    Thành viên tích cực TÍNH-NGHI_MOBILE's Avatar
    Feb 2011
    Mặc định xin ý kiến ae về cặp 2730c
    máy bị va đập mạnh.bật nguồn hiện contac sever...mình backup lại rồi chạy pm cho nó vẫn bị vậy..vậy mình có thể thay con flahs đựoc ko hay là phảu thay nguyên cặp...xin ae cho mình xin chút ý kiến thanhk all ae..
    lyvant@yahoo.com.vn 0934030540
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    trước tiên bạn đưa cái lock lên ae xem mới ra dc
  3. ( duykhanh_gsm ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    TÍNH-NGHI_MOBILE (06-05-2013)
    Feb 2011
    09:22:56 : BootFlashModeDCT5Ex Succeeded after 7 Attempts
    09:22:56 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
    09:22:56 : Number of Sub Blocks 7 (0x07)
    09:22:56 : 1 SYSTEM_ASIC_ID 01
    09:22:56 : Block Length : 21 (15)
    09:22:56 : BB ASIC Index : 0 (00) CMT
    09:22:56 : ID DWORD 0 : 00000001
    09:22:56 : ID DWORD 1 : 00000226
    09:22:56 : ID DWORD 2 : 00010006
    09:22:56 : ID DWORD 3 : 030C1921
    09:22:56 : ID DWORD 4 : 01023000
    09:22:56 : 2 EM_ASIC_ID 02
    09:22:56 : Block Length : 5 (05)
    09:22:56 : ID DWORD 0 : 00000296
    09:22:56 : 3 EM_ASIC_ID 02
    09:22:56 : ID DWORD 0 : 00000B22
    09:22:56 : 4 PUBLIC_ID 12
    09:22:56 : ID DWORD 0 : 0F700013
    09:22:56 : ID DWORD 1 : CB9D0356
    09:22:56 : ID DWORD 2 : 8F29CBCE
    09:22:56 : ID DWORD 3 : 1B2AD063
    09:22:56 : ID DWORD 4 : A72A620B
    09:22:56 : 5 ASIC_MODE_ID 13
    09:22:56 : Block Length : 2 (02)
    09:22:56 : Mode Id : 00
    09:22:56 : 6 ROOT_KEY_HASH 14
    09:22:56 : Block Length : 17 (11)
    09:22:56 : Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
    09:22:56 : 7 ROM_ID 15
    09:22:56 : Block Length : 9 (09)
    09:22:56 : CRC 0 : 273F6D55
    09:22:56 : CRC 1 : DFAAF68F
    09:22:56 : Checksum 4C
    09:22:56 :
    09:22:56 : SearchForBootstrap_DCT5..
    09:22:57 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
    09:22:57 : Boot File - Version 010.042.00
    09:22:57 : Boot File - Revision 0x0000 (0)
    09:22:57 : eBB5ProtocolType == Original
    09:22:57 : SearchForBootstrap_DCT5 : No Error - 0 (0x00)
    09:22:57 : Secondary Loader Sent...
    09:22:57 : ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
    09:22:57 : MCU_CONFIGURATION_RESPONSE_BB5:
    09:22:57 : ...
    09:22:57 : ERROR: Sending Loader Failed, CHECK PHONE RX2 PINOUT
    09:22:57 : ERROR: Sending Loader Failed...
    09:22:57 : Operations Failed....
    09:24:03 :
    09:24:03 : Only Phoenix.ini Flash Files are
    09:24:03 : supported for Checksum Verification...
    09:24:09 :
    09:24:09 : Only Phoenix.ini Flash Files are
    09:24:09 : supported for Checksum Verification...
    09:24:11 : ATF Software Version v9.80
    09:24:11 : ATF Box FBUS Flash Started...
    09:24:11 :
    09:24:11 : Number of Image Files: 3
    09:24:11 :
    09:24:11 : Processing Image File :
    09:24:11 : F:\FILE-NOKIA\RM-578-2730C\rm578__10.47.mcusw
    09:24:11 : CMT Type : BB5
    09:24:11 : CMT Algorithm : BB5 ALGORITHM
    09:24:11 : Secondary Sending Speed : 3250000 Hz
    09:24:11 : Algorithm Sending Speed : 6500000 Hz
    09:24:11 : Program Sending Speed : 6500000 Hz
    09:24:11 : Message Reading Speed : 98000 Hz
    09:24:11 : Number of Blocks : 1395
    09:24:11 : Entry Point : 0x457E
    09:24:11 : Page Format : 128K
    09:24:11 : Maximum Page Size : 0x00004000
    09:24:11 :
    09:24:11 : Changing MODE : FLASH
    09:24:11 : Booting Phone via FBUS...
