ATF v9.83
Release Date: May 08, 2013
Firmware Version Required : 10.3.50
*** Only Available via the AutoUpdate Server ***
1.
Lumia WP8 Recovery Flashing Added
Supported Phones:
All Lumia WP8 Phones
This will allow re-flashing of Lumia Phones which encountered an error during a previous firmware update (incomplete flashing). This will only work if BOOT Loaders are still OK.
To perform recovery flashing:
1. Run ATF Software, load the flash WP8 Flash File and click FLASH.
2. Hold VOLUME_DOWN + POWER button until the phone will vibrate.
3. Release VOLUME_DOWN + POWER button then connect USB Cable.
4. Recovery Flashing will start and will Fix Partitions.
2.
BB5 Read Firmware Version via Flash Mode
Supported Phones:
All Single-CPU BB5 Phones (RAP3, RAPIDO, RAPUv1, RAPUv2, Broadcom and XG223)
NOT Supported Phones:
All Dual-CPU BB5 Phones (E90, N90, N95, N95-8GB, N73, N80 etc...)
This will allow you to know the current firmware version inside the phone just in case the phone is dead. It will also prevent you from accidentally DOWNGRADING any BB5 Phone. USB and FBUS Connection are both supported.
To check current firmware version:
1. Click "Buscheck" or "Backup RPL" Button
3.
Added Alternative USB Boot Method in Settings
In Settings --> Nokia Settings, check this:
Use BB5 USB Boot Settings Type 2 (Fixes Booting Problem on some PC)
If you get BB5 Booting Problems stuck at:
"FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)"
* Complete Product Listing in Nokia.ini (as of May-08-2013)
ATF v9.80
Release Date: April 30, 2013
Lumia Windows Phone 8.0 Dead Boot Repair via TP (First In The World!)
Supported Phones:
Lumia 520T RM-913
Lumia 520 RM-914
Lumia 520 RM-915
Lumia 521 RM-917
Lumia 620 RM-846
Lumia 720 RM-885
Lumia 720T RM-887
Supported Partition Repairs:
M.B.R. (Master Boot Record)
G.P.T. (GUID Partition Table)
SBL1
SBL2
SBL3
UEFI
RPM
TZ
WINSECAPP
Custom Read/Write eMMC Blocks also supported. The password is still
"password" in HEX format.
(Hint: RPL and Simlocks are inside a FAT12 Mountable Partition called DPP)
Added Test Point Pictures for 520T, 520, 521, 620, 720 and 720T
What's New ?
* Lumia Windows Phone 8.0 Dead Boot Repair via TP
* ATF FiRE Server Capable EXE (Flash Files/Links are still uploading)
Bug Fixes:
* Fixed Lumia Custom eMMC Read/Write Bug on new Hynix eMMC
* Fixed SD Card Custom Password Masking
Other Stuff
* Complete Product Listing in Nokia.ini (as of April-30-2013)
For this Update I give Special Thanks To:
X-shadow's Wife for editing the Test Point Pictures for the new Lumia Windows 8.0 Phones.
Who will buy this if you can get more in ATF?
__________________________________________________ ________________________
Buy only from ATF [Advance Turbo Flasher] authorized resellers:
ATF [Advance Turbo Flasher] Authorized Distributors and Resellers List
ATF [Advance Turbo Flasher] official web sites:
International - http://www.advance-box.com/
ATF [Advance Turbo Flasher] official support forums:
World Wide: Advance Turbo Flasher - GSM-Forum
Indonesia: ATF (Advance Turbo Flasher))
Philippine: Gsmph
Syria: Arabic Support (Syria) GsmVIP
Chinese support forum : ATF Box
Vietnam: Saigonmobile
India: Advance Box - .:: GsmIndia ::.
Official Iran Support Forum : ASANGSM FORUM
Bangladesh: Advance Box - Dhaka Mobile
Chinese Support forum : www.yananliuhuan.com
The Master Piece
			 ATF AutoUpdate v9.83 - Some New Stuff - 08 May 2013
