Huawei Um840 Hard Reset
Volume UP+Send+Power For Enter To Recovery Mode
Select Wipe Data/Factory Reset Delete Alll User Data
Waiting And Select Reboot Phone
Huawei U9508 Honor2 Hard Reset
Volume up+Power 5 Seconds
Select Wipe Data/Factory Reset Deleted All User Data
Huawei Ascend G300 Hard Reset
Step 1
Hold down the Volume Up and Power buttons simultaneously.
When you see the Huawei logo appear, release the power button but continue to hold the Volume Up button until your see the Android logo, then release.
This will access the blue unlock/reset menu.
Step 2
Once you've reached the unlock/reset menu, scroll down, using the volume buttons, and select ‘wipe data/factory reset’ by pushing the power button.
Step 3
When prompted, scroll down and select ‘Yes -- delete all user data’. This may take a few moments
Step 4
When prompted select ‘reboot system now’.
Hard Reset Huawei Ideos S7 Slim
Turn off the Huawei Ideos S7 Slim
Hold together button : Power + Volume Down for several second until the Ideos logo appear in the LCD. After that than suddenly release both button. The Ideos S7 Slim will running it self and without any asking or without notice the tablet will be reset to factory default.
How to Hard Reset Huawei U8300
1.Turn off phone
2.Press Volume UP Call Button then press Power
To Reset from Menu
1.Press menu Key
2.Select Privacy
3.Select Factory Date Reset
4.Select Reset Phone
5.Select Erase eVERYTHING
Hard Reset Huawei u8500 Ideos X2
press the "volume button" , the "call button" and the "power button" at the same time, then wait until you get in the screen where you can select the "reset factory" when you select the factory reset wait for the message "complete" then after that choose the "reboot".
Huawei ideos X3/Blaze U8510 hard reset
Turn off phone.Hold down volume up and power button
Boot menu will appear.Use volume down to navigate and power button as okay.
select wipe data/factory reset
Huawei Ascend Y201 Pro Hard Reset
Here Is Procedure....
Hold Volume Up & Home Button Lower Center Touch Pad & After That Press Power Button....
When Ur Handset Vibrate Release Power Button But Keep Holding Volume Up & Home Button...
After 3 To 5 Second Handset Show Recovery Mode....
After That Press Volume Down Button To Wipe Data/Factory Reset...
After That Press Power Button To Make Reset...
After That Wipe Cache Partition...
After That Ur Handset Are In Factory State...
P/S : sưu Tầm
			 Hard Reset 1 số máy  Huawei cho anh em cần