    09:24:11 :
    09:24:21 : BootFlashModeDCT5Ex Failed
    09:24:21 : Operations Failed....
    09:24:40 :
    09:24:40 : Only Phoenix.ini Flash Files are
    09:24:40 : supported for Checksum Verification...
    09:24:42 : ATF Software Version v9.80
    09:24:42 : ATF Box FBUS Flash Started...
    09:24:42 :
    09:24:42 : Number of Image Files: 3
    09:24:42 :
    09:24:42 : Processing Image File :
    09:24:42 : F:\FILE-NOKIA\RM-578-2730C\rm578__10.47.mcusw
    09:24:42 : CMT Type : BB5
    09:24:42 : CMT Algorithm : BB5 ALGORITHM
    09:24:42 : Secondary Sending Speed : 3250000 Hz
    09:24:42 : Algorithm Sending Speed : 6500000 Hz
    09:24:42 : Program Sending Speed : 6500000 Hz
    09:24:42 : Message Reading Speed : 98000 Hz
    09:24:42 : Number of Blocks : 1395
    09:24:42 : Entry Point : 0x457E
    09:24:42 : Page Format : 128K
    09:24:42 : Maximum Page Size : 0x00004000
    09:24:42 :
    09:24:42 : Changing MODE : FLASH
    09:24:42 : Booting Phone via FBUS...
    09:24:42 :
    09:24:44 : VBATT Powering Down <<<<
    09:24:48 : VBATT Powering Up >>>>
    09:24:48 : SET VCCIO Level Done
    09:24:48 : SET BSI Load Done
    09:24:48 :
    09:24:48 : AdvanceBox SendBootCodeEx
    09:24:48 : InitialiseBootstrap_DCT5 DIR
    09:24:48 : BootFlashMode_DCT5
    09:24:48 :
    09:24:48 : ************************************************** ****
    09:24:48 : TIME STARTS HERE
    09:24:48 :
    09:24:48 : BootFlashModeDCT5Ex Succeeded after 3 Attempts
    09:24:48 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
    09:24:48 : Number of Sub Blocks 7 (0x07)
    09:24:48 : 1 SYSTEM_ASIC_ID 01
    09:24:48 : Block Length : 21 (15)
    09:24:48 : BB ASIC Index : 0 (00) CMT
    09:24:48 : ID DWORD 0 : 00000001
    09:24:48 : ID DWORD 1 : 00000226
    09:24:48 : ID DWORD 2 : 00010006
    09:24:48 : ID DWORD 3 : 030C1921
    09:24:48 : ID DWORD 4 : 01023000
    09:24:48 : 2 EM_ASIC_ID 02
    09:24:48 : Block Length : 5 (05)
    09:24:48 : ID DWORD 0 : 00000296
    09:24:48 : 3 EM_ASIC_ID 02
    09:24:48 : ID DWORD 0 : 00000B22
    09:24:48 : 4 PUBLIC_ID 12
    09:24:48 : ID DWORD 0 : 0F700013
    09:24:48 : ID DWORD 1 : CB9D0356
    09:24:48 : ID DWORD 2 : 8F29CBCE
    09:24:48 : ID DWORD 3 : 1B2AD063
    09:24:48 : ID DWORD 4 : A72A620B
    09:24:48 : 5 ASIC_MODE_ID 13
    09:24:48 : Block Length : 2 (02)
    09:24:48 : Mode Id : 00
    09:24:48 : 6 ROOT_KEY_HASH 14
    09:24:48 : Block Length : 17 (11)
    09:24:48 : Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
    09:24:48 : 7 ROM_ID 15
    09:24:48 : Block Length : 9 (09)
    09:24:48 : CRC 0 : 273F6D55
    09:24:48 : CRC 1 : DFAAF68F
    09:24:48 : Checksum 4C
    09:24:48 :
    09:24:48 : SearchForBootstrap_DCT5..
    09:24:48 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
    09:24:48 : Boot File - Version 010.042.00
    09:24:48 : Boot File - Revision 0x0000 (0)
    09:24:48 : eBB5ProtocolType == Original
    09:24:48 : SearchForBootstrap_DCT5 : No Error - 0 (0x00)
    09:24:49 : Secondary Loader Sent...
