con này em chạy phần mềm thì ngon
đường lcd cũng ngôn ko đứt chân nào
nhưng bật nguồn màn hình cứ tối thui bác nào biết giúp em với
đây là log của nó
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
Booting Phone...
CPU ID Response: A200341100
CPU Type: XG110 2.1B
Phone Booted at after First attempt...
TIME STARTS HERE
Sending PBL 19456 bytes...
PBL Successfully Sent...
Sending SBL 65024 bytes...
SBL Successfully Sent...
Flash Chip Manufacturer: Samsung Electronics Corp.
Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR
Extended Information: Multiple Bank / Burst / 1.8v
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm769_007.200
FIRMWARE Image Found...
Number of Sections: 03
FIRMWARE Certificate Block Sent Successfully...
Processing Section 01 of 03
FIRMWARE Erase Block: 0x00000000~0x0001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 24576 bytes
Data Checksum: F5BE
Uploading Data Blocks to phone...
FIRMWARE Data Blocks uploaded to phone...
Processing Section 02 of 03
FIRMWARE Erase Block: 0x00800000~0x00BFFFFE
Start Erasing...
Block Erase Done...
Data Size: 4128768 bytes
Data Checksum: BFB7
Processing Section 03 of 03
FIRMWARE Erase Block: 0x00C5D000~0x00E5FFFE
Start Erasing...
Block Erase Done...
Data Size: 1697536 bytes
Data Checksum: 2B05
Start Data Verification... (Please wait)
Data Verification Successful...
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm769_007.20mr
PPM Image Found...
Number of Sections: 01
PPM Certificate Block Sent Successfully...
Processing Section 01 of 01
PPM Erase Block: 0x00100000~0x0060A93E
Start Erasing...
Block Erase Done...
Data Size: 5286208 bytes
Data Checksum: D6F8
PPM Data Blocks uploaded to phone...
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm7690_nai07.20mr
CONTENT Image Found...
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x00E60000~0x00F0E4BE
Start Erasing...
Block Erase Done...
Data Size: 713920 bytes
Data Checksum: 60DE
CONTENT Data Blocks uploaded to phone...
Exit Flash Mode Done...
Time Elapse : 00:04:16
You must Factory Reset the phone to enable the
ringtones and other customized settings to work
Waiting For Phone to go Online...
5, 4, 3, 2, 1...
MCU: V 07.20 30-03-12 RM-769 (c) Nokia
IMEI: 359740046049787
Product Serial Number: 6120F9DAH
Product Code : 059H0D7
Module Code : 0204883
Basic Production Code: 059F6L6
PPM SW Version : V 07.20 30-03-12 RM-769 (c) Nokia MR
ADSP Version : p V 07.20\n30-03-12\nRM-769\n(c) NMP\nmr
MCU SW Version : V 07.20 30-03-12 RM-769 (c) Nokia
HW Version : 1000
UEM Version : 1328
UPP Version : 8850
LCD Version : WIN:BARACOAv95 NT39121
********** SIMLOCK INFO **********
CONFIG_DATA : 0010100000000000
PROFILE_BITS : 0000000000040002
ASIC : 11
PROVIDER : Default Test Operator
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
ST_LCD_TEST : PASSED
FACTORY SET TO : Full Factory Set
OK
FACTORY SET TO : User Data
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Service Center
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : Production Tune
OK
mong các bác giúp em với
			 101 mất nguồn cần giúp thank all!!!!
