log đây
Booting Phone via FBUS...
AdvanceBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
TIME STARTS HERE
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00010006
ID DWORD 3 : 400C1921
ID DWORD 4 : 01051103
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 00000296
3 EM_ASIC_ID 02
ID DWORD 0 : 00000B22
4 PUBLIC_ID 12
ID DWORD 0 : 07500010
ID DWORD 1 : 12B20052
ID DWORD 2 : ECFB09F2
ID DWORD 3 : F60693FC
ID DWORD 4 : DD77E77F
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 47 9C 6D DE 39 42 E1 2C 42 9C 1D 6A DE D8 03 71
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 4B9B7510
CRC 1 : 3E691FF8
Checksum AE
SearchForBootstrap_DCT5..
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg
Boot File - Version 012.08.00
Boot File - Revision 0x0002 (2)
eBB5ProtocolType == New
PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
Secondary Loader Sent...
TransmissionTypeRequest_DCT5_NewProtocol
TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
Transmission Type Request Sent...
MessageID : 06
SubBlocks : 06
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : RAM 05
Device Index : 00
Manufacturer Code : 0000 -> Flash
Device ID : 0000 -> not detected
Extended/Fixed ID : 0000
Revision ID : 0000
2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Type : NOR 00
Device Index : 00
Manufacturer Code : 0400 -> Flash
Device ID : 0000 -> Type not in database
Revision ID : 0000
4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Index : 01
Manufacturer Code : 0000 -> SPANSION
Device ID : 0001 -> not used
Revision ID : 0000
5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MuxOneNAND 03
Device Index : 00
Manufacturer Code : 00EC ->
Device ID : 0040 -> KAT00F00RA
Revision ID : 0231
6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
Block Length : 09
Data : XSR 1.6
Checksum : 13
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0040 ExtID :0000 RevID :0231
Flash Descriptor
Device ID : 0040
Revision ID : 0000
Size : 10000000 (256 MB)
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR17_alg.f g
Algorithm File - Version 012.08.00
Algorithm File - Revision 0x0002 (2)
Algo Loader Sent...
SendCodeStart_NewProtocol :
SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok...
VPP Enabled by Software
Using Internal VPP
FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
PAPUB_KEYS_HASH_REQ_BB5
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
7DC72D3FDC552426A4479BC820097D304CFB6C15
PHONE FIRMWARE VERSION:
51.0.002
Scanning Simlock Applet Type...
OK
PA_SIMLOC30 Applet detected
Use "Scan Phone" Button to Check if this Phone
uses a 15-digit NCK or a 20-digit NCK...
* Firmware Version Downgrade will KILL PHONE !!!
* Manual Full Erase WILL KILL PHONE!!!
* Simlocks are in PM 120 Only...
* PM 308 is Write Protected...
Basic Phone Information
MCU Version: V ICPR72_11w16.1 28-07-11 RM-588 (c) Nokia
IMEI Plain : 359288044324711
IMEI Spare : A359288044324710
IMEI SV : 33592880443247125F
Phone Model: Nokia 5230
Category : Classic Phone
Phone Type : RM-588
Extended Phone Information
Product Serial Number: 3304F44AA
Product Code : 059C4N4
Module Code : 0204359
Basic Production Code: 059C249
Long Production SN : 0
MCU SW Version : V ICPR72_11w16.1 28-07-11 RM-588 (c) Nokia
HW Version : 0810
RFIC Version : 17141716
DSP Version : ICPR72_11WK13
AHNE Version : 11
APE SW Core Version : V 51.0.002
Variant Version : V 51.0.002V 51.0.002 V 51.0.002
APE Test Version : eno_version
RETU Version : 16
TAHVO Version : 22
APE HW Version : 256
APE ADSP SW Version : 256
Bluetooth ID : 14:36:05:0B:C0:9C
CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA VIII
Simlock Information
CONFIG KEY : 0000000000000000
PROVIDER KEY : 2440700000000000
NETWORK NAME : Nokia Default;Finland
LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
SIMLOCK TABLE :
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK STATE : Not Locked
SIMLOCK_TYPE : PA_SL3 (15-digit NCK)
SIMLOCK_TEST : PASSED
SECURITY_TEST : PASSED
SECURITY_CODE : ENCRYPTED
PHONE_MODE : TEST
DCC ID : NOT USED
Make sure you have installed the
COMPLETE Flash Package for this Phone...
Goto "Settings" --> "Nokia Settings" and verify that
the Folder where you installed your Flash Files are
in the "PRODUCT PATH TO SCAN" List...
em đã thay nguồn lớn, nhỏ từ máy 27 sang mà vẫn y nguyên vây.
đo áp mở nguồn không có, và sạc không lên nguồn. chỉ bú check là ok hết
anh em giúp em với.
			 5230 bus check ok hết bật nguồn ko lên