    09:24:49 : ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
    09:24:49 : MCU_CONFIGURATION_RESPONSE_BB5:
    09:24:49 : MessageID : 03
    09:24:49 : SubBlocks : 03
    09:24:49 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    09:24:49 : Block Length : 0B
    09:24:49 : BB ASIC Index : CMT 00
    09:24:49 : Device Type : NOR 00
    09:24:49 : Device Index : 00
    09:24:49 : Manufacturer Code : 0089 ->
    09:24:49 : Device ID : 8982 -> NU48F512
    09:24:49 : Extended/Fixed ID : 0000
    09:24:49 : Revision ID : 8A31
    09:24:49 : 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5
    09:24:49 : Block Length : 13
    09:24:49 : Device Contents : FFFFFFFFFFFFFFFFFFFF
    09:24:49 : 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    09:24:49 : Device Type : MMC 04
    09:24:49 : Manufacturer Code : FFFF -> Flash
    09:24:49 : Device ID : 0000 -> BAD FLASH TYPE
    09:24:49 : Revision ID : 0000
    09:24:49 : Checksum : 61
    09:24:49 : SearchForBootstrap_DCT5 : No Error - 0 (0x00)
    09:24:49 : FLS1SendAlgoCodeEx..
    09:24:49 : SendAlgoCode_DCT5..
    09:24:49 : SearchForAlgorithm_DCT5..
    09:24:49 : Looking for ALL Devices...
    09:24:49 : Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31
    09:24:49 : Flash Descriptor
    09:24:49 : Size : 04000000 (64 MB)
    09:24:49 : VPP Info : 0009
    09:24:49 : Erase10s : 28
    09:24:49 : Block1s : 64
    09:24:49 : BErase1s : 02
    09:24:49 : Reserved0 : 00
    09:24:49 : Reserved1 : 00
    09:24:49 : Reserved2 : 00
    09:24:49 : VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK
    09:24:49 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
    09:24:49 : Algorithm File - Version 010.040.00
    09:24:49 : Algorithm File - Revision 0x0000 (0)
    09:24:49 : eBB5ProtocolType == Original
    09:24:49 : SearchForAlgorithm_DCT5 : No Error - 0 (0x00)
    09:24:49 : TransmissionTypeRequest_DCT5...
    09:24:49 : SuggestedType : 01 16BIT
    09:24:49 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC
    09:24:49 : ReturnedType : 01 16BIT
    09:24:49 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
    09:24:49 :
    09:24:49 : Uploading ALGO File...
    09:24:49 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
    09:24:49 : PAPUB_KEYS_HASH_REQ_BB5
    09:24:49 : No PAPUBKeysHash Returned
    09:24:49 : Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
    09:24:49 : Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
    09:24:49 : Certificate 1
    09:24:49 : Name : NPC
    09:24:49 : ASIC Index : CMT 0
    09:24:49 : Certificate 2
    09:24:49 : Name : VARIANT
    09:24:49 : Certificate 3
    09:24:49 : Name : R&D
    09:24:49 : Certificate 4
    09:24:49 : Name : CCC
    09:24:49 : Certificate 5
    09:24:49 : Name : HWC
    09:24:49 : STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 56 41 52 49 41 4E 54 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 85
    09:24:49 : STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
    09:24:49 : VPP Enabled by Software
    09:24:49 : Using Internal VPP
    09:24:49 : StartErase_DCT5...
    09:24:49 : BlockLength : 0x36 (54)
    09:24:49 : ERASE Blocks : 0x01 (1)
    09:24:49 : 0 ERASE_AREA_BB5 0x12
    09:24:49 : Block Length : 0x33 (51)
    09:24:49 : BB ASIC Index : 0x00 CMT
    09:24:49 : Device Type : 0x00 NOR
    09:24:49 : Device Index : 0x00
    09:24:49 : 0 : 00000000-000006BF
    09:24:49 : 1 : 000006C0-0001FFFF
    09:24:49 : 2 : 00040000-000BFFFF
    09:24:49 : 3 : 000C0000-0013FFFF
    09:24:49 : 4 : 00140000-0155FFFF
    09:24:49 : 5 : 01560000-0175FFFF
    09:24:49 :
    09:24:49 : Erase_SendEraseBlock_BB5_NOR
    09:24:49 : Task in Progress... Please Wait...
    09:24:50 : STATUS_REQUEST_BB5...
