Trang 1 của 4 1 2 3 4 CuốiCuối
Kết quả 1 tới 10 của 35
    Sóc Sơn - Hà Nội
    Mặc định Hot ! Jailbreak iOS 6.1.3 Untethered
    This jailbreak supports firmware 6.1.3 and isn't the easiest jailbreaks to use, but you won't have any problems if you follow the instructions.
    Rocky Racoon 2.0b1 uses new groundbreaking solution to jailbreak untethered, so some devices may need patches generated by the server during the jailbreak process (like in the JailbreakMe 3.0).
    Rocky Racoon is currently available for Windows only.
    In Rocky Racoon 2.0b1 load 6.0 or 6.0.1 IPSW file to jailbreak iDevice on 6.1.3!
    Rocky Racoon 2.0b1 supports the following devices on 6.1.3:
    - iPhone 5
    - iPhone 4S
    - iPhone 4 (GSM), iPhone 4 (CDMA)
    - iPhone 3GS
    - iPad 4
    - iPad Mini
    - iPad 3 (WiFi/CDMA/Global)
    - iPad 2 (WiFi/CDMA/GSM)
    - iPod 4G
    - iPod 5G
    How To Use Rocky Racoon 2.0:
    1. Make a backup of your device iTunes by right clicking on your device name under the 'Devices' menu and click 'Back Up'.
    2. Once your backup is complete return to your device and go to Settings - General - Reset - Erase All Content and Settings. This will make the jailbreak process much faster.
    3. Open Rocky Racoon and be sure your iDevice is is switched ON and plugged OFF!!!
    4. Click 'START' and wait...
    5. Select IPSW firmware file and wait until Rocky Racoon reads firmware data.
    6. Now PLUG IN your iDevice and stay SWITCHED ON.
    7. When your iDevice is detected, click "JAILBREAK" and follow the instructions on the screen.
    8. Jailbreak process can take several minutes, so be patient and do not unplug!
    9. Once jailbroken return to iTunes and restore your backup from earlier. To do so, right click on your device name under the 'Devices' menu in the left panel of iTunes and click 'Restore From Backup...' then select the latest backup you created before. (restoring this backup will return all the content previously on your device, i.e. apps, photos, etc.)
    Dowload
    Nguồn Sưu Tầm !
  2. ( trongtan8909 ) đã được 5 thành viên cám ơn vì bài viết hữu ích!
    HOAINAM GSM (12-05-2013), huphuc_mobile209 (09-07-2013), songhuynh1988 (17-05-2013), TAN_LOC (12-05-2013), TuệNguyễn (12-05-2013)
    Anh đả test thử chưa mới dow cái tool này về, mở lên ok --> Very Good --> không đòi pass gì hết nhưng chưa dám thử
    Sóc Sơn - Hà Nội
    đã test thử ok ! mai mình đăng clip nên cho mọi người !
    Trích Được post bởi trongtan8909 Xem bài viết
    Vậy Jailbreak cho máy xong, có mất dữ liệu trong iphone không anh
    V.I.P ĐƠ_NGUYỄN's Avatar
    quan trọng là câu nói này
    Thành viên kỳ cựu thanhchuong1221's Avatar
    Mar 2012
    hot quá chủ thớt ơi. đừng cho mọi người leo cây đấy!
    Thành viên mới TAN_LOC's Avatar
    Oct 2012
    Trích Được post bởi thanhchuong1221 Xem bài viết
    thử xem có gì báo nhang chủ thớt.
  9. #8
    Thành viên tích cực TUẤN ANH's Avatar
    May 2013
    sài gòn _vĩnh phúc
    đánh liều thử con 3gs lock coi .he he he
  10. #9
    Thành viên tích cực Chiến_mobile's Avatar
    Oct 2012
    bản dịch đây
    Làm thế nào để sử dụng Racoon Rocky 2.0:
    1. Tạo bản sao lưu của iTunes điện thoại của bạn bằng cách nhấn chuột phải vào tên thiết bị của bạn trong menu của thiết bị "và nhấp vào 'Sao'.
    2. Sau khi sao lưu của bạn là hoàn toàn trở lại thiết bị của bạn và vào Settings - General - Reset - Xoá bỏ Tất cả nội dung và Cài đặt. Điều này sẽ làm cho quá trình jailbreak nhanh hơn nhiều.
    3. Mở Racoon Rocky và chắc chắn iDevice của bạn được bật và cắm OFF!
    4. Bấm vào 'START và chờ đợi ...
    5. Chọn file firmware IPSW và đợi cho đến khi Racoon Rocky đọc dữ liệu phần mềm.
    6. Bây giờ cắm iDevice của bạn và ở lại bật lên.
    7. Khi iDevice của bạn được phát hiện, nhấp vào "Jailbreak" và làm theo hướng dẫn trên màn hình.
    8. Quá trình jailbreak có thể mất vài phút, vì vậy hãy kiên nhẫn và không ngắt kết nối!
    9. Sau khi jailbreak trở lại iTunes và khôi phục sao lưu của bạn từ trước đó. Để làm điều này, kích chuột phải vào tên thiết bị của bạn dưới trình đơn 'thiết bị' trong bảng điều khiển bên trái của iTunes và nhấp vào 'Khôi phục từ sao lưu ...' sau đó chọn sao lưu mới nhất mà bạn đã tạo trước đó. (khôi phục lại bản sao lưu này sẽ trở lại tất cả các nội dung trước đó trên thiết bị của bạn, ví dụ như các ứng dụng, hình ảnh, vv)
    dowload
    nghệ an quê choa >>> 0967 398 678 ....cuche_pro@yahoo.com
  11. ( Chiến_mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    sangnguyenag (12-10-2013)
  12. #10
    Feb 2012
    tây ninh
    hot hot hot.ae tét thử ok hú thằng em phát.để thằng em phực con ip4-6.1.3.ae nào có máy 3gs múc phát cho em nó coi rồi báo ae cái
  1. Sắp có Jailbreak Untethered cho iOS 6.1.3 và 6.1.4
    By toilatoi142001 in forum TỔNG HỢP FIRMWARE - JAILBREAK - UNLOCK
    Trả lời: 14
    Bài viết cuối: 25-11-2013, 12:49
  2. Sắp có Jailbreak Untethered cho iOS 6.1.3 và 6.1.4
    Bài viết cuối: 31-07-2013, 08:07
  3. Hướng dẫn untethered jailbreak iOS 6.1 & 6.0.1
    By 5ncnow.com in forum TỔNG HỢP FIRMWARE - JAILBREAK - UNLOCK
    Bài viết cuối: 13-03-2013, 22:01
  4. Tool Untethered Jailbreak IOS 5.1.1 đã phát hành
    By ANH_MOBILE in forum TỔNG HỢP FIRMWARE - JAILBREAK - UNLOCK
    Bài viết cuối: 26-05-2012, 08:04
  5. Tool Untethered Jailbreak IOS 5.1.1 đã phát hành
    By LongBiênMobile in forum TỔNG HỢP FIRMWARE - JAILBREAK - UNLOCK
    Bài viết cuối: 25-05-2012, 21:51
