mà mọi cái đều cài dc mà cái này ảo quá
    By vvaodoi1980 in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 26-12-2012, 20:44
  2. 2690 sạc mãi không đầy
    By ngocthanh1202 in forum BB5
    Bài viết cuối: 10-10-2012, 21:08
  3. 2690 phím không ăn
    By KHA_MOBILE67 in forum BB5
    Bài viết cuối: 14-06-2012, 16:05
  4. 2690 cập đường vio
    By tuananh_mobile1990 in forum BB5
    Bài viết cuối: 17-11-2011, 15:42