    09:24:50 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5
    09:24:50 : Block Length : 01
    09:24:50 : BB ASIC Index : 00
    09:24:50 :
    09:24:50 : Successfully erased..
    09:24:50 : Time Taken to Erase : 00:00:00
    09:24:50 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9
    09:24:50 : ReturnedType : 04 DDR & 2TX
    09:24:50 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
    09:24:50 :
    09:24:50 : Flashing Speed: 5.00 Mhz
    09:24:50 : Processing : rm578__10.47.mcusw
    09:24:50 : Total blocks to write : 1395
    09:24:58 : ================================================
    09:24:58 : FBUS Cable RX2 PIN Diagnostics
    09:24:58 : STATUS_REQUEST_BB5...
    09:24:58 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5
    09:24:58 : Block Length : 01
    09:24:58 : BB ASIC Index : 00
    09:24:58 : INFO: RX2 PIN is OK
    09:24:58 : >> CMT Rootkey Hash CERT : NOLO
    09:24:59 : >> CMT Rootkey Hash CERT : KEYS
    09:25:00 : >> CMT Rootkey Hash CERT : PRIMAPP
    09:25:00 : >> CMT Rootkey Hash CERT : PASUBTOC
    09:25:04 : >> CMT Rootkey Hash CERT : PAPUBKEYS [8669C77551AE1280331BBAE6FD0C7CB3D3F44CC1]
    09:25:04 : >> CMT Rootkey Hash CERT : UPDAPP
    09:25:04 : >> CMT Rootkey Hash CERT : DSP0
    09:25:09 : >> CMT Rootkey Hash CERT : MCUSW
    09:25:57 : ContinueFlash_DCT5 Complete
    09:25:57 : STATUS_REQUEST_BB5...
    09:25:57 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5
    09:25:57 : Block Length : 01
    09:25:57 : BB ASIC Index : 00
    09:25:57 : Continue Flash Complete : : No Error - 0 (0x00)
    09:25:57 : Time Taken to Flash : 00:01:07
    09:25:57 :
    09:25:57 : Processing Image File :
    09:25:57 : F:\FILE-NOKIA\RM-578-2730C\rm578__10.47.ppm_v
    09:25:57 : CMT Type : BB5
    09:25:57 : CMT Algorithm : BB5 ALGORITHM
    09:25:57 : Secondary Sending Speed : 3250000 Hz
    09:25:57 : Algorithm Sending Speed : 6500000 Hz
    09:25:57 : Program Sending Speed : 6500000 Hz
    09:25:57 : Message Reading Speed : 98000 Hz
    09:25:57 : Number of Blocks : 434
    09:25:57 : Entry Point : 0x00B6
    09:25:57 : Page Format : 128K
    09:25:57 : Maximum Page Size : 0x00004000
    09:25:57 :
    09:25:57 : VPP Enabled by Software
    09:25:57 : Using Internal VPP
    09:25:57 : StartErase_DCT5...
    09:25:57 : BlockLength : 0x0E (14)
    09:25:57 : ERASE Blocks : 0x01 (1)
    09:25:57 : 0 ERASE_AREA_BB5 0x12
    09:25:57 : Block Length : 0x0B (11)
    09:25:57 : BB ASIC Index : 0x00 CMT
    09:25:57 : Device Type : 0x00 NOR
    09:25:57 : Device Index : 0x00
    09:25:57 : 0 : 01760000-01FFFFFF
    09:25:57 :
    09:25:57 : Erase_SendEraseBlock_BB5_NOR
    09:25:57 : Task in Progress... Please Wait...
    09:26:35 : STATUS_REQUEST_BB5...
    09:26:35 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5
    09:26:35 : Block Length : 01
    09:26:35 : BB ASIC Index : 00
    09:26:35 :
    09:26:35 : Successfully erased..
    09:26:35 : Time Taken to Erase : 00:00:38
    09:26:35 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9
    09:26:35 : ReturnedType : 04 DDR & 2TX
    09:26:35 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
    09:26:35 :
    09:26:35 : Flashing Speed: 5.00 Mhz
    09:26:35 : Processing : rm578__10.47.ppm_v
    09:26:35 : Total blocks to write : 434
    09:26:52 : ContinueFlash_DCT5 Complete
    09:26:52 : STATUS_REQUEST_BB5...
