ddasdasdas
    Mặc định VolcanoBox 2.1.0 Update SPD Android Imei now 95% SPD Androind Supported for imei
    VolcanoBox 2.1.0
    Whats new ?
    Update SPD Android IMEI Write
    (Now 95% SPD Android phone Supported for imei repair !!)
    MTK Bug Fixed
    MediaFire / Hotfile
    Please share here all your tested preloader mode tested TestPinouts ....
    Little Guide :
    What is it ?
    in MTK Android there is many Partitions in your phone. like Preloader, Recovery, Bootimg etc..... if somehow Preloader get Corrupted then you phone will not able to DETECT WITH PC !!! in other words you will have phone with BOOT DEAD.
    How Preloader get corrupted ?
    There could be few reasons but main reason could be that someone or you Flash your complete phone (include Preloader) with wrong files or with wrong ver. Also there could be reason someone Delete Preloader or you Deleted.
    How could i know my phone have preloader dead ?
    Preloader can be dead if some one Flash it wrong and after flash your mobile will not detect with pc any more. for confirm
    open device manager
    take battery out from phone
    insert usb
    insert battery
    and check is computer detecting any device
    If it's not detect then you have phone which Preloader is dead AKA Boot Dead
    How can i repair it ?
    you have to disassemble your phone and take pcb out. check there should be some Golden points. check these points there should be written on them Rx,Tx,GND,Vcc,Vcharge etc... check there should be written "COLO" or "KOLO" or "KCOLO" you have to Sold that point with GND After Sold Attach usb now your phone will detect with USB !! and now ready to Flash.
    In some phones "COLO" or "KOLO" or "KCOLO" not written for those type of phones you have to test all points one by one Short Golden point with GND and attach usb cable which point short with gnd can able to detect your phone by pc is Force Preloader Mode Test Point !! Keep in mind Don't Short Vcc,Vcharge or any other pin which have 4.x Volts also i had tested "Colo" or "Kolo" or "KCOLO" don't have any kind of volts..
    So Please share your Researched Force Preloader mode TestPoint Picture with Model name
    Here i am starting with two pictures
    Qmobile A10 Dead boot repair TP
    CPU TYPE:6575
    Special Thanks to Danish for test
    Qmobile A2
    [B]CPU TYPE:6573
    Special Thanks to SweatHamza for Test
    All Off topic will be deleted !! keep this Thread clean
    @ All Copy pasters Don't Copy this
    USE THIS THREAD FOR PRELOADER TP
    @All Share Here>Android Phones Force Preloader Mode Test Points AKA REPAIR DEAD BOOTS - GSM-Forum
    GPGINDUSTRIES PRESENTS COMBO BOOT CABLE
    GPGIndustries & VolcanoBox Team presents Chinese Android mobiles Combo Boot Cable - GSM-Forum
  2. ( Lính Khang ) đã được 2 thành viên cám ơn vì bài viết hữu ích!
    haomobilest (16-05-2013), hoangdaika (16-05-2013)
  1. VolcanoBox 2.0.4 SE ST18 - Coolsand 16MB Imei - SPD Android - MTK Android - MTK Imei
    By Lính Khang in forum THÔNG TIN CẬP NHẬT MỚI NHẤT CỦA THIẾT BỊ
    Bài viết cuối: 22-04-2013, 09:36
  2. VolcanoBox 1.9.8 MTK 625a Imei Repair with USB, SPD Android Format, MTK Andrid,
    Bài viết cuối: 16-03-2013, 18:31
  3. VolcanoBox 1.9.0 W1st Coolsand CPU ID - MTK Android 4.0.9 Imei Repair & More..
    Bài viết cuối: 27-01-2013, 09:25
  4. VolcanoBox 1.6.9 MTK Andriod 4.0.4 Imei Repair Supported now !!
    Bài viết cuối: 08-11-2012, 19:36
  5. VolcanoBox ver 1.6.7 SPD Android Imei Repair Supported & more SPD Imei repair
    Bài viết cuối: 01-11-2012, 07:40
