    Thành viên tích cực tony.haokiet's Avatar
    Jan 2010
    Mặc định 1110i contact
    máy em mới nhận nạp tiếng việt giờ bị contact service không hiểu vi sao nhờ anh em giúp đỡ thank ae
    Getting MCU ID
    MCU ID: 0x2201
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-93\
    Checking path: \Products\RH-93\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_06.930
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_06.93qa
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai6.93qa
    Languages in ppm: English,Chinese S,Chinese T
    Changing flashing settings...
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_06.93qc
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai6.93qc
    Languages in ppm: English,Chinese S,Vietnamese
    Setting local mode...
    Reading IMEI...
    Reading IMEI data...
    IMEI data corrupt...
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_06.930
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Flash ID is 0x28882000
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u_st_i.fia
    Loader size is 0x4B28; Loader chk: cb
    Loader is ready...
    MSID: 8441D14EB77B2757478B6FD673
    MSID decoded: 3E4EBAE90080D758AA000000
    FAID: 4B39CAAE8FEF5B8FFB585AC0
    Operation took 0 minutes 6 seconds...
    Erasing...
    Found 5 interval(s) to erase
    Erasing area: 01010000 - 013BFFFF...
    Erasing area: 013C0000 - 013EFFFF...
    Operation took 0 minutes 47 seconds...
    Writing...
    Perm. Data Restore OK
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_06.93qc
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    Erasing PPM...
    Found 2 interval(s) to erase
    Erasing area: 011E0000 - 011EFFFF...
    Erasing area: 011F0000 - 0137FFFF...
    Operation took 0 minutes 19 seconds...
    Writing...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai6.93qc
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    MSID: 84C4934A31FB98F19EC76659CE
    MSID decoded: 3E4EBAE90080D758A8000000
    FAID: 96E1DC4AA42488748476FD85
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 01380000 - 013BFFFF...
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 1 minutes 59 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Phone type: RH-93, Software version: 6.93
    IMEI: 359745003712061
    Product Code: 0541719
    Resetting PPC...
    Setting FULL FACTORY......Setting test mode...
    Done!
    Done!
    Done!
    Done!
    May 2010
    ĐIỆN BIÊN
    1110i thả cửa lâu lắm r .full flash > ulock .> full pm lụm lúa nhé bạn
    TRUNG HIẾU MOBILE
  3. ( QUANGTRUNG_GSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    tony.haokiet (29-04-2013)
    kiếm file chuẩn chạy bác vào factory cho em nó
  5. ( mobingoc ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Jan 2010
    Getting MCU ID
    MCU ID: 0x2201
    Algo is ready...
    Done!
    Phone Restarted...
    Powering the phone...
    Unlocking...
    ASIC: 2
    SW version: 6.93
    Selected flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_06.930
    Decrypting flash...
    Encrypting....
    CHK Patch found - Unlock Patch found and are not in same block
    Patch status: 01
    MCU ID: 0x2201
    Algo is ready...
    Erasing area: 01140000 - 0115FFFF...
    Unlocking...
    Checking locks...
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    MCU ID: 0x2201
    Algo is ready...
    Done!
    DCT4 unlock counter: 18
    Done!
    Unlocking...
    ASIC: 2
    SW version: 6.93
    Stoping...
    Phone Type:
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_07.020
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_07.02md
    Languages in ppm: English,Filipino,Vietnamase
    Phone Type:
    Phone Type:
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh930_nai7.02md
    Reading IMEI...
    Reading IMEI...
    MCU: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_07.020
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    Erasing...
    Writing...
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_07.02md
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    Erasing PPM...
    Writing...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh930_nai7.02md
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 1 minutes 54 seconds...
    Reading...
    Phone type: RH-93, Software version: 7.02
    Resetting PPC...
    Done!
    Done!
    Unlocking...
    ASIC: 2
    SW version: 7.02
    Selected flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_07.020
    Decrypting flash...
    Encrypting....
    Patch status: 01
    MCU ID: 0x2201
    Algo is ready...
    Unlocking...
    Checking locks...
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    MCU ID: 0x2201
    Algo is ready...
    Done!
    DCT4 unlock counter: 19
    Done!
    Done!
    unlock luôn cũng vậy các bác
    Mar 2012
    nam định
    xóa full flash nạp lại-write pm- unlock+factorry
    not ok bung máy ra vệ sinh,thay màn rồi tính tiếp
    HÃY HẾT LÒNG VÌ KHÁCH HÀNG
  8. #6
    Jan 2012
    loc đẹp bạn thay màn hình xem
    manhdung81mobile@gmail.com
  1. 1110i contact service
    By ngocminhhungyen in forum DCT4 - WD2
    Trả lời: 21
    Bài viết cuối: 11-10-2010, 11:17
  2. 1110i contact sevice
    By ngtammy in forum DCT4 - WD2
    Bài viết cuối: 18-01-2009, 21:07
  3. 1110i contact sevice
    By dungnv86 in forum DCT4 - WD2
    Bài viết cuối: 03-01-2009, 20:19
  4. 1110i contact
    By baoanh_moto in forum DCT4 - WD2
    Bài viết cuối: 22-11-2008, 17:38
  5. 1110i contact
    By baoanh_moto in forum DCT3-DCTL