    09:26:52 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5
    09:26:52 : Block Length : 01
    09:26:52 : BB ASIC Index : 00
    09:26:52 : Continue Flash Complete : : No Error - 0 (0x00)
    09:26:52 : Time Taken to Flash : 00:00:16
    09:26:52 :
    09:26:52 : Processing Image File :
    09:26:52 : F:\FILE-NOKIA\RM-578-2730C\rm578__10.47.image_v_black_v2
    09:26:52 : CMT Type : BB5
    09:26:52 : CMT Algorithm : BB5 ALGORITHM
    09:26:52 : Secondary Sending Speed : 3250000 Hz
    09:26:52 : Algorithm Sending Speed : 6500000 Hz
    09:26:52 : Program Sending Speed : 6500000 Hz
    09:26:52 : Message Reading Speed : 98000 Hz
    09:26:52 : Number of Blocks : 1000
    09:26:52 : Entry Point : 0x00C8
    09:26:52 : Page Format : 128K
    09:26:52 : Maximum Page Size : 0x00004000
    09:26:52 :
    09:26:52 : VPP Enabled by Software
    09:26:52 : Using Internal VPP
    09:26:52 : StartErase_DCT5...
    09:26:52 : BlockLength : 0x16 (22)
    09:26:52 : ERASE Blocks : 0x01 (1)
    09:26:52 : 0 ERASE_AREA_BB5 0x12
    09:26:52 : Block Length : 0x13 (19)
    09:26:52 : BB ASIC Index : 0x00 CMT
    09:26:52 : Device Type : 0x00 NOR
    09:26:52 : Device Index : 0x00
    09:26:52 : 0 : 02000000-0245FFFF
    09:26:52 : 1 : 02460000-03FBFFFF
    09:26:52 :
    09:26:52 : Erase_SendEraseBlock_BB5_NOR
    09:26:52 : Task in Progress... Please Wait...
    09:30:18 : STATUS_REQUEST_BB5...
    09:30:18 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5
    09:30:18 : Block Length : 01
    09:30:18 : BB ASIC Index : 00
    09:30:18 :
    09:30:18 : Successfully erased..
    09:30:18 : Time Taken to Erase : 00:03:25
    09:30:18 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9
    09:30:18 : ReturnedType : 04 DDR & 2TX
    09:30:18 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
    09:30:18 :
    09:30:18 : Flashing Speed: 5.00 Mhz
    09:30:18 : Processing : rm578__10.47.image_v_black_v2
    09:30:18 : Total blocks to write : 1000
    09:30:56 : ContinueFlash_DCT5 Complete
    09:30:56 : STATUS_REQUEST_BB5...
    09:30:56 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5
    09:30:56 : Block Length : 01
    09:30:56 : BB ASIC Index : 00
    09:30:56 : Continue Flash Complete : : No Error - 0 (0x00)
    09:30:56 : Time Taken to Flash : 00:00:37
    09:30:56 :
    09:30:56 : Total Flash Write Time (Flashing Only) : 00:02:01
    09:30:56 : Total Flashing Time (Booting + Erase + Flashing) : 00:06:04
    09:30:56 :
    09:31:05 :
    09:31:05 : Waiting for Phone to Go Online...
    09:31:06 : Elapsed Time: 1s
    09:31:07 : Elapsed Time: 2s
    09:31:08 : Elapsed Time: 3s
    09:31:09 : Elapsed Time: 4s
    09:31:10 : Elapsed Time: 5s
    09:31:11 : Elapsed Time: 6s
    09:31:12 : Elapsed Time: 7s
    09:31:13 : Elapsed Time: 8s
    09:31:14 : Elapsed Time: 9s
    09:31:15 : Elapsed Time: 10s
    09:31:15 :
    09:31:15 : ================================================
    09:31:15 : Basic Phone Information
    09:31:15 : MCU Version: V 10.47 27-08-10 RM-578 (c) Nokia
    09:31:15 : IMEI Plain : 355931046608987
    09:31:15 : IMEI Spare : A355931046608980
    09:31:15 : IMEI SV : 33559310466089862F
    09:31:15 : Phone Model: Nokia 2730 classic
    09:31:15 : Category : Classic Phone
    09:31:15 : Phone Type : RM-578
    09:31:15 :
    09:31:15 : Extended Phone Information
    09:31:15 : Product Serial Number: DUI727283
    09:31:15 : Product Code : 059C0H1
    09:31:15 : Module Code : 0204764
    09:31:15 : Basic Production Code: 059C5X3
    09:31:16 : Long Production SN : 0
    09:31:16 : PPM SW Version : V 10.47 27-08-10 RM-578 (c) Nokia V
    09:31:16 : BT MCM Version : 2.31-SP2.26
    09:31:16 : MCU SW Version : V 10.47 27-08-10 RM-578 (c) Nokia
    09:31:16 : HW Version : 2004
    09:31:16 : RFIC Version : 17141716
    09:31:16 : DSP Version : ICPR72_10w01_Tommy
    09:31:16 : LCD Version : SEIKO
    09:31:17 : Content Pack Version : Content: v_black V 10.47 27-08-10 RM-578 (c) Nokia
    09:31:17 : AHNE Version : 30
    09:31:17 : RETU Version : 16
    09:31:17 : TAHVO Version : 22
    09:31:18 : Bluetooth ID : FC:E5:57:7E:8B:F6
    09:31:18 : CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA VIII
    09:31:18 :
    09:31:18 : ================================================
    09:31:18 : Simlock Information
    09:31:18 : CONFIG KEY : 0000000000000000
    09:31:18 : PROVIDER KEY : 2440700000000000
    09:31:18 : NETWORK NAME : Nokia Default;Finland
    09:31:18 : LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
    09:31:18 : SIMLOCK TABLE :
    09:31:18 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
    09:31:18 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
    09:31:18 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
    09:31:18 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
    09:31:18 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
    09:31:18 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
    09:31:18 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
    09:31:18 : SIMLOCK STATE : Not Locked
    09:31:18 :
    09:31:18 : SIMLOCK_TYPE : PA_SL3 (15-digit NCK)
    09:31:18 : SIMLOCK_TEST : PASSED
    09:31:18 : SECURITY_TEST : PASSED
    09:31:18 : SECURITY_CODE : 281146
    09:31:19 : PHONE_MODE : TEST
    09:31:19 :
    09:31:19 : ================================================
    09:31:19 : Dynamic Camera Configuration
    09:31:19 : DCC ID : NIMMIIIIRRFF00000000
    09:31:19 : DCC Ver: XXXXXX
    09:31:19 :
    09:31:19 : ERROR: DCC File Mismatched!
    09:31:19 :
    09:31:19 : Required DCC File:NIMMIIIIRRFF00000000
    09:31:19 : Write the correct DCC to Fix the Problem
    09:31:25 :
    log nó đây ae xem giúp
    Thành viên tích cực Chiến_mobile's Avatar
    Oct 2012
    thay màn , thay trở 47k, thay cặp nguồn
    nghệ an quê choa >>> 0967 398 678 ....cuche_pro@yahoo.com
  6. ( Chiến_mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Thành viên tích cực V_K85's Avatar
    Jun 2006
    đóng lại thử coi đc ko,máy va chạm sợ bị đứt chân
    V_K
    chuyển qua Iphone 0918745688
  8. ( V_K85 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  9. #6
    Feb 2011
    ok...làm chân đóng lại ok..tưởng thay cả cặp rùi...thank
  10. #7
    Thành viên mới duchoabmt's Avatar
    Feb 2013
    274 thôn 7 hòa phú đăklăk
    Trích Được post bởi lyvant Xem bài viết
    cái bệnh contac sever này a thử kiểm tra socket của màn hình và main đi nhé nếu ko dk thì tet cái màn khác thử xem sao .Kiểm tra kỹ từ socket trên main vào U xem có đứt chân nào ko nếu có thì tìm cách câu lại nhé máy đập hiếm khi có bệnh lỗi phần mềm lắm ...
  11. #8
    Thành viên mới 0977616463's Avatar
    Máy đập thì đóng lại là dc cớ sao phải thay ?...............................................
  12. #9
    Vi phạm nội quy hongquan_gsm's Avatar
    Dec 2012
    Usa
    nếu bạn backup rồi thì ok,bạn thay flash xong ban chạy lại bình thường sau đó xóa và buckup là ok chúc may mắn
  1. Trả lời: 10
    Bài viết cuối: 11-09-2012, 17:05
  2. 2730c tự khởi động
    By hahagiang1 in forum BB5
    Trả lời: 17
    Bài viết cuối: 11-09-2012, 12:05
  3. sơ đồ 2730c
    By madao in forum BB5
    Bài viết cuối: 07-06-2011, 17:28
  4. 2730c vô nước mất dèn màn hình
    By khoailac1984 in forum BB5
    Bài viết cuối: 10-02-2011, 09:29
  5. máy 2730c anh em cho ý kiến dùm
    By Phungmobi in forum BB5
    Bài viết cuối: 09-09-2010, 22:09
